Recommended Capacitor Tester
  • thespeakerport
    • Mar 2016
    • 17
    Hello all...
    Was hoping someone could make some suggestions for good, reliable capacitor tester. Is there one out there that can accurately test and provide information about a capacitor such as (capacitance (duh), ESR, Impedance, leakage, etc.) In a different thread, I voiced concern about not being able to accurately identify what specs an old/vintage capacitor had. It occurred to me that if I had a way to comprehensively test an 'original'; identifying the replacement would be cake walk. (I found and bought a few 'general' testers out on eBay and they work OK to provide basic information, but as I mentioned, looking for something that can truly and thoroughly test and measure a capacitor.
    • 31197
    Re: Recommended Capacitor Tester
    a vintage cap will not be in-spec, so your idea wont work.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Peak atlas esr meter, very good.
        • 31197
        does the peak show leakage?
        nothing that costs 2digit numbers will show ripple btw.
        • gearhead63
          • Jul 2014
          • 14
          I have an old EICO 950B. It works for the stuff I work on, but will only tell capacitance and if it leaks. AND, you can test caps up to 500V for leakage. And it actually supplies 500 volts to the cap.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Works well for what I need it for
            • brucetv
              • May 2015
              • 281
              • united states
              The Peak Atlas ESR 70 is very nice. You can use in circuit, has automatic discharge before it analyzes the capacitor, shows Cap and ESR on a easy to read readout and has a automatic shutoff. Shows In-Circuit/Leaky when it senses a bad cap. I remove and re-test. Nice compact design for the field and gold clips. Different beep tones for each function...love it.
              • chth96
                by chth96
                03-09-2024, 10:03 PM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • nubinator
                how can i test individual leds without tester
                by nubinator
                Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                10-25-2022, 11:05 PM
