How to correctly desolder through hole IC?
    replied
    Re: How to correctly desolder through hole IC?
    incidentally, R13 is burned up.
  • Christian0734
    replied
    It's a cinch with real quality braid and real flow and not cheap chinoiserie. I use Amtech flux, the real one, not the Chinese copies and the "BMJ" desoldering braid and it is very easy to remove the solder and unclog the holes with that. When we look at the inexpensive braid and the quality braid with a microscope or a binocular, they are not at all the same thing. In the quality braid there are many more filaments and they are much smaller, which increases the capillarity. There is no comparison in use
    replied
    MLCC = Multi Layer Ceramic Capacitor.
    Take caution when handling them, check the resistance after you install the cap to make sure it is not damaged and shorted out due to mis-handling.
    Read the PDF attached.
  • LearningToRepair
    replied
    Originally posted by momaka
    *EDIT II*
    Looks like the cracked MLC is connected to pin 9 (and maybe ground - please check.) That's a signal IC pin, so probably a 16V-rated or higher MLC will do. As for the capacitance, I think that will depend on the circuit design, since it's connected to the inverting input of the PWM comparator. The test circuit in the datasheet suggests 10 nF. But again, that may not be the value that's in your circuit. It does give you an idea for a ball park, though (i.e. it's probably not over 1 uF and probably not lower than 1 nF... but that's still a huge range to guess.)
    If you have a cap meter or capacitance measure setting on your multimeter, you can test that MLC (out of circuit.) If it reads open or infinite capacitance, it's probably bad. If it does show a good standard capacitance value, it's probably OK and you can leave it back in.
    Yes, It goes to pin nr 9. When I took it out of circuit I was unable to get any reading. I think it was because the other side was broken off. Just asking to be sure: can I be confident that this is capacitor or are there also other components that are yellow like that?
    I would also like to know where you got 10 nF? Did you use this datasheet?
    page 5? It doesnt have any units. Is it default to assume that numbers are in uF and therefore 0.01 uF = 10 nF?
    Local hardware store sells 10nF*50V X7R 10% SMD 0805 is it good enough? Sadly they dont have any other info than just product name. Also what does MLC exactly mean? If my local store lists this as SMD capacitor, are they same thing or different?
    Here is also macro photo of after removing it from the board in case it helps.
  • eccerr0r
    replied
    If you're using wick, you need the really fine wire stuff and have plenty of flux on it.
    Usually old wick is no good. If your wick is not shiny bright yellow copper colored and just red copper colored, it's probably no good anymore...
    Don't store your wick in a humid environment, if you have fresh wick you might want to keep some desicant with it.
  • i4004
    replied
    https://www.chipquik.com/store/index.php?cPath=200
    replied
    I also never got it to work until I tried it with a really large tip (=large thermal mass).
    Nope, still no success for me.
    By default, I use a 5.2 mm bevel tip with my 75-Watt station. It has enough thermal mass and heat transfer to melt a large blob/pool of lead-free solder for flooding the pins on a D-SUB port on a motherboard (to pull it out) - and I've done it a few times now with no issue.
    replied
    i only use wick for cleaning tinned tracks in combination with a blade-style tip.
    but to be fair, i have an electric pump.
  • Per Hansson
    replied
    I've been soldering for years, and I have NEVER been able to use wick to clean holes and remove components like some videos show. I've tried both cheap and expensive wicks, with and without flux, with my 75-Watt temp-controlled soldering station. As such, I NEVER recommend wick to anyone, especially beginners. And for through-hole components, wick is a big waste of time IMO. I only keep a little bit now for BGA work, which I haven't done in years.
    Then it works absolutely amazing, I can sometimes even clear multilayer PCB's (Though that is unusual) but a board like here should be doable...
    The tip in question is a "SMD" tip for my Weller soldering station, i.e. a tip that can reach both sides of a 0805 component for example.
    replied
    Originally posted by stj
    most wick is pretty crap unless you add flux to it first.
    Otherwise for removing multi-pin components and ICs like this, I either use a regular soldering iron with a manual vacuum pump or I use my 40-Watt Radio Shack soldering iron that has a built-in bulb sucker. Both work pretty well. Generally I usually try the RS 40-Watt iron first, as it's quicker and less work. But when there are large solder joints that the RS 40-Watt iron can't tackle, I go for my 75-Watt soldering station and my manual spring-loaded sucker. With these two, I can remove just about anything.
    I don't suggest buying an expensive iron with a built-in sucker just for this one job. If you're going to do DIP ICs a lot, then yes it makes sense. But since through-hole soldering is not so popular anymore, it's not going to be a very useful tool. If you're going to spend that kind of money, then better get a regular but good-quality temperature-controlled soldering station (probably one that use T12 tips) and a cheap-ish spring-loaded sucker.
