CH341a and logic level converter
  • megaraider
    • Jul 2015
    • 307
    • Portugal
    Re: CH341a and logic level converter
    Originally posted by gabiz_ro
    (...)On SPI chip you have serial data out and serial data in,clock etc.
    And all are uni-directional.
    Is not like in i2c where you have one pin clock one pin data.
    That require bidirectional converter.
    True... but only in Standard SPI mode!
    But most devices now support Dual, Quad, ... SPI mode for access speed improvement!
    Since one's not sure about the programmer algorithm,
    what SPI mode is being used, it's better to be sure than sorry
    • gabiz_ro
      • Mar 2011
      • 168
      Indeed.
      But if programmer doesn't work in dual or quad mode but in standard SPI mode then?
      Isn't same content?
      Still works but at lower speed?
      • wall
        • Apr 2016
        • 37
        • Portugal
        After all this time my tablet is still a paperweight due to never getting the programmer to work. I think the programmer is dead, Windows recognizes and installs the drivers correctly but the LED lights don't turn on and the software says Device State: NotConnected in the bottom right corner
          • 31198
          check the jumper is in "programmer" mode and not "serial" mode.
          btw, pro convertor for low voltage parts.
          http://www.ebay.co.uk/itm/191899183629
          • wall
            • Apr 2016
            • 37
            • Portugal
            I tried the jumper on 1-2 and 2-3, it shows in device manager either way but never turns the leds on and the software never detects it.
              • 31198
              so what version of windows is it, and what is it recognised as?
              • wall
                • Apr 2016
                • 37
                • Portugal
                #27
                USB-SERIAL CH341A. Installs automatically under Windows 10 and it's exactly the same driver I have to manually install in Windows 7.
                  • 31198
                  and the parallel drivers?
                  • wall
                    • Apr 2016
                    • 37
                    • Portugal
                    #29
                    There is no other device to install.
                      • 31198
                      the chip is a usb to parallel converter aswell as a usb to serial convertor.
                      i'm starting to think it's a windoze problem as usual.
                      • wall
                        • Apr 2016
                        • 37
                        • Portugal
                        #31
                        But it should power the LEDs at least, the board gets hot under the chip. Could I have burned it by connecting it to the bios chip on the tablet without removing the battery?
                          • 31198
                          your supposed to remove the damned bios first, you probably tried to power the entire tablet through the programmer!!!
                          anyway, it probably survived.
                          i will try to set one up on xp later and see what the o.s. says and what the led's do.
                          • megaraider
                            • Jul 2015
                            • 307
                            • Portugal
                            #33
                            wall
                            If the CH341 programmer power led doesn't light up upon connection to the USB port the programmer is, imo, burned or dead.
                            Buy another one... trying to avoid spending less than 5€ and remaining with a dead tablet is not a solution
                            Found this tutorial in pdf:
                            Recovering-a-Bricked-Chuwi-Hi12-caused-by-Corrupt-Bios.pdf
                            and these videos:
                            https://www.youtube.com/watch?v=-K8Xif-6GUw
                            https://www.youtube.com/watch?v=0WHJgi1U5bc
                            Everything you need is there » Follow them step by step
                            Do not forget to:
                            - isolate / disconnect w25q64fw pin 8 (bios chip) from the programmer;
                            or
                            - disconnect the red wire that connects the battery to the board;
                            • wall
                              • Apr 2016
                              • 37
                              • Portugal
                              #34
                              Some people succeeded in flashing these Cherry Trail tablets without desoldering the bios or disconnecting the battery and even without a 1.8v converter.
                              What's the worse that could happen if I don't isolate the VCC pin? I already put 3.3V through it and probably eveything in between VCC and GND that's meant to take 1.8V, the tablet is behaving the same, still charges the battery and powers devices through the usb host.
                              I really don't want to desolder the bios chip or even bend a leg back.
                              • megaraider
                                • Jul 2015
                                • 307
                                • Portugal
                                #35
                                Yes, you've already temp fate
                                If the tablet still behaves as before and a close naked eye inspection doesn't reveal anything burned lets assume the only casualty is the programmer
                                You don't have to remove any solder or bend any pin.
                                Just use isolation tape on bios chip pin 8 placed between the pin itself and the contact on the clip, thus isolating w25q64fw pin 8 (bios chip) from the programmer
                                • wall
                                  • Apr 2016
                                  • 37
                                  • Portugal
                                  #36
                                  Should I buy another CH341a? I was thinking about trying the EZP2010 but I only see "W25X64" in the manual and "W25Q64BV" in the software. Do you think it will work?
                                  • wall
                                    • Apr 2016
                                    • 37
                                    • Portugal
                                    #37
                                    I received my new CH341a, this time not the black one and the mentioned 1.8V SPI converter, but the software can't detect the chip, I programmed it twice anyway but the tablet still doesn't turn on, this was with the BAT+ desoldered, by the way.
                                    So I should really remove the bios chip, what puzzles me is that everywhere I looked nobody removed the battery or desoldered the chip from the motherboard and they were all successful wih those sh*tty clips.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #38
                                      It takes less time to remove the BIOS chip than it does messing about with those clips ensuring they are making proper contact.
                                      Removing it and soldering it directly to the CH341a is the best way as you will know for sure. It's possible the chip is faulty.
                                      • wall
                                        • Apr 2016
                                        • 37
                                        • Portugal
                                        #39
                                        It has too many small resistors, memory chip and emmc right next to it I don't know how the hell I'm going to desolder this..
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #40
                                          Hot air.
                                          • md500
                                            [Question] Ch341a and 5v to 3.3v with logic converter
                                            by md500
                                            zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                                            Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                                            What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                                            I can't buy the ch341a 1.6v that has...
                                            05-24-2024, 06:51 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • korben_dallas
                                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                            by korben_dallas
                                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                            MY QUESTION:
                                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                            02-14-2024, 12:23 AM
                                            MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                                            The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                                            Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                                            10-23-2024, 03:23 AM
                                          • gizmo1990
                                            What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                                            by gizmo1990
                                            I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                                            The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                                            10-21-2024, 08:02 AM
