Re: Transitor/ESR tester dead
Right I agree.
the regulator should have 5v coming out - start with that!Leave a comment:
So pin7 and pin1 of the big chip should be at +5 volt. ISP pin5 is also connected.Leave a comment:
Thank Steve. So you have a plug in "worts" if I spelled that right and a 9 volt battery. I imagine when its plug in it disconnects the battery. What are the symptoms? Does it not have a test button?Last edited by keeney123; 09-11-2015, 09:41 PM.Leave a comment:
The schematic is in the PDF file.
Stj, you mean the transistor to the left of the regulator?Leave a comment:
battery power goes through the transistor top-right.
it's similar to the schematic but the diode is missing.Leave a comment:
hi i have the same tester here any measurements you need just ask on the regulator i have 9.37 in 4.99 out im running off a 9volt battery is your dc power supply still giving the correct output voltage you have probably already checked this though.Last edited by vinceroger69; 09-11-2015, 11:39 AM.Leave a comment:
Starting a new thread about this that began in my Korg Polysix synthesizer thread in Audio forum...
I am very good about discharging caps before measuring them. I may have missed doing so to the last one. It's usually my habit to discharge but I don't know. However, it failed right after I had re-soldered a test lead to it that the strands were breaking on. It's soldered to a length of solid wire that is soldered to a PCB pad, so I didn't overheat anything or that bit of solid wire would have come loose. Regardless, the little guy won't fire up. Oh well. I've gotten a lot of use out of it. I'll get another when I am able to.
Edit: it was also running on a regulated DC power supply not a battery, so I suppose a momentary power fluctuation or spike that didn't get filtered out could have killed it but I've been using it that way for months. *shrug*post a foto of the parts-side so i can see the design.
it may just be a voltage regulator.
btw, i just ordered this model.
i chose it because it has a 3pin connector and flyleads.
http://www.ebay.co.uk/itm/181861030068
Stj page 11 appears to show a mod for the board but not what's there on my board. If I'm mistaken let me know. If you meant the basic schematic then what transistor are you referring to?Tags: None
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by maleksaThe LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...-
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos -
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... - Loading...
