yihua 938d hot tweezers
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    hi guys what your thoughts on these hot tweezers
    https://www.ebay.co.uk/itm/YIHUA-938...53.m1438.l2649
    • 31196
    Re: yihua 938d hot tweezers
    if you need them a lot then they are probably o.k.
    if not then maybe......
    https://www.reichelt.com/gb/de/de/en...09-p90922.html
    • awyatt2
      • Feb 2012
      • 407
      • america
      I have the tweezers and don't use them I like their hot air station better
      • aaronmacdonald
        Mix & Match Hot Tweezers with Station
        by aaronmacdonald
        Hey guys; I have a cheap soldering station (Txinlei 8586) and was wondering if it was possible to use Aoyue hot tweezers on it.
        Digikey has a couple options for Aoyue hot tweezers available, and although you're not really "supposed to" use them on anything other than intended Aoyue stations, I was wondering if any of you have experience/knowledge and can tell me if I can safely use any of the available options on my cheap station.
        These are affordable, and the quick shipping speed (I'm about to do a digikey order anyway) makes them attractive over a Chinese...
        08-29-2022, 08:00 PM
      • Srdjan01
        IPhone 12 ProMax - Thoughts of (not so young) apprentice
        by Srdjan01
        Hi guys.
        I'm working on my first board reballing.
        It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
        Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
        I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
        03-17-2025, 02:49 AM
      • Chrissygizmo
        Yihua 968DA+ Mk3 unboxing
        by Chrissygizmo
        Hi all ,
        just a quick question
        I've just bought myself a new Yihua 968da+ mk3 , I’ve got it all together now but I don’t know what this is or & where it goes, it’s obviously nothing important judging from the size of it but I think I had the same with my last Yihua rework station but I just left it in the box that time ...
        10-03-2025, 08:58 PM
      • Peter_1402
        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
        by Peter_1402
        Hi Everyone,
        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
        1. Soldering iron works great
        2. There is a burnt mark on the hot air gun handle.
        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
        Reed switch tested ok with a magnet.
        From the above test, I can conclude...
        07-12-2025, 11:50 AM
      • redwire
        Hakko 950 SMT hot tweezers but no base or stand
        by redwire
        I got gifted a Hakko 950 SMT hot tweezers but no base or stand.
        Any suggestions for building one?
        "The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
        I don't have any of those, have a 470-2 (no RTD in) and a FX-888A.
        04-17-2025, 03:01 PM
