Irons that use 900M soldering tips... and why I dislike them
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    I've seen people here ask and recommend various soldering stations. Unfortunately, most stations that get recommended are the Hakko 936 clone ones (or a version of that) with 900M series tips. Nothing wrong with that, but in my opinion, all of those perform about the same and if you are getting a station like that, don't spend a fortune on it. Rather, if you really are serious enough about getting a "proper" soldering station, you might as well spend just a little bit more and get something with T12 and T15 tips.
    So why all of the dislike for 900M stations/tips? Let's take one apart and see...
    Here's is your standard 900M iron handle. I put a 3 mm chisel tip on there:
    All taken apart, showing the ceramic heating element:
    https://www.badcaps.net/forum/attach...1&d=1431575036
    And the mini PCB pulled from the handle:
    Now, let's note something here: the thermocouple/temperature sensor is inside that thicker base which is holding the heating element to the PCB (under the spring).
    But now let's see what happens when the tip is on the heating element:
    Anyone see what's wrong with this picture? No, not yet?
    Well, you have the tip on one end (left) of the heating element and the thermocouple/temp sensor all the way on the other end (right). So how exactly is the thermocouple going to pick up the temperature of the soldering tip? Short answer - it won't.
    Rather, the way it works is that the thermocouple just keeps the temperature of the heating element to whatever temperature you set the station to. As the soldering tip sits over the heating element, it eventually equalizes to the heating element's temperature (if the iron is not being used, of course). But once you start soldering, that soldering tip will drop in temperature, whereas the temperature of the heating element won't change drastically. You leave the iron for a bit, and again the tip will get to the heating element's temperature.
    So the result is poor thermal control. And that's why so many people crank these stations up to 300C just for leaded soldering, and much higher for lead-free.
    With T12 and T15 tips, both the thermocouple and the heating element are embedded in the tip. This is why those tips have much more superior heat control (and why each T12/T15 tip costs around $10 a pop too). But IMO, that investment is worth every penny. You will be able to solder lead-free stuff even on as low as 260-280C temperature settings with those T12/T15 tips.
    Anyways, I don't mean to steer anyone clear of stations that use the 900M tips. Rather, just trying to inform of what to expect from them. Obviously, if you can get it very cheap, go for it. They do have some benefits over regular/standard mains plug-in irons. But otherwise if you want a more serious station, just go for something that uses T12/T15 tips, even if it is a lower wattage than the offerings you may get from stations that use the 900M tips.
    I haven't been following on what are the latest trends for these temperature-controlled soldering stations, but I know that Aoyue 2900 was one of the more inexpensive units a few years back. Circuit Specialists also sold a clone of that for about $60 last I checked. Another alternative is Hakko FX-951 - if you can find one that is genuine, of course (though, on that note, I will say that I have tested a "counterfeit" FX-951 station, and it still worked quite okay... just didn't have sleep function and soldering and built quality inside were low).
    • 31301
    Re: Irons that use 900M soldering tips... and why I dislike them
    make one.
    http://dangerousprototypes.com/forum...hp?f=56&t=5264
    • chth96
      What soldering station should I purchase for 900M-TJ-I tip?
      by chth96
      hello.
      A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
      https://ko.aliexpress.com/item/4001275635593.html
      Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
      Any reply would be appreciated.
      11-24-2023, 05:08 PM
    • Prott
      Soldering flex cable - tips & tricks
      by Prott
      Hello fellow badcappers,
      I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
      I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
      10-04-2023, 06:25 AM
    • Ady2017
      SMD fuse soldering advice please
      by Ady2017
      Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
      11-07-2025, 12:03 PM
    • Azurain
      Elitebook 840 G5 Bios Chip Soldering Question
      by Azurain
      Hi everyone,
      I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
      Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
      04-14-2023, 06:58 PM
    • EasyGoing1
      The best way to drive a heating element?
      by EasyGoing1
      I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
      What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
      This is the general setup that I have now.
      This is what the...
      01-25-2023, 11:29 AM
