Transistortester
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Transistortester
    Curious of those who own one of these things...
    I broke up the two as I'm curious of those who have ESR testing capability within it...
    Me I'm stuck with a crappy DMM hFE tester right now that I don't even use and just use diode check...
    [EDIT]
    Apologies for the pejorative, especially since it wasn't invented by the Chinese. If you built your own using the German sources, please also indicate so too...
    13
    Yes, transistor tester that can test resistor ESR, inductance
    0%
    8
    Yes, transistor tester that can test just bjt/mosfet/diode/etc.
    0%
    2
    Multimeter with hFE checker
    0%
    3
    Diode Checker or Ohmmeter only
    0%
    0
    No way to test transistors...
    0%
    0
    The poll is expired.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Transistortester
    ESR feature in my Chinese tester. https://www.aliexpress.com/item/2017...777488801.html
    Not far off what my Peak ERS70 displays and that cost 7x the price and only does capacitance and ESR.
    I also have the Peak DCA55 which is a semiconductor component tester.
      • 31196
      https://www.badcaps.net/forum/showthread.php?t=50720
      is my answer
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I've been trying to get by without one...
        wonder if it's time to get one or build one.
        I have a ton of HD44780's that I really want to utilize for something, won't be as pretty but at least I'll use one of these 16x2's...
        I do have a Sencore LC meter and a homemade analog ESR meter, so this thing theoretically can do both of these things. I just need to make it a bit more sturdy than a bare PCB.
          • 31196
          it can do a lot more, if you fit a 16MHz crystal it can even read the frequency of crystals and resonators upto about 10MHz,
          and it can decode I.R. bitstreams from remote controls!!!
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Actually it can't do leakage test at rated voltage that the Sencore does, so it's not going to be redundant...
            Hmm. Unfortunately it's the 20+ MHz crystals that I have the most problems with as these don't like being breadboard tested...
              • 31196
              you could make a bit of stripboard with a socket, a couple of caps and an ic to get it running.
              then just poke it with a frequency counter.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Exactly, a feature that the transistortester doesn't have
                Then again transistortester does have a frequency counter...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Maybe the next poll:
                  Do you have a curve tracer?
                  1 Yes
                  2 No, but intent to buy one
                  3 No, no intent to buy one
                  4 Why would I need to trace pr0n curves?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Wow, seems a lot of you all have them or nobody is admitting to not having one...
                    Anyone DIY and assembled ones own using the guides?
                    Yeah probably not worth it to have a board fabricated, but I was thinking about fabricating my own board as well...
                    I just worry about the calibration with resistors, as I'll probably be using 5% resistors. I might have to cherry pick them...
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      I Have most of them , but never used them , maybe since the damper diodes invention .. Yes , due to the infinite possibilities and diversity of Transistors specs , i always preferred the old six ways manual check . More effective and let you catch by experience , a base from an Emitter or collector , or if it is an irregular transistor .
                      Nowadays , i come to neglect a Multi at any cost . A high professional tool for each electronic component is a luxury one must have .
                        Component tester which one is worth the money from it capability to test and identify
                        I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
                        Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
                        There are so many versions of this type of device and I do not have enough information to make a good decision at this point
                        When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (...
                        06-30-2022, 08:23 PM
                      • Lifeisfun
                        Trying to troubleshoot DDR4 SODIMM slot with slot tester
                        by Lifeisfun
                        Hi folks!
                        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                        Eventually I discovered that it was related to moving the laptop.
                        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                        I removed the board got one of those memory slot testers...
                        06-04-2025, 02:26 PM
                      • valente222
                        help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                        by valente222
                        Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                        05-12-2025, 03:42 PM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
                        FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                        https://www.ebay.com/itm/405035016711
                        I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                        I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                        04-13-2025, 08:17 PM
