O-scope probe ×100
  • Behemot
    • 4845
    • CZ
    O-scope probe ×100
    If I am not mistaken, it is just insulated high-voltage 10MΩ resistor inside the probe plus some tweaking capacitor on the BNC side, right?
    So if I wanted to embed BNC for measuring AC line output of a device, I could just hook 10MΩ HV resistor in series on the center pin of the BNC connector inside the device and than connect it with BNC-BNC coaxial directly to O-scope? OFC the device must always be turned on AFTER conecting the cable because of the risk of electrocution, I am aware of that.
    • 31197
    Re: O-scope probe x100
    wrong, it's a voltage divider.
    so it has to have atleast 2 resistors.
      100:1 probe?. Your scope has input Z of 1M. It has to do with Voltage divider and compensation.
      Please see the attached PDF.
      Probe_Fundamentals-_Tektronix.pdf
      • redwire
        • Dec 2010
        • 3912
        Typically x10 probe has a 9MEG resistor and trimmer capacitor.
        The problem you might have is the scope GND is connected to earth GND (via the line cord), so you will probably blow things up.
        On-line SMPS have a bridge rectifier and if you work on the DC bus, connecting the scope GND to - will make smoke.
        I would add a small fuse in series with the probe GND; Otherwise one mistake and you melt the traces inside the scope. Use a bigger (1/2W) 9M resistor good for 500V or more. You don't need the trimmer capacitor to view 100/120Hz stuff.
          • 31197
          but you will for the 100-200Khz stuff entering the transformer.
          • japlytic
            • Oct 2005
            • 2086
            If you need to take measurements on the mains side, you need to use an active differential probe (which is appropriately rated for the application); it also minimizes the problem with common mode noise affecting the measurement.
            From some older Pace satellite receiver service manuals, the floating of the oscilloscope ground was mentioned - don't do that under any circumstances!
            • Behemot
              • 4845
              • CZ
              Oh yeah, 9meg, sure, didn't realize at that hour, just got a quick idea and didn't think about the math thoroughly…thanks for pointing it out! But actually I now also realized it does not matter, I do not care about the absolute value, I won't be measuring any values on the X axis - I only need to look whether voltage is there or not. Fast. And than do measurements based on time, so Y axis.
              No problem, what I want to scope is actually wall phase against earth ground and the whole device is earth grounded so no problem here. Otherwise I am well aware of shorting devices with earth ground on secondary… So the phase will be on the central pin, GND on the rim of the BNC as the chasis is grounded too. I will be only looking at this 50Hz phase (whether it is on or off) so if I don't even need the tuning capacitor, even better.
              japlytic: yeah man I know differential probe is the best and I should use it for everything incl. actually measuring PSU secondary. But are you going to buy me any? I guess not? Two probes will be more expensive than the whole frelling O-scope. Unless they start making them for 1/10 of the current price, than I am interested but not buying any.
                The scope itself has 1M input so with the add 1M (R2) in parallel with the Input Z of the scope will not make it 10:1, unless that drawing referring the R2 as the input Z of the scope.
                • redwire
                  • Dec 2010
                  • 3912
                  It's a crappy diagram, R2 is the scope's input resistance and C2 is the probe cable-capacitance + scope input capacitance.
                  C1 is in the wrong place I think, because the probe compensation trimmer cap is usually inside the BNC.
                    • 31197
                    not on any of mine - maybe on very expensive stuff though.
                    • perfm2
                      Wson8 spring pin probe WORKS
                      by perfm2
                      I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
                      I recently ordered one to give it a shot and it actually worked quite well.
                      The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
                      I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
                      This aided greatly in allowing the probe to stay in place...
                      03-30-2023, 11:19 AM
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • Askic
                      Probe point corrosion -Macbook repair
                      by Askic
                      Hello guys,
                      I'm learning about logic board (motherboards) repairs. I don't do repairs professionally, but I manage from time to time to repair something for my family and friends.
                      What caught my attention is this visual inspection guide written by Louis Rossmann. It seems that corosion on probe points on the motherboard can "kill" Macbook. https://wiki2.rossmanngroup.com/inde...ual_inspection
                      I wonder how corrosion cause this. If there is a track that has a probe point made on it and corrosion is build up on that place, does this means...
                      01-31-2021, 10:46 AM
                    • JimBanville
                      MOSFET mystery
                      by JimBanville
                      N channel mosfets testing as P type?
                      Working on a smps.
                      Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                      Removed a pair of mosfets marked 1L02AB FDP
                      26N40 from the circuit.
                      The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                      I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                      09-14-2023, 04:22 PM
                    • irnard
                      Micro SMD probe tip for Rigol oscilloscope ?
                      by irnard
                      Any advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
                      02-09-2023, 09:22 AM
