Trio oscilloscope cs1022
Re: Trio oscilloscope cs1022
Depending on what you're doing, having a DSO may or may not matter.
At first I had a old 20MHz analog scope, which is probably very similar in capability to your CS1022. I used it to repair a more advanced 300MHz analog scope with digital control. I subsequently got a broken 300MHz digital storage oscilloscope and used the newly fixed 300MHz analog scope to fix it, though the old 20MHz analog would have done just fine too.
Still surprising what you can do with old analog scopes, a lot of the time it's just thinking about what experiments you can do to work around limitations.Comment
Well, don't get too excited. Only analog scopes that have XY mode can be used as a vector monitor, and ones with XYZ input can be made into a raster monitor. Then again I'd be surprised if digital scopes could not have software to display NTSC directly...
I know my old 20MHz scope can not do XY mode and thus cannot do vectors or lissajous figures. My 300MHz scopes do have XY mode, and my analog 300MHz scope can do full XYZ and thus with some external circuitry, display raster images. Note when I say Z, this is brightness, not third dimension; however yes it is a third dimension to a scope.
The XY mode on my 300MHz DSO is crappy at best. I doubt it can do vector graphics justice, but you can do lissajous figures. However I don't have it calibrated perfectly yet so even with X=Y I get an oval indicating a phase error. In any case, using lissajous figures on DSOs have mostly been deprecated as the signal processors can mostly get information gained by lissajous figures by direct computation.
My old vacuum tube (amplfiers, not just the CRT) Eico scope that's at my parents' place, has XY mode and is also single trace. Dang these mini dual trace scopes! Alas it doesn't even have a triggering mechanism...
That being said, I think the CS1022 does have XY mode, or at least the CS1021 has XY mode according to Wikipedia
Well the trick is, it needs to be processed in software on the digital scopes (including "digital phosphor" (I hate that term)) - if not, no chance, but at least this kind of stuff is theoretically possible. Indeed it will make a trade off of screen refresh rate and CPU/resource utilization. The screen update circuitry gets the shaft over the trigger and capture circuitry.
My 2440 DSO XY mode plots dots, which is OK for lissajous figures, but not OK for vector graphics. I doubt it does XY mode at full sample bandwidth either - probably a small fraction as a gimmick.
Anyone actually use XY mode anymore? I've always thought of this as a hack to get around the limitations of a single channel analog scope without needing to implement a second channel as this was kind of expensive to do (dual gun CRT) before fast transistors/ICs became available.Comment
Ah, thought you were doing so just for fun (I thought fixing the CRT to work was the plan, then again having it show up on the scope helps determine which side is broken), as displaying a raster image on an XYZ scope is really of limited use
Though maybe someday I'd still like to make my 2465 show a raster image for the heck of it
It definitely didn't work that way debugging my 2440. Needed to see the screen and use another scope to monitor the signals at the same time. Luckily I could use the internal screen since it's not nearly as big as an arcade.Comment
Thanks m8
Just got my hands of on a CS-1022 and have tried to locate a servicemanual for it, nothing but suspect money-grabbing sites claim to have it
I will share it too
i still havent tested my scope as yet but have got it on my work bench now so over the next few days will see if it works doing some basics tests etc it powers on ok and has a trace etc so its a start i guess.Comment
Hi everyone, Im hellping a local audiophile who has a problem with his oscilloscope, Im trying to find a service manual to help him fix his scope, would you guy be so kind and upload the pdf again?? I tried with the .rar link but it could not be exported properly.
Thanks in advance greeting from SerbiaComment
the rar link does work fine ive just re downloaded the rar files i think the pdf will be too large too upload on the forum.
im using 7 zip to unzip the files and works fine.Last edited by vinceroger69; 02-05-2017, 03:30 PM.Comment
I did try to download it and it did, but when I export it doesn't open it gives me this message : "rar unexpected end of archive" so thats why I asked if someone could put another .rar file again? Could you?
His English is also weak so ill be translating the manual to him in Serbian while we work on it together...
The RAR file works fine, try downloading again and if it fails use the latest version of WinRAR."The one who says it cannot be done should never interrupt the one who is doing it."Comment
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
Subject: Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
I am looking to repair my MSI RX 6900 XT GAMING Z TRIO graphics card and need the boardview to perform an accurate diagnosis.
Would it be possible to provide it to me or let me know where I could obtain it?
Thank you in advance for your help.
Best regards,
Aurelia...-
02-06-2025, 02:21 PM -
by EvetsI have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
by SolomonManAll,
Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor... - Loading...