    Originally posted by budm
    BTW, you should use good IC socket so If you have to replace the IC again, it will be easier to replace the IC.
    That's a good idea, but not always applicable.
    Some ICs need to be soldered to a large ground plane for thermal management reasons (e.g. certain low-power audio ICs.)
    So depending on what the IC is/does, an IC socket may or may not be used.
    *EDIT*
    Looking at the pictures and checking the datasheet shows it's an SMPS controller, so probably OK to put in a socket. Always check with datasheet of course.
    Originally posted by LearningToRepair
    The capacitor I am talking about is the yellow one on the picture I attached to my previous post. Not exactly sure if it is MLC.
    Yup, it's MLC.
    What's the part number on the IC?
    Looks like KA3525A from the picture, if I'm not mistaken.
    Knowing what the IC is and finding its datasheet are the first two things to help determine the cap value. A lot of times, the circuit on the PCB may closely resemble an application circuit in the datasheet. This can help you find the value of that capacitor... or at least a ball park.
    That aside, any reason for changing out this IC? If this is for troubleshooting a PSU, a lot of time, the IC is not the issue - at least not if it's just a PWM driver or voltage monitor. If it is one of those offline PWM-FETs/ICs, then those do actually go bad somewhat more often.
    *EDIT II*
  • LearningToRepair
    replied
    replied
    Since you got the IC remove, you should check that you still have connection between the top side and the bottom side of the board of each hole, just need to make sure the through-hole plating are not damaged.
    500V rating cap will be so much Bigger size than 5V cap, you also need to use the same type of cap. Are you talking about MLC Capacitor?
  • petehall347
    replied
    you could heat those broke pins and pull out whilst iron still on it .
  • LearningToRepair
    replied
    Thanks,
    I will try out solder sucker. Meanwhile I have few more questions:
    1) Will solder sucker also getrid of broken legs in holes or is it only useful for future desolderings?
    2) Do scratched traces (see attached image) need some sort of treatment?
    3) If I managed to break one piece off of smd ceramic capacitor would I have to replace it and if yes then what would be the voltage rating (see attached image), I read from the internet that it is ok to replace it with capacitor with larger voltage rating, but is there any limit how much higher voltage rating capacitor can I use, for example if original capacitor were rated for 5V and and new one were rated for 500V, would it become a problem or would it be fine as long as capacitance is close enough?
  • petehall347
    replied
    you should get a solder sucker .. it should almost fall out after using one .
    sometimes you need to add new solder to get the old solder to melt to remove it .
    replied
    if you pull a chip out without the pins being TOTALLY unsoldered from the holes, you can rip the through-hole plating out.
  • LearningToRepair
    replied
    if you dont want the chip, cut each leg and then pull them out with tweezers while melting the solder.
    I already tried to add extra flux on wick.
    Ok, I will try to cut the legs next time.
    That is what I do, I rather cutout the chip than damaging the traces.
    What do you exactly mean by damage? Heat damage? It looks like around holes where I tried too hard, the green coating came off a little bit and the copper trace got exposed like 1 mm or maybe a bit less due to heat. Can this and should this be fixed or should the entire thing be now thrown away? also on the other side where I pulled the chip there are few small scratches where copper is visible but not damaged. In that case it's just mechanical damage, not heat damage.
    replied
    replied
    replied
    Ok
    It depends on if you want to spend some money or not
    If want to spend some money then buy a Desoldering Gun with a vacuum pump style
    If you do not want to spend very much money at all use a good quality solder wick with some flux
    Either one will work but you if you choose the second option you should have a temperature controlled soldering iron at a minimum 60 watt would be preferred but could get by with a 40 watt iron but you will have to be some what patient with this but you can stay on a one soldering joint for a real long time because you could have have the pads lift off the board
  • ktmmotocross
    recommend good solder wick on aliexpress
    by ktmmotocross
    I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
    02-08-2024, 12:48 AM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • silberdrache
    Burnt Hole under IC on MacBook Pro M1 Pro 14"
    by silberdrache
    I'm new to this Forum, so I hope it's the right place for this topic.
    Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
    I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
    The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
    I opened it up and there were only three drops of coffee...
    11-10-2025, 11:19 AM
  • corrize
    Best way to solder LVDS connector for beginner (and qfn) ?
    by corrize
    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
    See the test :
    https://youtu.be/bNAzC-EvqHs?t=1767
    With hot air from bellow the board, that's...
    03-09-2023, 02:57 AM
  • petemanuk
    BGA solder balls not connecting - help pls
    by petemanuk
    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
    11-16-2022, 05:21 AM
