A2289 Board 820-01987-A Dead?
  • Kudeta
    • Mar 2020
    • 6
    Hello everyone, I think I am the worst repair guy here is my story...
    I am trying to repair my daughter's board bought 3 months ago she dropped the macbook pro Board 820-01987 Resulting in no Backlight no Image.
    I had fan spin and normal voltage and Amps at this point with the board out.
    I tried to take some measurement on the display cable.
    Unfortunately I felt a quick hot sensation when I did this... I know I know...
    This is where I am at:
    When I plug in the A2289 I Get 20.4V and takes 0.13A jumping after to 0.36 sometimes 0.42 and go back down to
    0.29A Stays Steady for 10 seconds and the dies to 0.0A
    Comes back up to 0.16A and then back down to 0.00A and stays there.
    The only schematics and boardview I have found is the 820-01598 Which seems to be close enough to the 820-01987
    So keep in mind that these can possibly be wrong but I tried my best to be close to the truth.
    Here are some measurements...
    PBUS G3H 12.62V
    PBUS G3H_SSDO 12.62V
    PP3V3_G3H_RTC 3.31V
    PP3V3_G3H 3.3V
    PP1V8_SLPS2R 1.8V
    SIG OUT / PMU_CLK32K_SOC 0.85V
    PP1V8_AWAKE 1.8V
    PP1V8_SLPS2R_PMUGPIO 1.8V
    PP1V1_SLPS2R 1.1V
    PP0V8_SLPS2R 0.79V
    PP0V82_SLPDDR 0.77V
    PP3V3_AWAKE 3.3V
    PPVDDCPUSRAM_AWAKE 0.8V
    PP0V9_SLPDDR 0.9V
    PP1V1_SLPDDR 1.1V
    PP1V2_AWAKE 1.2V
    PPVDDCPU_AWAKE 0.53V
    PP3V_G3H_RTC 3.01V
    PP5V_G3S 5.12V (ON C3111)
    PP3V3_G3S 3.31V
    PP1V8_G3S 1.8V
    P5VG3S_PGOOD 1.25V
    PPVCCQ_ANI_SSD0 1.8V
    PP0V9_SSD0 0.89V
    PP2V5_NAND_SSD0 2.52V
    PMU_ONOFF_L 1.78V
    PP3V3_S5 3.3 V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 2.40V WITH 0 AMPS TAKEN
    PP1V8_S5 1.80V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.2V WITH 0 AMPS TAKEN
    PPVPCORE_S5 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
    PP1V_PRIM 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
    PP1V8_S3 ?
    PP1V2_S3 1.2V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
    PP1V_S3 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
    PP1V2_S0SW 1.2V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN THIS TIME BOARD WENT UP TO 0.50AMP WITH PROBE ON IT
    PP1V_S0SW 1.04V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
    PPVCCIO 0.98V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN
    PPVCC_S0_CPU 0.03V AT 0.29 AMPS TAKEN AT STARTUP THEN DROPS TO 0.0V WITH 0 AMPS TAKEN Resistance 2.5ohms to Ground Diode 0.005
    PPVCCSA_S0_CPU 0.00V
    PPVCCGT_S0_CPU 0.00V
    U7210 Appears to have all in lines...but
    L7210 0.00v pin 1 and 2
    L7220 0.00v pin 1 and 2
    L7270 0.00v pin 1 and 2
    L7410 0.00v pin 1 and 2
    L7420 0.00v pin 1 and 2
    Rip CPU ?
    Thank you for your kind responses and help I am lost at this point.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: A2289 Board 820-01987-A Dead?
    I assume Apple refused to take it under warranty?
    Voltage on CPU_VR_EN_R?
    Exact resistance to ground on PPVCC_S0_CPU, PPVCCSA_S0_CPU and PPVCCGT_S0_CPU?
    • Kudeta
      • Mar 2020
      • 6
      Thank you piernov for your kind reply.
      You assume right! the macbook showed that it fell on the case....
      These are the results to your question
      CPU_VR_EN_R 1.8V at 0.29 Amps taken for 10 seconds then 0V
      PPVCC_S0_CPU 2.4 Ohms
      PPVCCSA_S0_CPU 10.0 Ohms
      PPVCCGT_S0_CPU 2.4 Ohms
      • piernov
        • Jan 2016
        • 4437
        • France
        I don't have enough experience on these boards to know what could cause VCCSA not to come up after CPU_VR_EN_R comes up.
        Could be an issue with U7100, U7270 or a component around them or the CPU maybe.
        Check voltage on VIN, VCC of U7100 and VCIN, VDRV of U7270 at least.
        • Kudeta
          • Mar 2020
          • 6
          Piernov thanks again for taking the time here is what I found:
          U7100
          Pin 41 Vin 12.62V constant
          Pin 42 VCC 5.12V Constant
          U7270 This one is tough 820-1987 and 820-01598 dont look the same I found U7270 but caps and Res are not populated in the same way on both boards...
          PPBUS_HS_CPU 12.62V
          On caps and resistors around the chip I found 5.11V, 4.8V and 12.62V (1 Cap)
          VCIN not sure
          VDRV not sure
          • Kudeta
            • Mar 2020
            • 6
            I might add
            PPVCCSA_S0_CPU is 1V when The Mbp is taking 0.30Amps for 10sec then goes back to 0V
            • piernov
              • Jan 2016
              • 4437
              • France
              I assumed it was always 0V since for the other power rails you listed 2 measurements.
