Desoldering station vacuum pump. Looking for recommendations.
    • 31084
    Re: Desoldering station vacuum pump. Looking for recommendations.
    you can set your temp to match the type of solder your dealing with.
    • clearchris
      • Dec 2013
      • 687
      Ouch. Id think that piece would be glaas. Clear plastic tends to be brittle.
      • jeffescortlx
        • May 2011
        • 40
        #43
        The directions explain what setting to use depending on solder and if the board is double sided or not. But I just started on the lowest setting possible and worked up until it did the job.
        • epssty
          • Oct 2015
          • 4
          • usa
          #44
          desoldering station
          does anyone have a csi 474 desoldering station?
          • jeffescortlx
            • May 2011
            • 40
            #45
            Update on the FR300. The first two canisters cracked, but the 3rd is working fine. Manufacturing must of gotten a bad batch of plastic. So far the tool is working good and reliability with moderate use.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4977
              • New Zealand
              #46
              If you can find someone who works with glass, you could get a glass one made from a piece of glass tube. That's what I have for my Den-on. Much nicer and easier to clean. The original plastic one has held up fine, but has tiny bits of solder melted into the inside everywhere. Glass works a lot better.
              -David VanHorn
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I have an ancient Ungar desolder pump (sounds like an aquarium pump, probably is an aquarium pump!). Over the years I've had to replace the heating element once already. Yes, cleaning it is very important else you'll clog. I have some steel wire that I use to poke through the tip, and changing the filters must be done as well. Also emptying the solder bin is also quite important, put it off and you might have an internal "solder bridge" that may result in replacing parts...
                It's a pain to maintain but being able to remove solder... almost priceless.
                (Good solder wick also works well...)
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  #48
                  I use a Pace ST 115E De-Soldering system with the Sx80 solder extractor, older technology but very reliable
                  • garbleduser
                    • May 2019
                    • 3
                    Re: desoldering station
                    I have one. Are you having as many problems modding a new style gun into it as I am? I would like to trade some board and original gun wiring pictures/pinouts with you! My unit came from ebay, with no gun, in a fully toasted state.
                    Trying to add the B1002B gun this this is a pain. I will have to add a solid state relay and transformer to run the 24v heater. The problem that is holding me up currently, is that I have no idea where the thermocouple attaches On top of that, the butcher that previously worked on this unit burned/pulled off all the traces at the din connector.
                    Please, we can help each other!
                    -Garbleduser
                      • Jul 2011
                      • 6041
                      Please post pictures of the boards front and back that are in this unit and we might be able to help you with it
                        ZD-915 vacuum pump motor mount service alert
                        by sam_sam_sam
                        If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                        One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                        Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                        The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                        09-19-2021, 02:15 AM
                        ZD desoldering station pump rebuild
                        by stj
                        just did one.
                        works great.
                        so here's the discoveries.
                        the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                        the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                        so you need to clean everything to get rid of all the tacky black stuff.
                        then reassemble it.
                        *BUT*
                        you must put the 2 screws into the assembly only finger-tight.
                        if you tighten it properly the valves dont work....
                        08-21-2024, 05:59 PM
                      • flat-earther
                        Hoover FM216LI cordless vacuum refuses to charge
                        by flat-earther
                        I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                        I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                        5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                        So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                        06-06-2025, 03:14 AM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • hans_meier
                        HP EliteBook 840 G6 how to dump without desoldering
                        by hans_meier
                        I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
                        01-04-2025, 04:11 PM
