Multimeter problem
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    Multimeter problem
    I don't know if this is in the correct place but it made sense to post here.
    Earlier I was testing a DVD player, was testing for mains coming in and wasn't reading anything, so I unplugged the cable and put the probes into the white plug that connects to the power supply inside the DVD player. When I plugged it in my multimeter read 1000volts which I think was its max, buzzed and popped.
    How can mains burn out my multimeter? has this happened to anyone else?
    Re: Multimeter problem
    Was the meter set to ACV? Can we see the pictures of the damaged meter?
    • quiggy
      • Aug 2014
      • 136
      • United Kingdom
      Yeah, I had it set to AC and 1000 volts, I can get a picture sorted for tomorrow. The meter still comes on but the display is flickering and it shows random readings, continuity test also does nothing, it used to have an audible sound but not any longer.
        • 31154
        open it and look for burn marks.
        • quiggy
          • Aug 2014
          • 136
          • United Kingdom
          I had it open earlier, I didn't see any visible damage, anyway I'll post pictures later.
          • retiredcaps
            • Apr 2010
            • 9271
            If it is a name brand good quality meter, there is a possibility that the front end input protection did its job and saved you and meter from harm.
            Testing the input protection components is fairly easy with another working meter and replacement parts can be found.
            Good clear focused pictures of the make, model and pcb (both sides) will help.
            Dave Jones did a video on input multimeter protection.
            http://www.eevblog.com/2012/10/19/ee...tion-tutorial/
            --- begin sig file ---
            --- end sig file ---
            • quiggy
              • Aug 2014
              • 136
              • United Kingdom
              Pictures of my meter, i can get close ups if needed
              • vinceroger69
                • Mar 2012
                • 6714
                looks like you had it on dc volts then but was testing ac volts acording to ur post 1 maybe the white fuse has blown have you got a spare multi meter you can borrow to test the fuse.your post 3 says you had it on ac 1000v but looks like ac volts goes to 700 volts did you have it on ac symbol?
                  • 31154
                  the coil between the fuses looks cooked, the diodes near the probe sockets need a better look.
                  the tiny resistor or whatever it is to the right of the rotary wsitch looks fucked,
                  and i think that's a low battery warning on the display.
                    I would check D1~D4.
                    Wht position of the selector switch was it in when you were trying to measure the AC line?
                    • quiggy
                      • Aug 2014
                      • 136
                      • United Kingdom
                      Looking at it now it was probably an oversight on my part with 1000v dc and 700ac being 1 click away from each other. So totally my fault lol
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Yes ive been there done that myself with my first ever multi meter ive learnt to double check now.
                        • quiggy
                          • Aug 2014
                          • 136
                          • United Kingdom
                          Feel like quite the idiot. Ill replace the meter rather than attempt repairs, it was pretty old anyway
                            • 31154
                            i prefer Auto-Ranging meters, far less to fuckup on those.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              Yes thats what i got after my misshap i still have a manual range one too though.
                              • R_J
                                • 9580
                                Is it possible you had the probes pluged into the amp (A) or(10A) instead of the voltage (V Ω) when you measured the Voltage, that would do it.
                                  Auto range is not going to solve the AC/DC wrong setting. He was 1000VDC and still blew up by 230VAC (648V P-P).
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Good quality meters will survive any "oops" moment and protect the user and itself.
                                    If you are not going to try and fix, I won't make any suggestions.
                                    • quiggy
                                      • Aug 2014
                                      • 136
                                      • United Kingdom
                                      I'd probably need to purchase another meter to repair this one, wouldn't I? It just seemed to make sense to just grab another if I were having to buy one regardless lol
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        Mistakes happen to everyone. When these happen I am thankful it was not my body that took on the damages and that I learned something.
                                        It definitely makes sense to get another meter. If you repair the old one that's great, it's better to have two meters than none. Sometimes it's good to be able to check voltage and current at the same time.
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • guizmo1967
                                          NAD CD/DVD Player T-513 Problem !!
                                          by guizmo1967
                                          I have a NAD T-513 that always display DISC Err, no matter what kind of CD I use.
                                          I change the optical laser pickup, it was only 20$, I had nothing to lose, but it did not solve the problem !
                                          My question is:
                                          On a good working CD player, is the RPM always constant, because on mine, it goes up then down, up then down repeatedly ???
                                          I check the VCC pins of the Motor Drive IC (LA6560) and +8V is present. But one thing I notice, this IC gets hot really fast ???
                                          Do you think LA6560 is bad or the spindle motor ??...
                                          12-30-2023, 03:30 PM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                          MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 05:30 PM
