How To Make Full Use Of Your ESR Meter
Re: How To Make Full Use Of Your ESR Meter
Thanks for the reference.
This site is a heavily advertising-supported type. He has browser redirectors, etc, that pop up similar to the adult sites.
You might consider using Sandboxie when browsing sites like this.
www.sandboxie.com -
dunno, i didn't click on any ads there...
about sandbox; have you tried it on some users that easily get infected(ie 90% of all people..hehe)?
would be good to know for one such person(better to say family) where clean install of xp last a godo one day...after that no amount pof cleaning can get it to original(fast) condition...Comment
I put Sandboxie in both client sites, and my own systems. I have my wife trained to use it for anything dangerous, i.e. MySpace, Facebook, etc.
All my systems are built from FDISK/FORMAT with an unattended install CD slipstreamed with DriverPacks mass storage drivers. I have multiple CDs.. both Retail and OEM, for the various XP versions, so I can rebuild using the customer's existing serial number.
I build all systems in stages, then GHOST the system. It gets very ugly when all that work is lost due to a crappy HP print driver, etc, and there is no image backup. Imaging is the only way to return to a 100% clean system.
I partition into SYSTEM and DATA volumes. Systems that have Diag or Restore partitions (Dell, etc), I also image the entire partitioned disk with System and Data present, but empty. That way I have a disk image of the factory partitions for when the disk dies.
I come back a year or two later for a trashed system and restore it from the image. I do all the Windows updates, then update the image for the next time. It is time consuming, but I charge by the hour.Comment
Sorry, that went way off-topic.
I'm looking forward to building and using my new ESR kit that was recommended here. I have a Gateway/Intel board that I recapped that is DOA. One of the Rubycons is suspected as being bad, or reversed. Hopefully the ESR meter will show the way.
Q: can the meter be used in-circuit, or do I have to unsolder all those nice Rubycon caps?
I plan on using the ESR meter to verify every new cap BEFORE it goes into the board. Lesson learned on my part.Comment
yeah it can be used in circuit. works fine.Comment
Works fine as long as caps aren't in parallel with other caps.
.Mann-Made Global Warming.
- Dr Seuss
In-circuit use is for typical VRM caps.
Lesson learned: measure each cap before installing in the board.
I am using all MCZ, but the Gateway board went DOA after recapping. VRM won't turn on, and just sings to me. I posted in depth in a different thread, etc, but can't pursue it further until the rainy season arrives and I have free time. I figure I have a reverse labeled cap, defective cap, etc.
Hopefully the ESR meter will pick it out without having to remove all those new Rubycons.Comment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by piernovJust archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
May complete this post at a later date with more details.
Basically issue is a combination of thermal dissipation of the chip with hotspot,... -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... - Loading...
