Time for a new/better soldering iron
  • newtothis
    • Mar 2013
    • 1556
    • england
    OK throw me your recommendations and reviews
    No slip over type tip irons please... Meh LOL
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Time for a new/better soldering iron
    You will most like have to state what you will be soldering
      • 31015
      no slipover tips means hakko T12 clones.
      all other irons have slip-over / slip-in tips, just with a cover over them.
      • newtothis
        • Mar 2013
        • 1556
        • england
        A good quality iron will be able to cope with any cct soldering work
        • newtothis
          • Mar 2013
          • 1556
          • england
          Indeed.. I was considering the Hakko FX-951 but can't seem to get any over in UK
            • 31015
            contact these guys.
            http://www.batterfly.com/shop/index....te=common/home
            they ship to the u.k. and have great prices, a friend got an 888d from them recently.
            they even take paypal
              • 31015
              move fast, it's on a special till the end of december!!
              http://www.batterfly.com/shop/hakko-fx951
              • newtothis
                • Mar 2013
                • 1556
                • england
                Awesome thanks!
                Ordering later on
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  So maybe I'm stupid, but what does the abbreviations CCT mean in this case?
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Circuit
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      So you are saying any circuit that you may come across?
                        • 31015
                        i think he means pcb
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Speaking of these slip over knock off irons, seems that the air gap between the ceramic and the tip makes the tip have much less temperature control. What a sham! I guess I get what I paid for, alas definitely still could get it to work though it's fairly weak on ground planes.
                          I guess I should have suspected something when the "heater on" LED didnt turn solid on when wiping the tip off on a wet sponge... Instead the solder solidified on the tip...
                          Any good mods for this? Heard of people filling the gap with graphite. I tried filling the gap with some aluminum foil but wonder if it's going to really help any. It really needs to be tightly attached to the ceramic to make a difference, I'd think.
                          • mariushm
                            • May 2011
                            • 3799
                            If you don't want a soldering iron with separate ceramic heating element, there are options besides fx-951.
                            I have on my desk a Pace HW-50 soldering stations, the removable tips have the ceramic heating element built. This model is no longer sold, but the newer models are pretty much the same and compatible tips are still made for them:
                            http://uk.farnell.com/webapp/wcs/sto...6474&mf=100367
                            The cheapest is ST 30 , same as ST 50 but with analogue temperature adjustment (at 196 uk pounds) : http://uk.farnell.com/pace/8007-0512...-uk/dp/1279325
                            The cheapest digital one is ST 50 at 229 uk pounds: http://uk.farnell.com/pace/8007-0514...-uk/dp/1279326 :: pace link: https://www.paceworldwide.com/produc...soldering-iron
                            Here's datasheet with lots of details about the stations here: https://cdn.badcaps-static.com/pdfs/...f8729678fc.pdf , see page 8. See page 20 for tip descriptions.
                            And like I said, it uses TD-100 tips which are compatible with my old HW-50 station, plenty of them for around 10 uk pounds each : http://uk.farnell.com/webapp/wcs/sto...7221,112899753
                            ST 70 is somewhere in between, but it doesn't have direct temperature adjustment, you adjust it by plugging something in the station (it's basically a stereo jack with a built-in resistor, different resistors set the station to different temperatures so you can make your own instead of buying them . It's good design for factories, where you just set the temperature and forget, less nice for hobbyists or if you need to adjust the temperature often.
                              • 31015
                              my cheap shit tips that actually work very well have a sleeve inside them to give a tight fit.
                              you can also put silicone grease or copper-paste in one.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                • United States of America
                                I love the Weller WX2 station I got. You can get a WX1 for cheaper. The difference is the WX2 can handle two irons at once, the WX1, just one. They have a bunch of different irons that you can buy for it. I have a micro soldering iron right now. It's real nice for SMD type devices. I bought the iron off Amazon used and paid I think 60$ and it came with a stand. The tips have a mini-din type connector that just plugs into the iron. You can exchange them when they're hot without too much risk of burning yourself. It heats up extremely quick and has presets for the temps you can set. You can pick different watt irons. I think the max this can handle is a 120 Watt but it might actually be bigger. They also have an iron that's a tweezer. It's for SMD type work. You can just pick up the SMD component. Personally, I don't have any trouble using the micro iron so I won't be purchasing the tweezers anytime soon.
