Hacking the Uni-T UT210E
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. The time has come for me to get my first clamp meter and I chose the fairly decently priced UT210E. I'm pleased with my overall experience with it so far - it's definitely more than enough for the light usage I'm putting it through. It's not my main meter (I have like 3), so I only wanted it for the clamp feature TBH. It's not my go-to for quick everyday measurements, though I don't see why it can't be.
    Anyway, I also read that they're pretty hackable to unlock or modify some features it doesn't come with out of the box, which is right up my alley.
    Some of you may know that I brought about this discussion in another post of mine, about measuring the current draw of power windows in my car, but didn't want to digress too far from the original topic, so I opened up a separate thread on this very topic. People have been kind enough to provide resources and even hex codes ready to go, which I might try out as I go (why not - there's some interesting stuff there), however the feature I've been interested in in a meter ever since I got my hands on one as teenager but never seem to get is a proper HOLD function. I want the meter to store the highest value it read and actively update it if I get a spike or surge for instance...you know what I mean. With every one I got so far, the HOLD button just freezes the display regardless of the value and this one is no exception. Some meters seem to get it right, but they're either very expensive or don't measure DC amps. The A and B models of this meter do have such feature for instance, but lack the DC current feature...I reckon it may be possible to implement it.
    I had a look at the datasheet for the chip inside, which is a DTM0660 and looking at the schematic on page 17, the MAX/MIN button is connected between pins 23 and 26. I doubt simply connecting them together is enough to activate the function....or is it ? I reckon the chip doesn't know what to do in that case, so would this require altering the EEPROM or something ? People talk more about unlocking more fancy features like IR communication or increasing the range, but for now I only care about small details like having a bloody MAX function Cheers guys. Thanks for the help.
    Wattevah...
    • 31259
    Re: Hacking the Uni-T UT201E
    first step is dump your eeprom.
    then i can talk you through the many options.
    btw, if you solder some thin wires in it you can try the missing buttons - it's a matrix.
    K5: hold/lamp int1, pt1.5/eeprom-sda
    K1: select(yellow) int1, pt3.5
    K6: max/min int1, pt3.7
    K2: range int0, pt3.7
    K3: rel/rs232 int0, pt1.5/eeprom-sda
    K4: Hz/duty int0, pt3.5
    int0:pin24
    int1:pin23
    pt1.5:pin19
    pt3.5:pin31
    pt3.7:pin26
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      I shall, though I'll replace the chip entirely like I always do when messing with EEPROMs so the original stays safe Probably overkill, but my buddy killed one before when he overheated it and a stubborn leg refused to let go of the PCB and broke off at the corner as if the package turned into rubber....
      Wattevah...
        • Jul 2011
        • 6070
        Do you know what meters have this chip in them ( DTM0660 )
          • 31259
          there is a big list on the russian forum.
          i think it's kazus
          • retiredcaps
            • Apr 2010
            • 9271
            Re: Hacking the Uni-T UT210E
            There is lots of info about hacking this on eevblog.
            https://www.eevblog.com/forum/testge...-uni-t-ut210e/
            --- begin sig file ---
            --- end sig file ---
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Ok, here's what I grabbed off the chip...hope it's all good
              UPDATE: just noticed the main IC is a DM1106EN....haven't looked up a datasheet yet.
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                I found something on that EEV thread which I'd like to try, which is changing the default settings from AC to DC. After a bit of struggling, not having worked with HEX too much in my life, I managed to identify what the guys were on about and I modified a copy of the original backup how I THOUGHT it should look. I only wanted to try defaulting to DC for the 2A range for now....I thought to start off small and see if I at least got it right.
                Unfortunately I had no 24c02 ICs on hand, so I tried a 256k one thinking it should still work if it's a larger capacity chip, but it didn't: when I turned it on, it displayed CAL and then random gibberish. Just to check, I soldered in the original unmodified chip and it worked, so it didn't like those extra blank bits apparently, which is different from some TVs where I've successfully done this trick before. I just got some blank 24C02s to play with, so I'll try it again tomorrow...I'm also thinking of coming up with some kind of a contraption to allow me to quickly remove and program the chips, since I WILL be doing this a lot and it's pretty cramped in there. It's right next to a crystal and just above the display, which I'm guessing won't like so many rounds of heat like that. What I'll do is chop the end of an USB extension bracket to get myself an 8 pin female connector, which I'll then solder to the pads on the board, then stick my programmer's clip in that. When I need to program, I simply swap the clip from the makeshift board connector to the programmer's connector...should work
                Wattevah...
                  • 31259
                  good, that's the newer 10,000 count one.
                    • 31259
                    bad move.
                    24c00 upto atleast 24c08 is 8bit, but at some point they switched to 16bit!
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      I seem to be having no luck so far. I'm having trouble even copying the code from the original chip to the blank ones I got. I built my little test rig which you can see below: soldered some male headers to the board which allows me to connect my programmer's clip as discussed, so I can easily go back and forth without soldering and damaging the board. It works with the original IC (meter boots up and works perfectly), but when I try flashing another IC, I only get ---- on the display along with AUTO at the bottom and a clock in the top-right....what's going on ?
                      I tried two different ICs and they both do the same thing. I tried reading the original again, but there was no difference between the codes I obtained...I'm a bit nervous that if I reprogram the original I might not be able to get it going again. I doubt it's the freak wiring job causing the issue, since the original IC works...do these 24c02 ICs have versions or something ? *disappointed*
                      It could be because of two reasons: there's something wrong with these replacement ICs, or the code wasn't grabbed correctly in the first place, so I'm writing bogus code on them. I don't know what could've gone wrong....I tried it multiple times but received the same exact code and it's not the first time I've used the programmer...
                      Wattevah...
                        • 31259
                        you need to hold the chip in reset while reading or writing it so the data isnt corrupted by activity on the serial lines.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Doesn't the programmer do that by default ? Makes me wonder how I've done similar EEPROMs for TVs in the past, since I didn't do any extra step: clip it in, program it, solder it back in (try again if it didn't work)...
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            I made another discovery: the chips I got have a C at the end - 24c02c...I found a datasheet for them and some parameters are slightly different, like the frequency for instance. The original chip doesn't have a C at the end....don't know if that's it though...
                            Wattevah...
                              • 31259
                              you arent reading them at 400KHz so the speed dont matter
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                I've had the project on hold for quite some time now because the shop's been really busy, but I really want to get it going because I need the meter. Right now its guts are all out with that adapter I made still hanging from it. Last time I messed with it, I was having trouble with the EEPROMs and couldn't figure out why it wouldn't work with a different replacement IC. My thought was that it's not entirely identical and thus something's not quite lining up properly...I've never had this issue before with ICs in TVs. I just clip them in, program them and hope for the best.
                                Wattevah...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  HA ! I managed to get it going using an EEPROM I ripped from a TV board. It's THIS thing...apparently there WERE some differences between the one I got new and these ones. I'll start messing with it soon. Right now I just quickly wrote the original code back to it just to test it.
                                  Wattevah...
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    Ok, I managed to rearrange my default startup settings and it seems to be working. Now on to adding that Max button. Looks good so far I'm not sure whether to solder the chip back in permanently or to continue to use the hookup I made provided further adjustments may be necessary for it to work
                                    Wattevah...
                                      • 31259
                                      good progress.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        About time eh ?
                                        Wattevah...
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • DrDos
                                          Unit runs but no speaker output kenwood KR-6030
                                          by DrDos
                                          I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                          09-14-2025, 09:57 PM