              So issue is on PPVCC_S0_CPU instead, but it's handled by the same controller, but the VRM chips are U7210 and U7220 instead.
              • dbteckos
                • Jul 2019
                • 6
                • FR
                I have same Logic Board to repair (820-01987-06) and have 20V with 48mA which stays stable to this value. I can feel CPU warming but I have no image on the LCD and not on external display anymore. The LCD is ok, I have tested it with a working board.
                I have noticied if the TrackPad is not connected, there is a current consumption (max 0,62mA) and drops to 0 after few seconds. That's why I'm asking me if this board needs the to communicate with TrackPad to be able to boot.
                I retrieve similar resistance values than Kudeta:
                PPVCC_S0_CPU : about 2Ω
                PPVCCSA_S0_CPU : 9,8Ω
                PPVCCGT_S0_CPU : about 2Ω
                and I can measure:
                PPVCC_S0_CPU : 0,81V (stable)
                PPVCCSA_S0_CPU : 1,02V
                PPVCCGT_S0_CPU : 0V
                Thanks for your help
                • Byeelec
                  • Nov 2015
                  Really?? You'll look for backlight fuse and driver
                  • Byeelec
                    • Nov 2015
                    BTW, Apple also uses an LCD driver. You must know which because there is a USB-C thunderbolt driver
                    • piernov
                      • Jan 2016
                      • 4437
                      • France
                      There's no point in troubleshooting backlight circuit if there's no image or the machine does not even complete POST…
                      • momoomar
                        • Jan 2021
                        • denmark
                        Hey dbteckos did you managed to solve it? i have almost the same issue cuz of water damage..mine is using 20V and 500mA with the TrackPad and 20V with 60mA without it. the fan spins, CPU is warm but no image on the LCD. The U7420(FDMF5804,SIC621) is blown will that effect the image?
                        • dbteckos
                          • Jul 2019
                          • 6
                          • FR
                          Hi momoomar, unfortunately not. I left it out for now waiting a real boardview.. But maybe you can help me.
                          Could you please tell me what voltage you get on the testpoint (beside J8401) with the red arrow on the photo and also diode value when board is disconnected from power ?
                          PS: If U7420 is blown you should try to replace it
                          • joutrade
                            • May 2015
                            • 24
                            • united kingdom
                            do you have ( PP5V_G3S_CPUREG_MISC ) on ( L8504 ) pin 2 ?
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              With shorted U7420, very high chance of dead CPU.
                              • dbteckos
                                • Jul 2019
                                • 6
                                • FR
                                Yes joutrade 5,12V present on L8504 (pin 1 and pin 2)
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 667
                                  Question do you by any chance have an ultra sonic cleaner like a crest? Possibly would be considered to put it through a cleaner if it’s recently water damaged? I had a board like this, threw it in the cleaner and it booted. Major water damage, worked like a charm after. Sometimes you get lucky with these boards if you clean them up properly. If it doesn’t boot, it also helps you solve the problem faster.
                                  sigpic
                                  MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                  • dbteckos
                                    • Jul 2019
                                    • 6
                                    • FR
                                    I have an ultrasonic cleaner, I will try. What temperature and time settings do you recommend ?
                                    • dokctor
                                      • Sep 2017
                                      • Russia
                                      Hello, did you manage to get it refurbished?
                                      • dbteckos
                                        • Jul 2019
                                        • 6
                                        • FR
                                        Hi, same issue with ultrasonic cleaning
                                        • jasonr2000
                                          MacBook Pro A2289 No Power
                                          by jasonr2000
                                          hi guys I have a 2020 MacBook Pro A2289 it has the i5 CPU and is now acting as if its dead,
                                          when I plug in the charger cable with a volt meter thing connected as well its drawing 20.3v and 1.11A
                                          if I press the power button nothing happens.
                                          but if I hold the power button for 7 seconds or more the voltmeter drops all the amps down to 0.00A but voltage stays the same.
                                          any ideas where I can check ??
                                          from what I can gather it must be charging the battery at 1.11A as nothing happens when the power button is pressed. I can successfully...
                                          03-08-2025, 10:22 AM
                                        • Fisher8865
                                          MacBook Pro A1990 stuck at 5v .592 amps
                                          by Fisher8865
                                          Hi guys
                                          I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                                          05-30-2024, 07:36 PM
                                        • Stephen
                                          MacBook Air 13" A2179 2020. 5Volts .250 amps issue
                                          by Stephen
                                          Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
                                          PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
                                          ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully...
                                          02-18-2025, 05:54 PM
                                        • alexruehr
                                          A2289 - 820-01987 - Dead?
                                          by alexruehr
                                          Hey guys, just troubleshooting a MacBook Pro A2289 with the 820-01987 logic board.
                                          No fan spin, no booting, device not getting detected by the Apple Configurator.
                                          Did a few basic things, the board gets to 20V USB supply according to my USB tester, F7000 fuse seem to be ok and not blown.
                                          Board draws about 0.5A for about 10 seconds, after that it goes down to 0V. Found an n channel FET (Q4830) in the backlight supply(?) that could to be blown (pictures below), not quite sure about that, but t assume that should not be relevant, because I was testing the board...
                                          08-23-2024, 06:26 PM
                                        • baglaivlad
                                          MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                                          by baglaivlad
                                          Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                                          Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                                          01-09-2024, 09:55 PM
