CH341a and logic level converter
  • wall
    • Apr 2016
    • 37
    • Portugal
    Hi, I need to flash the bios on a bricked windows tablet, but the chip is 1.8v soic8 and I have no idea how to hookup the 2-channel bi-directional logic level converter, I just know I need a 1.8v reference voltage on the LV side and a 3.3v reference on the HV side.
    Any help is appreciated, thank you.
    • 30979
    Re: CH341a and logic level converter
    got any links / foto's?
    • wall
      • Apr 2016
      • 37
      • Portugal
      The tablet is a Chuwi Hi8 Pro
      The usb programmer
      The logic level converter
      and the soic8 clip
        • 30979
        https://www.sparkfun.com/products/retired/11978
        that's the board.
        you get the high voltage from the programmer socket, and the low voltage from the chip / tablet.
        but i dont think it will work.
        most flash chips use bi-directional data pin(s)
        what is the part number on the flash?
        • wall
          • Apr 2016
          • 37
          • Portugal
          You mean the bios chip?
          It's a Winbond 25Q64, the rest is scrapped off.
          • wall
            • Apr 2016
            • 37
            • Portugal
            I have a very old 18650 battery that measures 2.03v, could I use that as the Low Voltage reference? These bios' can take 1.65v to 2.20v if I'm not mistaken.
            I don't know which pins need to go through the LLC.
              • 30979
              the reference has nothing to do with it.
              those chips use one pin to send data in both directions - that converter wont do that.
              how do you know the chip is 1.8v and not 3.3v ?
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                the thing important to note is FW mark after w25q64, that indicate the IC use voltage 1.8v.
                experience with ezp2010 didn't kill the ic. maybe just cause corrupted data when transfer process.
                that best idea should using converter/adapter for doing flashing bios chips
                  • 30979
                  3.3 through a 100ohm resistor - maybe with a 2v zener diode to ground,
                  but NOT with a clip - you will put 3.3v into everything else and trash the cpu.
                  the chip needs to be removed first.
                  • wall
                    • Apr 2016
                    • 37
                    • Portugal
                    The progamming software isn't detecting the programmer I've tried on 3 computers and tried every driver but it just says device state not connected. Shouldn't the PWR led light up?
                      • 30979
                      what software, what o.s.?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Theres a problem with these black versions of these programmers this video may help
                        https://www.youtube.com/watch?v=5NYe21nFSDI
                        i have this one in this link not sure if the software works with yours its included in the comments
                        https://www.youtube.com/watch?v=L0ChYNwunUE
                          • 30979
                          i have every software version, but i want to know what o.s. he's using.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            It took me ages to find the bottom one in the link that worked with english language i messaged the poster of that video and he re uploaded the files, in the black version like the tester in this thread i think its a matter of moving the jumper to the correct pins too and then the pc reconises it etc.(although looking at the picture in the thread it does look like its on the correct pins)
                              • 30979
                              not looking at the video, but i can say the black one can double as a usb>serial convertor if you move the jumpers.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                some of these gadgets from china work very well once you sort the correct software you can save a lot of cash too as there so cheap.
                                  • 30979
                                  yes, i have to have this now!!!!
                                  http://www.ebay.co.uk/itm/291693366485
                                  Core: ARM 32 Cortex-M3 CPU.
                                  72MHz work frequency.
                                  64K flash memory, 20K SRAM.
                                  £1.70!!!
                                    • 30979
                                    the language is selected in the config file.
                                    they all support english
                                    • megaraider
                                      • Jul 2015
                                      • 307
                                      • Portugal
                                      1st. The Winbond chip has to be removed first!
                                      [Otherwise, unless you're an experienced electronic guy you will most likely kill everything connected to the 1.8V power rail]
                                      2nd. Forget the clip and that tricky voltage level converter;
                                      3rd. Use the CH341A programmer and a suitable voltage level converter, e.g. this 1.8V SPI Flash adapter around €4;
                                      • gabiz_ro
                                        • Mar 2011
                                        • 167
                                        • Romania
                                        I was looking for same thing some time ago.
                                        Never tested,but in near future i'll do one.
                                        http://eximage.ru/image.php?dm=6KNL
                                        http://storage6.static.itmages.ru/i/...50a3837bca.jpg
                                        I recomend second image,since I don't know how programmers are built,but in any case suplimentar resistors will not force IC used in programmer if are direct pin to pin connected with memory needed to program.
                                        Level converter can be use I think.
                                        On SPI chip you have serial data out and serial data in,clock etc.
                                        And all are uni-directional.
                                        Is not like in i2c where you have one pin clock one pin data.
                                        That require bidirectional converter.
                                        • md500
                                          [Question] Ch341a and 5v to 3.3v with logic converter
                                          by md500
                                          zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                                          Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                                          What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                                          I can't buy the ch341a 1.6v that has...
                                          05-24-2024, 06:51 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • korben_dallas
                                          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                          by korben_dallas
                                          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                          MY QUESTION:
                                          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                          02-14-2024, 12:23 AM
                                          MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                                          The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                                          Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                                          10-23-2024, 03:23 AM
                                        • gizmo1990
                                          What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                                          by gizmo1990
                                          I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                                          The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                                          10-21-2024, 08:02 AM
