Using my CH341A.
  • philbo_baggins
    • Feb 2020
    Re: Using my CH341A.
    Originally posted by newguy90
    I successfully read and wrote in circuit the 93c56 and 93A56 EEPROM's. I didn't have to power on the circuit, I just used the SOIC8 test clip with the interface
    that I built!
    I could not use the CH341a though, so I have no use for that interface... at least for now.
    newguy90, I am working through a similar problem that you did, do you mind doing a quick writeup of what you did to get this to work? It sounds like you didn't use the CH341 usb programmer/software, but connected directly to the chip through a serial port? I wasn't sure where the drawing you redlined came from, or if that was the final version that you used. Thanks.
    • R_J
      • 9633
      Check this site, it has some information: https://hw-server.com/serial-eeprom-programmer
      or do a google search for "93c56 programmer"
      Also see here http://www.lancos.com/prog.html for ponyprog
        • 31304
        if you dont want to build something,
        another option is this!
        i just recieved one yesterday - very capable for the price!
        http://www.xgecu.com/EN/TL866_main.html
        http://www.aliexpress.com/item/32992209964.html
        (and it can work in Linux as well as windows)
        • beekerc69
          • Oct 2021
          can you share exactly how you got the 3.3v working?
          what pins you tied together or what jumper settings you used?
            • 31304
            3.3v on what adapter?
            • digby1951
              • Jan 2017
              • 36
              #46
              https://www.youtube.com/watch?v=Hwnz...nnel=AdamantIT
              • remaker
                • Nov 2008
                • 5
                #47
                I recently had a similar problem and posted a photo of the Chinese jumpers to Chinese Stack Exhange
                https://chinese.stackexchange.com/q/59967/43628
                Basically, jumper, 1-2 means “programmer.” That activates the programming line (ACT#) on the chip. Jumpers 2–3 translate to “brush machine,” while “brush machine” idiomatically means “flash programmer,” what it's really doing is disconnecting the programming line and setting up the system to use the USB to RS-232 as pass-through at TTL level. It seems that all USB the serial converters are called, brush machines, or flash programmers, since that is the most common use of the converter these days.
                This particular model does not let you adjust 3.3V and 5V output. It seems to work fine on 3.3V parts, but a lot of people are uncomfortable with the electronic design. There are a number of sites that talk about how to physically modify the device to get through 3.3V, but it worked fine for me on 3.3V parts.
                • diamon
                  • 107
                  • Netherlands
                  #48
                  I have ordered also this device from Ali, (this one: click) and after connecting it to the USB port on my laptop, the voltage on data pin mentioned in the YouTube posting from AdamantIT is not 5V but the 3.2V from the voltage regulator (no chip has been placed into to socket).
                  It seems they have fixed this 5V issue on the data pin. The main chip is running on the 3.2V and not on 5V.
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • DynaxSC
                    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                    by DynaxSC
                    Hi
                    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                    08-04-2025, 12:20 PM
                  • pengamat_hebat
                    Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                    by pengamat_hebat
                    I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                    Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                    However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                    I also tried applying 3.3V to pin 3, but it still didn't work.
                    I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                    03-25-2025, 04:13 AM
                    How to add chip support to NeoProgrammer software for the CH341A Programmer
                    by SMDFlea
                    Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                    and once you do find them there`s a few crucial steps missing.
                    Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                    Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                    After adding the chip save the xml file and copy it to the root directory of the...
                    05-26-2024, 07:15 AM
                  • BMCappelletti
                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                    by BMCappelletti
                    Long story short:
                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                    - gave the computer to his son a couple years later
                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                    (seems like the story was not that short)
                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                    01-08-2025, 07:27 PM
