Used solder from desolder pumps, etc...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    What do you guys do with it?
    Currently I've got all of my used solder that got sucked up from the desolder pump melted into a ball... It's about an inch in diameter now, maybe more. Since I dont desolder that much, and growth diameter would be the square or third root of how much solder I put on it, its growth is now very slow unlike when it was first conceived.
    Basically when I clean out all the solder from the solder chamber I melt it together with the ball and round it off. Why I do this? I don't know...
    Unfortunately this ball is probably a mixture of lead and leadfree solder, it's hard to tell what the mix percentage is. But it definitely has lead in it, hence I don't toss it in the trash.
    I wish that someday I could just draw it back into wire and reuse it for fill solder if needed, as long as no more flux is needed.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Used solder from desolder pumps, etc...
    When I was a kid I saved used solder blobs and bits and reused it later because I couldn't afford to buy any.
      • 31028
      Henry eats mine!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I don't know how I collect a significant amount of solder in the collection tube - it's not little drops, it actually is quite a bit, maybe it's just because I was parting a board or cleaning excess solder that there's so much collected in it.
        Enough gets collected I need to remember to empty it before it clogs... and if it does clog I'd need to replace the collection tube which I have no idea where to get...
        • clearchris
          • Dec 2013
          • 687
          Twist, by hand, a thin drill bit through it. The solder will come right out.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Liquid flux is easy to make for a little money. Violin rosin is well purified and when dissolved in IPA makes a very good liquid flux. Crush it and mix with IPA. It will completely dissolve into the alcohol within one to a few hours, depending on how fine it was crushed and how much alcohol was used. I haven't tried to make a paste with violin rosin yet.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              The collection tube is about 6" long. Finding a 4" drill bit that's narrow enough is difficult (the 3/64" bits tend to be short...)
                • 31028
                there is a guy on ebay selling tins of russian rosin from poland *very* cheap for people to make flux.
                • fbuth
                  • Jan 2008
                  • 5
                  http://www.ohiodrill.com/vent_drills
                  • corrize
                    Best way to solder LVDS connector for beginner (and qfn) ?
                    by corrize
                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                    See the test :
                    https://youtu.be/bNAzC-EvqHs?t=1767
                    With hot air from bellow the board, that's...
                    03-09-2023, 02:57 AM
                  • myth77
                    UV solder mask - high temp resistent, recomendation?
                    by myth77
                    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                    Is there any solder mask...
                    03-28-2022, 04:04 AM
                  • petemanuk
                    BGA solder balls not connecting - help pls
                    by petemanuk
                    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                    11-16-2022, 05:21 AM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • sircastor
                    Solder not reflowing - what am I doing wrong?
                    by sircastor
                    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                    03-03-2024, 02:44 AM
