Hello all. I am new at this but have some soldering experience. I want to recap a few pieces on my Soyo Dragon and am considering buying a used Metcal SP 200 station. Anyone heard of them and I think it has an internal ground fault or something. Is this OK for working on boards or does there actually need to be a physical ground connection to the board for safety and to be sure not to fry the board? Anyone with experience please chime in or suggestions for a different station would be appreciated. Thanks.
metcal sp 200 soldering station
Re: metcal sp 200 soldering station
why dont you fix the internal ground fault? its recommended to have that
i think it would be a nice station although the metcal tips are expensive.
can get a hakko 936 for about 75 bucks -
“Most soldering irons should be hard grounded (i.e. <5 ohms) and ESDS should be grounded before coming into contact with the tips. This hard ground is needed because the vast majority of soldering irons have some form of temperature control, either by switching the iron on or off at limits, or by using high frequency effect. These control mechanisms can produce electric fields and thus require a low impedance path to ground to prevent high potentials from being accumulated which can damage ESDS (ESD sensitive items).” (EN 61340-5-2 Section 5.2.10)Comment
Welcome kd677777
if you can get it for the right price and fix it and its working ok apart from that
why not they are apparently very good gear to have.
If you want to save some bucks wiilawake's suggestion is a good one
How suitable that model is for recapping I don't know
I think what you are getting at is what is known as ESD or Anti Static Precautions
(Electro Static Discharge)
There is info on the net with regards to this
Should you use Anti Static Precautions? Ideally yes
(some don't and the pcbs survive ok)
just google either term for more info on what you need to do,
HTH
CheersYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
Hi everybody,
I am new here. I am looking to get a new soldering station and the hakko 936 you mentioned sounds good to me. What is the best tip size/shape to use for cap replacement? I had a nice Weller Solder Station with temp control and the thing quit working right about out of warranty and was seldom even used. The part (at least the part I think went bad) cost about $100 + bucks so it is sitting in the closet...
Thanks,
dbRegards,
dbComment
A chisel tip of around 2mm is best used for motherboard recaps. I have an extremely similar soldering station to the Hakko 936 (It is actually exactly the same but with a different brand slapped on it) and I use a 1.6mm chisel tip with it. Works so much better than the pencil tip that came with mine.
Perhaps some of the other forum members can help resurrect your Weller unit. Sounds like a fairly large expense and nothing major is wrong with it. It may well be easily fixed yourself.Comment
Thanks for the info. Do you prefer a small, medium, or large iron? I figure I will ask all the basic questions before I purchase one so I don't have to do it twice. My Weller was diagnosed by me and also researched quite a bit on google and many others havd the same problem and same complaints with that model. If I can find a temp control on e-bay I would buy it if the price was right but would rather get a reliable simple station so if it quits it is cheaply repaired or replaced.
Thanks,
dbRegards,
dbComment
I just ordered a Hakko 936 and a few Hakko flush cutters ( CHP-170 ). I think I will sell my Weller on e-bayRegards,
dbComment
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by chth96hello.
A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
https://ko.aliexpress.com/item/4001275635593.html
Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
Any reply would be appreciated. -
by capriderHey,
I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
I now have a TS100 and some soldering irons and looking for some better tools.
1. Soldering station, budget around 200-240€
JBC BT-2BWA seems to be a good product in the budget.
2. Hot air station, budget around 200€
Up to now I've found ATTEN ST-862D to be a good option.... -
by mkbehbehI purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
I am... -
by Peter_1402Hi Everyone,
I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
1. Soldering iron works great
2. There is a burnt mark on the hot air gun handle.
I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
Reed switch tested ok with a magnet.
From the above test, I can conclude... - Loading...
