Hacking the Uni-T UT210E
  • bobale
    • Aug 2018
    • 14
    • Serbia
    #41
    Re: Hacking the Uni-T UT210E
    I haven't even gotten to oppening it, let alone hacking it. But it looks like it is going to stay without MIN/MAX function. For the price it is good anyway.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #42
      Originally posted by stj
      to use min/max on a meter you first need to enable manual ranging - not autoranging.
      maybe that's the issue?
      That seems to happen automatically on another Uni-T I've got that has MIN/MAX out of the box. I'm not sure the same happens if it's not meant to have the MIN/MAX feature and you're trying to patch the button in.
      Wattevah...
        • 31198
        if i had a spare meter with that chip i'd experiment with adding all the buttons, but i gave my spare aneng to a friend.
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • ngml
          Repair of an LG split AC system indoor unit PCB
          by ngml
          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
          This indicates an error in the communication between the outdoor and the indoor unit.
          The outdoor unit is fine, so the problem is the indoor PCB.
          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
          Does anybody have the schematics of this board,...
          02-01-2025, 12:55 PM
          12-31-2023, 06:04 AM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
        • DrDos
          Unit runs but no speaker output kenwood KR-6030
          by DrDos
          I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
          09-14-2025, 09:57 PM
