Recommend me an ESR METER 20-30$
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Hello.Im looking to buy an ESR meter to test the capacitors in circuit.
    Im willing to spend about 20-50$. Can someone recommend me a good ESR meter on Ebay or Aliexpress?
    Thanks in advance.
    • 31086
    Re: Recommend me an ESR METER 20-30$
    search a little - you will see that in-circuit testing is not reliable.
    • ducky29
      • Dec 2015
      • 370
      • Europe
      I have been looking through several models but almost all of them are the same, just different cases, thats why I was trying to find a little help here.
      Why testing in circuit is not reliable?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        I find this one interesting, for it's 100KHz testing frequency.
        But I don't own one and I don't think I've seen one on Badcaps before either.
        As STJ said, testing in circuit is iffy at best, takes allot of prior knowledge for the specific board under test.
        http://www.ebay.com/itm/MESR100-V2-A...-/321906634429
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • petehall347
          anyone recommend an earth leakage clamp meter ?
          by petehall347
          have been looking at earth leakage clamp meters and its like a minefield out there . i wondered if anyone here had bought one that actually works properly ?...
          04-17-2024, 01:31 PM
          12-31-2023, 06:04 AM
        • jorpec
          by jorpec
          Hi
          Thnaks
          01-23-2023, 10:37 AM
          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
          12-14-2023, 07:45 PM
