noob question about solder
+ More Options
Posts
  • angelofhope
    • Apr 2007
    • 6
    I have found this solder wire lying around, it is 0.5mm Sn62PbAg2 http://www.radielfondam.com/, any idea if this is any good for recapping a motherboard?
    TIA
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: noob question about solder
    Looks good. It should flow well.
    Note: Admins may want to edit the link and remove the last parenthesis!
    • angelofhope
      • Apr 2007
      • 6
      Tried it on a very old board, just to see if I might be able to recap another board, seems like the biggest problem is getting the whole clean... is this really necessary? anyway, the solder was really easy to work with, although I can't test if it's well connected, because the board didn't work to start with and I just tried removing some caps and reinserting them again.
      Still found it difficult enough, but it might be worth the risk if there's a possibility I might get my K7VTA3 working again.
      • starfury1
        • May 2006
        • 1256
        For clearing the pcb holes check the FAQ's on this site and practice on junk pcb first.
        (stainless steel needle or dentist pick)
        As to the solder well from what I gather above and the site
        (which I can't read)
        Sn = Tin
        P b= lead
        Ag = Silver
        From periodic table Here
        So
        62% tin
        2% silver
        36% lead
        if I read it right (think you may have missed the PB spec but not sure)
        60/40 is what is normally used for Electronics although this has now changed thanks to RoHS
        60/40 solder allows a small "plastic" state between liquid and solid states when cooling.
        (63/37 offers min plastic state, not Ideal from memory so 60/40 was chosen)
        So that should be ok to use
        I am not into the use of more exotic types solders but if its not flux cored you will need to use electronics type flux with it.
        my thoughts HTH
        Cheers
        as always I'll stand to be corrected if wrong
        • 999999999
          • Sep 2006
          • 774
          For the sake of completeness I resurrect this old thread.
          63/37 is the preferred eutectic forumlation. Having 60/40 stay in a plastic state is more often a bad, not good thing, as it may result in cold solder joints when a part doesn't stay perfectly still.
          There is no good reason to choose a tin/lead solder that also has silver in it. That will just require more heat to melt it. Yes you "could" use it, and have a fine result but if we're splitting hairs then having silver in it is worse than not for a typical repair scenario where there no way to precisely control the soldering temp. Even if you have a highly accurate soldering iron with regulated temp you are still maintaining far above the melting point of the solder, sometimes much higher when soldering caps onto power planes.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            i use 60/40....cold joints who me?
            • gonzo0815
              • Feb 2006
              • 1600
              Silver containing solder is used and promoted for SMD devices, as silver containing solder does better wet the the parts.
              Sure, for leaded soldering i think it is not necessary for trough hole components.
              In case of lead free soldering, AFAIK Ag containing alloys have the lowest melting point compared to other lead free alloys.
              • 999999999
                • Sep 2006
                • 774
                Silver solder in general tends to have a more active flux, and optionally, a higher % of flux. These two factors can make the silver bearing solder flow (wet) as well or better, but by the same measure the stronger and/or higher % of flux could be selected in a non-silver (PbSn) solder and then it would flow/wet better (best). Unfortunately beyond a MSDS, many solder manufacturers aren't so eager to fully disclose the compositions of their flux beyond the main active ingredient and carrier.
                • corrize
                  Best way to solder LVDS connector for beginner (and qfn) ?
                  by corrize
                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                  See the test :
                  https://youtu.be/bNAzC-EvqHs?t=1767
                  With hot air from bellow the board, that's...
                  03-09-2023, 02:57 AM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
                • petemanuk
                  BGA solder balls not connecting - help pls
                  by petemanuk
                  So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                  I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                  I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                  11-16-2022, 05:21 AM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • sircastor
                  Solder not reflowing - what am I doing wrong?
                  by sircastor
                  I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                  For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                  03-03-2024, 02:44 AM
