Using my CH341A.
  • philbo_baggins
    • Feb 2020
    Re: Using my CH341A.
    Originally posted by newguy90
    I successfully read and wrote in circuit the 93c56 and 93A56 EEPROM's. I didn't have to power on the circuit, I just used the SOIC8 test clip with the interface
    that I built!
    I could not use the CH341a though, so I have no use for that interface... at least for now.
    newguy90, I am working through a similar problem that you did, do you mind doing a quick writeup of what you did to get this to work? It sounds like you didn't use the CH341 usb programmer/software, but connected directly to the chip through a serial port? I wasn't sure where the drawing you redlined came from, or if that was the final version that you used. Thanks.
    • R_J
      • Jun 2012
      • 9535
      Check this site, it has some information: https://hw-server.com/serial-eeprom-programmer
      or do a google search for "93c56 programmer"
      Also see here http://www.lancos.com/prog.html for ponyprog
        • 30978
        if you dont want to build something,
        another option is this!
        i just recieved one yesterday - very capable for the price!
        http://www.xgecu.com/EN/TL866_main.html
        http://www.aliexpress.com/item/32992209964.html
        (and it can work in Linux as well as windows)
        • beekerc69
          • Oct 2021
          can you share exactly how you got the 3.3v working?
          what pins you tied together or what jumper settings you used?
            • 30978
            3.3v on what adapter?
            • digby1951
              • Jan 2017
              • 36
              • uk
              #46
              https://www.youtube.com/watch?v=Hwnz...nnel=AdamantIT
              • remaker
                • Nov 2008
                • 5
                #47
                I recently had a similar problem and posted a photo of the Chinese jumpers to Chinese Stack Exhange
                https://chinese.stackexchange.com/q/59967/43628
                Basically, jumper, 1-2 means “programmer.” That activates the programming line (ACT#) on the chip. Jumpers 2–3 translate to “brush machine,” while “brush machine” idiomatically means “flash programmer,” what it's really doing is disconnecting the programming line and setting up the system to use the USB to RS-232 as pass-through at TTL level. It seems that all USB the serial converters are called, brush machines, or flash programmers, since that is the most common use of the converter these days.
                This particular model does not let you adjust 3.3V and 5V output. It seems to work fine on 3.3V parts, but a lot of people are uncomfortable with the electronic design. There are a number of sites that talk about how to physically modify the device to get through 3.3V, but it worked fine for me on 3.3V parts.
                • diamon
                  • 107
                  • Netherlands
                  #48
                  I have ordered also this device from Ali, (this one: click) and after connecting it to the USB port on my laptop, the voltage on data pin mentioned in the YouTube posting from AdamantIT is not 5V but the 3.2V from the voltage regulator (no chip has been placed into to socket).
                  It seems they have fixed this 5V issue on the data pin. The main chip is running on the 3.2V and not on 5V.
