New Software Achi LY by PSOFT
    Originally posted by jasko_jacker View Post
    Re: New Software Achi LY by PSOFT
    The Psof software was created to obtain that the real temperatures are as close as possible to the solder profile when using a machine with both top heaters with ceramic IR technology. In other cases it is not so necessary
    This is a profile I use to solder medium bga as hm170, etc with an IR-pro modified.
    i have your profile and i have one probleme i dont now whi not finish the profile how i have 2xx finish and is not the finish of curve ... i dont understand this i go make one photo if any here
    Thankksssss
      How do i change language in the PSOFT software?
        Never mind im dumb
          i have change the data bit to 7 and it work, just a quick question it normal that the Com Open keep flashing
          Changing the data bit to 7 worked for me. Just a heads up, the "Com Open" in the bottom left hand will flash green when it's connected to your PC.
            To get this setup working for me on a windows 11 machine, I had to run a VM with Win7. After installing the USB driver from the CD, and PSoft, I then had to change both the com port settings and PSoft settings as Psoft was set to 19200 baud, but my machine handles 9600 better. On the windows side, I had to set data bit to 7, Baud to 9600, and parity to even, as well as select COM1.
            it works flawlessly in the 7 environment, but my windows 10 machine refuses to see anything, and windows 11 actually shows an error for the driver, claiming it is not compatible (though it connects to the 7 VM on the 11 machine just fine!) Thank you for the files and breadcrumbs!! I hope someone else finds this info useful!
              Can you please give me your opinion on the program
              By the way, I didn't think that this software would be used all over the world
              Best wishes for the new year 2025
                It depends on which chips you solder and with which configuration of the soldering machine. This software allows you to use the pc410 controller together with the c100 with a more user friendly configuration. If you have a soldering station with these two controllers you can benefit from it above all because you have a complete view of the profile. Obviously when setting the profile you must take into account the real power of the heaters because if you ask for too much the curve in relation to the time is not respected, this especially if you do not use air but diffuse infrared. The use of increasingly thinner bga chips and increasingly subject to distortion (rectangular cpus) requires completely different and much more precise and sophisticated soldering machines in the management of pick and place, these machines have dedicated software as you well know and are largely automated. Personally I no longer solder bga components except for some pch for various reasons.
                  I actually wrote this program 10 years ago, but it can always be modified to fit today's needs. Any ideas?
                    Hello and thank you for your contribution, I really appreciate the time you took to create this software.
                    I think, for me, the ability to control two PC410 controllers together (select profiles for both and run at same time, plot graphs for internal and external thermocouple of both also) would be a great improvement.
                    Maybe this is a niche use case because I know many stations only have one PC410 but my Honton station uses two PC410 modules to control top and bottom hot air, plus the usual REX-C100 for the plates.
                    From factory only the top PC410 had serial comms but I swapped the bottom one for a serial-enabled unit too and added another db9 connector.
                    I think this would be a great way to give more control over units with a similar configuration and make them closer or maybe even better than some of the newer units that use all-in-one control units (and usually some large screen) instead of the PC410s
                      Please revamp this to work better on Windows 10 /11 Also a better description of the functions would be great. There is no other software out there that controls these machines this well!
