Using my CH341A.
  • newguy90
    • Sep 2019
    • 12
    Re: Using my CH341A.
    Originally posted by R_J
    I found this information on using a CH341a and 93LC86 microwire https://freesoft.dev/program/171504972
    93C56b is microwire
    thank you R_J. I followed the link you gave me, but the info found there it doesn't help me... As far as I know the 93C56 EEPROM of my car has a bit organization of 128x16 bits, not 256x8 bits. The project from the link you sent me has a limitation in this respect (only 8-bit data organization (ORG pin Low) supported).
      • 31304
      maybe you should look at PONY PROG,
      • newguy90
        • Sep 2019
        • 12
        I've started looking yesterday on the Pony prog 2000 website. As far as I see, I need to build the Base board (SI Prog) + the 93cxx adapter (Microwire eeprom adapter) using the schematics provided on that website. Is that right?
        I want to build those, but as simple as it can be... So what would be the simplest schematic that I should build? Do I really need the extra power source? And if I do, can I use the 5V rail from the PC's PSU for this purpose instead of the one presented on the Base board schematics ?
          • 31304
          you only need what will be used, so really just 5v
          • newguy90
            • Sep 2019
            • 12
            I inverted in the image below the colors of the components which I want to remove from the Base Board interface, and I retraced with red color the connections that I think it needs to be done in the circuit. Would it work this way?
              • 31304
              you need the voltage regulator, the serial port outputs 12v.
              well it should but modern stuff is closer to 9v but it will still fry your chip!
                • 31304
                or get 5v from a usb port.
                • newguy90
                  • Sep 2019
                  • 12
                  #28
                  I see... If 12 V is the voltage from those serial pins, then I think I definitely need a 5v regulator... But if I don't have the 5 V regulator (LM2936z-5), what else can I do using other common electronic parts that are easily available? Or can I just eliminate the 1N4148 (D1, D2 and D3) along with the regulator and the other capacitors (C3, C4 and C12) and just use a 5V from USB or from an 5V PSU rail to drive the pin 1 (that's VCC, + PE + ORG of the 93cxx EEPROM ) ?
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    #29
                    You can salvage an LM7805 from any common domestic appliance, TO-220 easy to spot.
                    You can also find 5V regulators in 3.5" hard disks boards.
                    • megaraider
                      • Jul 2015
                      • 307
                      • Portugal
                      #30
                      Pay attention to the EEPROM pin layout:
                      93C56B-I/MS standard pin layout
                      vs.
                      93C56BX-I/SN rotated pin layout
                        • 31304
                        just use 5v from usb or ps2 connectors.
                        • mcnc
                          • Sep 2019
                          • Serbia
                          #32
                          Does this flasher supports 1.8v chips?
                            • 31304
                            no, it supports 5v chips, it's not intended for large chips like serial-flash
                            • el panke
                              • May 2019
                              • 78
                              • argentina
                              #34
                              this is the last ver of the software
                              maybe could help some1
                              • newguy90
                                • Sep 2019
                                • 12
                                #35
                                I uploaded your archive to virusTotal to verify it and some AV engines have detected trojans. ( CAT-QuickHeal : Trojan.IGENERIC /// MaxSecure: Trojan.Malware.74274250.susgen // SecureAge APEX: Malicious//
                                SentinelOne (Static ML): DFI - Suspicious PE//Trapmine: Malicious.high.ml.score)
                                Are they just false positives, or what?
                                  • 31304
                                  hard to know, the hacked versions are loaded into some type of "virtual shell" so the software thinks it's on a different machine.
                                  you could hide anything in that.
                                  it still wont do 93 series.
                                  • newguy90
                                    • Sep 2019
                                    • 12
                                    #37
                                    Well, I did it! I built myself a Pony Prog adapter for the programming of 93cxx EEProms using PonyProg and the result is: SUCCESS! I managed to write a 93c46 EEPROM that I bought from a local shop for testing purposes.
                                    Next: I will try to read/write the 93c56 in circuit. Keep ur fingers crossed for me, pls !
                                    • el panke
                                      • May 2019
                                      • 78
                                      • argentina
                                      #38
                                      just false positives i guess, never had a problem using it
                                        • 31304
                                        to read in circuit,
                                        you have to power the circuit, and make sure nothing else try's to read the eeprom when you do.
                                        infact if your doing that, DONT connect the 5v supply pin to the eeprom.
                                        just the ground and clock/data etc.
                                        • newguy90
                                          • Sep 2019
                                          • 12
                                          #40
                                          I successfully read and wrote in circuit the 93c56 and 93A56 EEPROM's. I didn't have to power on the circuit, I just used the SOIC8 test clip with the interface
                                          that I built!
                                          I could not use the CH341a though, so I have no use for that interface... at least for now.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • DynaxSC
                                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                            by DynaxSC
                                            Hi
                                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                            08-04-2025, 12:20 PM
                                          • pengamat_hebat
                                            Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                                            by pengamat_hebat
                                            I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                                            Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                                            However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                                            I also tried applying 3.3V to pin 3, but it still didn't work.
                                            I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                                            03-25-2025, 04:13 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
