DELL XPS 15 9560 - No VCore, Power Off after few seconds
  • Sephir0th
    • Oct 2020
    • 1282
    Hello Community,
    i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
    It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
    Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
    I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare some Things (measurements below). I have Schematics too, but unfortunately It's Very hard to use it because of Missing Board markings. For this reason i wasn't able to measure some Logic Signals so far. Actually i have this Overview:
    Coil (Rail-Name) Voltage non-working Board / Résistance to GND non-working / working board
    PR300 (+PWR_SRC_AC) 19.9V / O.L. / O.L.
    PL302 (B+) 13.6V / O.L. / O.L.
    PL400 (+3VALWP) 3.389V / O.L. / O.L.
    PL401 (+5VALWP) 5.179V / O.L. / O.L.
    PL501 (+1VALWP) 1.014V / 9.3 Ohms / 82.9 Ohms (!)
    PL600 (+1.2V_DDR) 1.191V / 140 Ohms / 144 Ohms
    PL701 (+1.35VSDGPU) 1.381V / 80 Ohms / 280Ohms (!)
    PL801 (+VCCIO) 0.972V / 56 Ohms / 24 Ohms
    PL901 (+1.05VSDGPU) 0V / 360 Ohms / 217 Ohms
    PL1002 (+GPU_CORE) 0V / 1.7 Ohms / 2.0 Ohms
    PL1200 (+VCC_CORE) 0V 4.5 Ohms / 1.9 Ohms
    PL1300 (+VCC_GT) 0V 7.6 Ohms / 4.0 Ohms
    PL1306 (+VCC_SA) 1.068V 26 Ohms / 10 Ohms
    PL1500 ( unknown ) 0V 79 Ohms / 55 Ohms (0.8V at working Board)
    My observations so far:
    After Plugging the charger it Starts itself and i have only +5VALWP, +3VALWP, +1VALWP, +1.2V_DDR, +1.35VSDGPU, +VCCIO and +VCC_SA present. Everything Else isn't Coming Up at all. After a few Seconds i lost everything except the ALWP Voltages. If i repeat Pressing the Power Button, i get the lost voltages Back, but again Just for a few Seconds. The Enables e.g. RUN_ON_EC, VR_ENABLE going Low causing losing +VS Voltages.
    I can't find the reason for the Low Résistance of +1VALWP. I've already Opened some Jumper and removed some ICs from this Rail but it Changed nothing so i decided to Put everything back. The Rail draws 0.12 Amps when injecting, nothing getting hot or even warm.
    Also i Wonder whether the Low Résistance at +1.35VSDGPU could be fine compared to the working Board. When i inject Here, 1.37 Amps are drawn and the GPU is getting warm after a while.
    When injecting on 3.3VALW-Rail, there are 0.06 Amps drawn for about 10 Seconds, then Only 0.02 Amps drawn. Nothing getting hot or even warm.
    I was able to check some signals (while the 7 Seconds, the Board is on): RSMRST# high, RTCRST# high, PLTRST# low, but resistance is in KiloOhms of every Rail.
    PGOOD signals:
    3.3V/5V-Controller OK
    1V-Controller MISSING, but also missing at working board
    RAM-Controller MISSING, but also missing at working board
    1.35VSDGPU OK
    VCCIO MISSING, but also missing at working board
    CPU-Controller OK, but ---> ALERT# low(!), so i have problem with "SVID". Actually i think about dead CPU, bevause SVID Clock and Data comes more or less directly from CPU...
    I compared the whole VRM-Controller and the Power stages with the working Board and didn't find anything suspicious. Only some little differences in Resistances, but they could easily explained because of the different CPU (i5 instead of i7) soldered there. However, i already ordered the parts for the VRM-Circuit and also the MEC5085-LZY.
    Actually i'm Not Sure where to proceed or whether it makes any Sense to proceed in General because of the low resistances i found. Hopefully Someone Here has experience with an issue Like this and can move me in the right direction. Otherwise i would Start replacing the components at VRM Circuit with "Fingers crossed".
    Note: there are some small differences, but the Schematics fits to.. let's say 95% regarding what i have checked so far...
    FairRepair on YouTube
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: DELL XPS 15 9560 - No VCore, Power Off after few seconds
    +VCCST and +VCCSTG?
    • Sephir0th
      • Oct 2020
      • 1282
      +VCCSTG comes Up with 1.008V and measures 282 Ohms to ground.
      +VCCST comes Up with 1.019V and measures around 400 Ohms to ground.
      The behaviour is like the other VS-rails. Came up for Just a few Seconds.
      Bad News, right?
      • Sephir0th
        • Oct 2020
        • 1282
        I have to correct my +VCCST measurement:
        1.006V for a few seconds and exactly 365 Ohms to ground
        • Sephir0th
          • Oct 2020
          • 1282
          Hello again!
          with the Boardview from >> HERE << and the Schematics of LA-G341P i was (hopefully) able to point out exactly what is missing.
          It's just PCH_PLTRST# staying low (0.000V) although PCH_PWROK and IMVP_VR_PG coming out before. Don't sure whether this makes a difference but DDR4_DRAMRST# also staying low (0.060V).
          UH7 should be fine. Don't see the point to replace it.
          PCH is gone, isn't it?
          • laptopuri
            • Mar 2014
            • Romania
            Hy Iam from Romania and have xps 9550 at wich VSDGPU 1.35V dosn't apear . Did you solve your 9560 ?
            https://************/threads/xps-15-...a-c361p.19533/
            Here are more docu . thanks
            • Francisco.s
              CPU vcore missing in HP workstation Z2 Mini 4G
              by Francisco.s
              Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
              The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
              It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
              Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
              The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
              I wonder which circuit generates this enable...
              04-22-2024, 12:35 PM
            • T4H
              RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
              by T4H
              I have an RTX 2080 ti (Zotac - triple fan) with no video output.
              So far I have measured the following:
              • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
              • 12V power rail present
              • 3.3V power rail present
              • 5V power rail present
              • 1.8V power rail present
              • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
              • Vmem power rail missing --> Not there because Vcore power rail is missing.
              Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
              Source: https://www.techp...
              08-19-2023, 08:14 AM
            • karlp028
              MSI Z390-A PRO missing VCORE voltages
              by karlp028
              I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
              06-23-2025, 01:25 AM
            • brusli009
              Z170 Pro Gaming missing Vcore after cleaning
              by brusli009
              I bought it used and was filled with dust, but was working fine, took the heatsinks off and gave it a quick clean with ipa and a soft brush.
              The next day it starts but the vcore is missing, also the qled dont light up, from what ive seen on the boardview (posted on the forum) i think im missing the vcore enable, but not sure. Also if the 8pin cpu is removed when the board is started,it dosent do anything, feels like the board dosent know that its connected.
              Maybe someone has some ideeas or something.
              10-10-2023, 09:37 AM
            • chbalnuweit
              HP 17-cn0234ng - RAM and VCORE voltage missing
              by chbalnuweit
              I got an HP 17-cn0234ng and I am hitting a wall diagnosing it.
              When I first got it, it wouldnt turn on at all and no lights were active.
              I found a shorted capacitor on the 3.3V powerrail near the lid sensor. Once I removed the shorted capacitor, the power and charging light on the DC connector started working and the Laptop reacted to the powerbutton.
              When I press the powerbutton, current consumption goes up to about 50mA and just stays there. Chipset and 3.3V regulator getting a bit warm under thermal camera, but not really noticeable...
              03-07-2025, 05:21 AM
