Rework Station Pump - Can They Be Repaired ?
  • fbooktablet
    • Aug 2013
    • 15
    • India
    #41
    Re: Rework Station Pump - Can They Be Repaired ?
    Even I had this prblem. The coil is not working any more.
    The circuit works like a dimmer using traics.
    These diaphragm doesnt go bad its the coil that sops moving in lateral direction n just vibrate.
    U can use dual diaphragm aquarium pumps n seal the pipes with some hot glue.
    • mmartell
      • Oct 2013
      • 3189
      Interesting. I ohmed out both coils and they seemed ok, about 146 ohms each.
      • mmartell
        • Oct 2013
        • 3189
        Originally posted by xelectech
        Since looking at the newer pics I can't agree with that possibility anymore, having seen those manifolds. Before those pics, it seemed debatable whether the work was being done inside the inner chamber or outside it; I do still think it's possible that the diaphragm is supposed to be secured somehow to the ends of the spindle so its lateral movement is more limited (not to say that that makes it true &^).
        I'm wondering now about the noise it made when it failed, did it make a big noise and then quit, or did it start making a noise and then you turned it off because of it?
        It didn't fail in use just noticed it sounding odd last time I turned it on. Made me think to check the wand for air flow before it melted in my hand anyway.
        • xelectech
          retired tech
          • Nov 2014
          • 238
          Okay, had to go reread from the start - do the magnets look beat up at all?
          Have you done any checking around on the ckt. bd. to see if anything seems awry there?
          I'm thinking that, from the looks of the top of the board, the bottom probably looks kinda funky too, maybe has some rosin bridges on it which might affect its operation.
          Other than that I don't know anything else to do...except look into fbooktablet's suggestion, and maybe a variac to vary the air-flow a little.
            • 31065
            the pcb's in these things are a joke, i resoldered about 80% of mine.
            things like a transformer not even sitting flat on the board!
            • xelectech
              retired tech
              • Nov 2014
              • 238
              How similar is yours to mmartell's? Just wondering, from fbooktablet's description of his unit's failure, if some ckt component went south...
                • 31065
                unknown without a pcb foto
                these units get cloned so you cant be sure what's inside from the outside.
                i would say they always need a recap even if new!
                • xelectech
                  retired tech
                  • Nov 2014
                  • 238
                  lol, a sign of the times, huh - no schematics came with it either, I suppose...
                    • 31065
                    you could draw one up in 15-30min's
                    it's mostly a 555 that i suspect is for the pump, and an opamp related to the heater feedback.
                    i should add that mine does not have a digital display - those probably contain even less.
                    • xelectech
                      retired tech
                      • Nov 2014
                      • 238
                      Maybe (probably) you could, my ckt drawing skills/understanding are pretty rusty/outdated,
                      lol!
                      • mmartell
                        • Oct 2013
                        • 3189
                        I couldn't do it either. I will pull the board and have a closer look and check some of the components.
                        The magnets look good.
                        stj there is a photo on the first page of the circuit board. Will take a better one when I remove it.
                          • 31065
                          that's very different, but shares the same construction quality!
                          • harleyman58
                            • Feb 2016
                            • 89
                            • usa
                            #53
                            The piston that has the diagrams on it will not be a magnet. The coil creates a magnetic field pulling the iron core in the center to one end of stroke then the other. If it was a magnet it would not move because of opposing magnetic fields.
                            • mmartell
                              • Oct 2013
                              • 3189
                              I considered this but I am not fluent in magnetics lol.
                              If the two pieces in the piston are supposed to be steel (they ARE magnetized atm) by what mechanism does the piston move to the other end of the stroke ?
                              • harleyman58
                                • Feb 2016
                                • 89
                                • usa
                                #55
                                One coil energizes pulling the diagram to one end,then it shuts off and the other coil energizes pulling it to the other end. Then the coils just alternate off and on.
                                  • 31065
                                  no, both ends energize together.
                                  what may be happening is that you have a pair of magnets of oposing polarity's, so it will pull in the direction of the current flow.
                                  that just happens to change direction 50-60 times a second
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Yes the coils are energized at the same time. Seems to me the magnetic field is perpendicular to the path of the piston though. Or is it ?
                                    • harleyman58
                                      • Feb 2016
                                      • 89
                                      • usa
                                      #58
                                      Why are there different wires feeding each end of the coil? With the commons wired together?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        The coils are wired in series.
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          Ok this image is from a patent filing and so the mystery is solved on how this is SUPPOSED to work. Now to troubleshoot if it's mechanical or electrical.
                                          • shahnld
                                            wds-580 rework station issue
                                            by shahnld
                                            Good day.
                                            i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                            Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                            kind regards...
                                            03-28-2024, 01:14 PM
                                          • minimania
                                            Need Schematic for jbc am6800 rework station
                                            by minimania
                                            hi all im looking for a Schematic for jbc am6800 rework station
                                            mine has stopped working fully
                                            it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                            now it wont turn on at all...
                                            01-28-2025, 03:44 PM
                                          • shahnld
                                            Seamark ZM-R6200 Rework station
                                            by shahnld
                                            Good day Experts.
                                            I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                                            Kind regards
                                            01-24-2024, 10:55 AM
                                          • petemanuk
                                            Help with IR6500 rework station
                                            by petemanuk
                                            I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                                            1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                                            2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                                            10-14-2022, 12:31 AM
                                            ZD desoldering station pump rebuild
                                            by stj
                                            just did one.
                                            works great.
                                            so here's the discoveries.
                                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                            so you need to clean everything to get rid of all the tacky black stuff.
                                            then reassemble it.
                                            *BUT*
                                            you must put the 2 screws into the assembly only finger-tight.
                                            if you tighten it properly the valves dont work....
                                            08-21-2024, 05:59 PM
