Broken DC jack leg stuck in hole
  • Severene
    • Jul 2015
    • 5
    • Texas
    I was removing the DC jack on an MSI laptop system board. One of the legs wouldn't release and I ended up breaking the jack off with that leg still in the hole. Its more square than round. Having the hardest time getting that little piece of metal out of that hole. Any suggestions?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Broken DC jack leg stuck in hole
    Try hot soldering iron and a dab of fresh solder and a stainless needle or safety pin to push it out. Don't use a brass safety pin, the solder will bind to it.
      • 31196
      push it through with the pin of the replacement socket.
      then you only have to heat the area once.
      • clearchris
        • Dec 2013
        • 687
        I first melt 63/37 solder onto it, remove as much solder as I can, repeat up to 2x. If that doesnt work I use chip-quik. If you are having problems getting it hot enough Ill often preheat the area with hot air.
        Pb free solder is a pain.
        • dj_ricoh
          • 2073
          • uk
          Good old makita with a 0.2 drill
            • 31196
            that should be one step short of a ban!
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • valvashon
              Samsung UN55FH6030CXZA main board USB jack indentification
              by valvashon
              Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
              I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
              01-23-2025, 11:17 AM
            • magneh
              HP Pavilion 23 All In One - Broken DCIn jack and SIO
              by magneh
              Hello guys
              This is an old device from a friend.
              DC jack was broken, and I figured that SIO was also KO.
              Replaced SIO and DCjack, and DCin LED is now ON again
              But when pressing power button, nothing happens.
              Does the SIO needs to be programmed? ITE IT8518E
              Thanks for any inputs....
              03-14-2022, 10:22 AM
            • chth96
              Is it possible bridging tiny broken trace
              by chth96
              When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
              cutting tiny trace.
              This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
              Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
              But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
              12-03-2022, 11:32 PM
