What solder would you recommend for this?
  • jazzie366
    • May 2016
    • 304
    Going to be soldering a joint that needs to flow 80-100A at 12v. Is standard leaded solder good for this?
    Popcorn.
    • 31196
    Re: What solder would you recommend for this?
    upload a foto of it.
    any solder will do, but lead-free is stronger.
    i'm more interested in what is connected to what that can handle that current!
    • petehall347
      • Jan 2015
      • 4438
      regular 60/40 will do it ..its what i use in starters and alternators .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        You need to make sure the copper or the conductor is conducting the current and not the solder like always. As long as this is true, regular solder is fine. If you need the solder to matter, then either you're doing it wrong, or what you really need is welding.
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          100A at 12 volts ? .. Better use cable lugs , nuts and bolts .
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Yeah, speaking of that, it's not "what solder would you recommend for this"... it's "what solder iron would you recommend for this"
            I think you'd need a torch to get anywhere with that much thermal mass to solder.
            • petehall347
              • Jan 2015
              • 4438
              i use 100 watt iron for such jobs ..takes 20 minutes to heat up properly
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • ktmmotocross
                recommend good solder wick on aliexpress
                by ktmmotocross
                I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
                02-08-2024, 12:48 AM
              • corrize
                Best way to solder LVDS connector for beginner (and qfn) ?
                by corrize
                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                See the test :
                https://youtu.be/bNAzC-EvqHs?t=1767
                With hot air from bellow the board, that's...
                03-09-2023, 02:57 AM
              • sircastor
                Solder not reflowing - what am I doing wrong?
                by sircastor
                I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                03-03-2024, 02:44 AM
              • pixelcap
                Pioneer Plasma 111FD To Solder or Not to Solder.
                by pixelcap
                Hello out there in Badcap land.
                I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
                are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
                Thank you
                Pixelcap...
                03-08-2025, 07:10 PM
