Ohms Law
  • chipper
    • Aug 2008
    • 95
    Ohms Law
    Is there a good quality link somewhere that spells out all the colors on resistors ,(ring values) as according to ohm's law? I haven't looked yet but I know there is one , and it belongs somewhere on badcaps for references.
    There is also a jingle that goes with ohm's law , and it relates to remembering , , remembering ohm's law :
    better / be / right / or / your / great / big / venture /goes /wrong
    silver = + or - 5
    gold = + or - 10
    better = blue (?? what order)
    be = black(?? what order)
    right = red
    or = orange
    your = yellow
    great = green
    big = brown (?? what order)
    venture = violet
    goes = gray
    wrong = white
    something like this ...
  • chipper
    • Aug 2008
    • 95
    Re: Ohms Law
    Ok , here it is :
    http://s.maxthon.com/?q=resistor+value+chart
    • gdement
      • Jan 2007
      • 690
      Re: Ohms Law
      whenever I try reading those colors, I get them wrong. I can't tell the difference between some of them.
      • stevo1210
        • Oct 2006
        • 4156
        Re: Ohms Law
        I saw that the thread was titled ohms law.... I thought this was going to be a physics lesson in electricity.
        By the way, I failed an exam on ohms law not that long ago... and I learnt one new thing.... a graph for resistance which has a very slight bend also satisfies ohms law.
        Anyway, I have issues reading those colour bands on the resistors as well.
        • chipper
          • Aug 2008
          • 95
          Re: Ohms Law
          I am trying to form a thread where we can all share experiences and theories on how to test these "rogue" type resistors that are perhaps old or unreadable. Best case senario is to form a method of meter testing , and apply it.
          I am working on setting up some very simple metering devices that will positively identify or suggest bad caps or resistors , just for starters. But I want to have all of the tests revolve around a metering device that will show the exact results , where side by side comparisons can be performed , instead of guessed at or summized.
          I guess if a resistor is unreadable , it's not a good idea to install it , if it's already on the board though , and obviously needs replacing , ohm's law is specifically important.
          I hope this thread grows into a place where "resistors" and ohm's law can be discussed and implemented. Not to mention that some resistors are actually fuses.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Ohms Law
            I've come across resistors that were marked wrong in the first place so I always check with a meter too.
            Mann-Made Global Warming.
            - Dr Seuss
            • Super Nade
              • Jun 2006
              • 294
              Re: Ohms Law
              Always always check with a meter!
              Q6700 @ 3.6 GHz
              Zippy GSM-6600P
              Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
              Abit IP35Pro
              ATi HD4870
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Re: Ohms Law
                No. This is the correct version:
                Bad | Boys | Rape |Our | Young | Girls | But | Violet | Gives | Willingly
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Re: Ohms Law
                  Moving on here is a good one to get resistor values from the color bands just plug them in and you get a value and tolerance.
                  http://www.dannyg.com/examples/res2/resistor.htm
                  This is only for 5 band resistors. I do it in my head but this works too.
                  Sometimes especially on 1% tolerance resistors I have a problem with the colors too due to their blue body.
                  My grandfather was colorblind luckily I didn't inherit that but I still get confused from time to time .
                  On a related note I seem to remember some guy online claiming to be an electronics tech selling info on how to tell the value of a burnt resistor.
                  Is this even possible?
                  Usually I'd hope that a copy of the circuit was nearby and use the resistor value from there. Like the HV circuits on a LCD inverter or the resistors on a CRT projection TV supplying the STK ICs. Barring that time to find a service manual.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: Ohms Law
                    that is the version i learned in the 70's
                    doubt you will hear that one in any school in this age of political correctness bullshit.
                    • arneson
                      • Sep 2005
                      • 1267
                      Re: Ohms Law
                      That's the one I had as well.
                      I have snapped a burnt resister in half,
                      measured whatever was left of it,
                      doubled that and went with it.
                      Carbon or wire wound, but only in non critacal applications.
                      Remember also that a resistor sub box can be your friend as can a small pot, when your unsure or designing stuff.
                      Jim
                      • chipper
                        • Aug 2008
                        • 95
                        Re: Ohms Law
                        It's all the same according to some left wing politically "appalled" types , but in the end they realize they are only at "A" in the dictionary , while they have been trying to cover some kind of unknown spectrum , in dismay.
                        When you tell them that you will hear some really nasty stuff , it's fun
                        • chipper
                          • Aug 2008
                          • 95
                          Re: Ohms Law
                          Yeah , 000ohms + - ? = 0
                          I have some electrical tape and some bits of hard flexible wire that I wanna test out on a rheostat controlled power supply. Please put on your safety visor prior to the application of voltage. ( attached to an infinity heatsink of course)
                          Usually , if I try to meter a resistor , and it doesn't show anything , I get a bigger power supply and try it till it gets really hot.
                          Damn , that was a "jumper" I just measured.
                          • narf
                            Epson EB-U42 projector / Caps with 0.7 ohms ?!
                            by narf
                            hi all,
                            first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                            i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                            what i've found so far:
                            - the PSU does its job and supplies 12V to the mainboard via the connector.
                            - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                            - not far away, there's the first cap with a resistance of 0.7 ohms....
                            07-02-2024, 03:53 PM
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • gica69
                            Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                            by gica69
                            I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                            Resistor shows orange range silver gold and green lines.
                            Thanks in adv...
                            07-21-2025, 09:49 PM
                          • Sephir0th
                            DELL XPS 15 9560 - No VCore, Power Off after few seconds
                            by Sephir0th
                            Hello Community,
                            i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
                            It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
                            Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
                            I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
                            05-09-2021, 11:22 AM
                          • ianbak
                            Dell Latitude 7290 Power Cycling
                            by ianbak
                            I have a Dell Latitude 7290 that power cycles instead of turning on. The circuit board is an LA-F311P
                            I have systematically checked pretty much every internal voltage, and they all seem to be present except for CPU Vcc_Core, which doesn't turn on.
                            The impedence the Vcc_Core coils is 8.3 Ohms, though, which seems reasonable.
                            Vcc_SA does get enabled, and reads 1.05V. This is driven by the same power controller IC as Vcc_Core, so I am assuming that that is good.
                            There is no Vcc_GT, but I have read that that can be normal as it only turns on when GPU...
                            07-14-2025, 11:06 AM
