What am I doing wrong desoldering?
  • Amiga64
    • Apr 2016
    • 10
    • germany
    Trying to get this IC out but it is the first time I've done this.
    I have a plunger and wick, but this is all I could remove, and it still won't budge. Am I doing something wrong, or?
    • 30952
    Re: What am I doing wrong desoldering?
    it's an advanced skill.
    what is it anyway - and what chip?
    there are a few ways of doing it.
    assuming you dont want to trash the chip, you use a desoldering pump with a bit of hellerman H30X25 sleeving on the end to create an airtight seal against the board.
    after you remove all the solder, you use the iron to gently nudge all the pins away from the edge of the hole, then gently wiggle the chip with pliers to break any tiny bonds still remaining.
    or you can try using braid from BOTH sides of the board and then using the iron as above to get the pins away from the edge of the holes.
    is that a comodore64 or similar? that rippled solder under the laq looks familiar!
    btw, always melt the solder fully before using the pump.
    • diif
      • Feb 2014
      • 6978
      • England
      I find adding some fresh leaded solder helps the old stuff come out easier.
      • whiz62
        whiz62
        • Dec 2013
        • 242
        • usa
        I am just a newbie, but I agree with adding fresh solder first. Makes it a lot easier.
        • ttuguy
          • Jul 2016
          • 7
          Removing DIP (dual row) through hole parts is always a nightmare... often you can choose to keep the part intact or the board intact, but not both; it's so easy to lift a pad. If your not trying to salvage the part snip some legs to make it easier.
          I've had best luck with my Aoyue 968A+ rework station and 853A board heater, put the board upside down on the heater at about 150C then once its up to temperature work the hotair in circles around the chip until it falls free.
          Assuming that's not in budget, I second adding some fresh leaded solder, and use copious amounts of no-clean or water soluble flux. After you get most of the solder off of a pin where you can see through the hole, heat it till it flows, remove the iron and wiggle the pin with some needle nose until it solidifies... repeat with every pin. you should then be able to pull it out, only reheating pins that catch.
            • 30952
            what i said works fine.
            • Brian_STI
              • Jul 2015
              • 10
              • united states
              What stj said...though sometimes you're just going to have difficulty, specifically with multi-layered boards. What you need then is Chip-quik, it's expensive(for what you get) but a little goes a long way. It will lower the melt point of the solder so it more easily comes off the board with solder wick.
              • MJ-meo-dmt
                • May 2016
                • 186
                • South Africa
                What the people above said works fine. ESP stj.
                What I sometimes experienced in those cases with those many pins, is making sure you have your iron nice and hot and make those pins nice and hot when you hold the soldering iron on them, add some more solder and press the solder sucker(pump) on top of it and suck it. everything should come out. If you have a plastic tip on the sucker(pump) be sure to speed up the process, don't hold it close to the hot iron or solder for too long .
                Also add liquid flux if you can, it makes the solder run more smooth... Keep at it you'll get it eventually
                Also a hot air station is the better alternative... I always use my hot air to remove multi pin chips... Thought you have to be careful some boards are weak against hot air and could cause them to either burn up or bubble up.... anyways Goodluck!
                while alive { live(toFullest=true) }
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  If your going to be doing much of this, then invest in a solder extractor, it was one of the best investments I have made in a long time. I got lucky on obtaining an older pace ST115 and hand-piece. Would not be without it for the work I do on expensive multi-layer boards, there are more up-to date and cheaper alternatives though.
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                  • hans_meier
                    HP EliteBook 840 G6 how to dump without desoldering
                    by hans_meier
                    I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
                    01-04-2025, 04:11 PM
                  • Dreigas
                    ISL95880HRTZ desoldering temperature
                    by Dreigas
                    I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                    Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                    09-13-2024, 10:59 PM
                  • armini
                    18VDC PSU completely dead - ZD-915 desoldering station
                    by armini
                    Hi everyone!
                    Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                    Due to a lack of time, I set it aside and didn't look at it.
                    Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                    According to replies in 18VDC PSU has dropped to...
                    04-25-2023, 07:49 AM
                  • Jeff'sTech
                    Dell Latitude 7420 BIOS Unlock Gone Wrong
                    by Jeff'sTech
                    Hello everyone.
                    I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                    11-08-2023, 03:30 PM