                                The hardware seems to be really well built and Weller's technical support, in my opinion, is excellent. The chips inside don't have the security bit set so you can dump the firmware if need be. They've provided technical documents explaining the protocol for the RS232 port on their preheaters. They've provided schematics to people who asked for them who didn't want to send the unit back to fix it themselves. I guess the schematics is hit or miss. Sometimes they'll give you schematics for the section you need or the the full schematics, other times they might not.
                                Don't quote me, but I believe their irons for the WX2 unit I have are ESD safe as well. When you're not using the iron but if you have it turned on, it's smart enough to tell that you're not using it and it'll drop the temp down to standby mode.
                                -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Oh, I believe they also have soldering irons that have built-in hot air wands or whatever you want to call them and built-in vacuum pump for picking up ESD sensitive components. They cost a bit more money though I believe.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Indeed!
                                    I dislike those irons myself quite a bit. Made a thread about it some time ago:
                                    https://www.badcaps.net/forum/showthread.php?t=46338
                                    Even the genuine Hakko stuff doesn't compare to a cheap iron with T12/T15-type tips.
                                    I am using a Circuit Specialists CSI-2900. This, actually:
                                    http://www.circuitspecialists.com/le...l-display.html
                                    It's basically the same thing as an Aoyue 2900 inside.
                                    For $60, you just can't beat the performance. The built quality is a bit cheap, though (especially the handle for the tips). But the performance gain of the T12/T15 tips over the 900M tips is worthwhile. I've even melted big blobs of solder with it to remove entire VGA and 8-channel audio connectors from motherboards, among other things.
                                    Hey, at least yours melted the solder. I got a "late Friday night" -shift KADA 852D+ station with a hacked 120V plug. What I mean by that is the station was made for the 220/230V market, but because they probably ran out of stations for the 120V market, they simply put a US / North America 120V plug on a 220/230V station. No transformer swapping or anything fancy like that.
                                    End result: iron barely got warm enough to melt plastic... let alone solder. Oh, and jiggling random numbers all over the display. The transformer was outputting only 5.1 V DC (after being single-wave rectified) to a 7805 regulator. So that regulator was dropping out constantly - at 60 Hz, in fact. Since that 7805 supplies power to all of the logic, I guess the 5V MCU didn't quite like 4.5V DC with 60 Hz ripple.
                                    That said, I'm surprised the damned thing worked at all.
                                    I don't think I have posted pictures of that station before, have I?
                                    I'm thinking about getting a 1/2" solid copper rod and making my own tip. Even if the fit is still not good, once that 1/2" copper rod heats up to proper temperature, there will be plenty of "heat reserve" for soldering even big joints.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Want to update this thread with my now current iron _
                                      I have the Jovy iSolder40 v2
                                      I can say by far this is the best iron I have ever owned
                                        Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                                        by sam_sam_sam
                                        This is a new item at Electronic GoldMine that has arrived within the last few weeks
                                        Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                                        Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                                        https://theelectronicgoldmine.com/products/g28392
                                        One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                                        11-24-2024, 01:25 AM
                                      • rmjimenez455@gmail.com
                                        Sumsour station 8586D error H-E
                                        by rmjimenez455@gmail.com
                                        Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                        09-07-2024, 09:33 AM
                                      • kalemaroni
                                        Opinions on particular soldering iron tip maintenance product
                                        by kalemaroni
                                        Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
                                        04-12-2024, 03:52 AM
                                      • tony359
                                        Kaiweets USB soldering iron
                                        by tony359
                                        I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
                                        As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
                                        In other words, do you think it's expected and...
                                        02-06-2024, 12:51 PM
                                      • Mirenia
                                        First time hot air (de)soldering
                                        by Mirenia
                                        I am trying to save my broken laptop and would like to desolder the WSON8 BIOS chip in order to repair the BIOS with a programmer.
                                        I have now purchased a hot air soldering station (YIHUA 959D-II) for this purpose. I have already practiced a little on a broken board and desoldered components with it.
                                        (350C with medium airflow and within a few seconds I was able to lift off the components with tweezers)
                                        Now I'm afraid of destroying the BIOS chip if I desolder it too hot or for too long.
                                        Do you have any tips on which nozzle size, temperature...
                                        02-03-2024, 01:09 PM
