This that famous harmonic distortion?
    Re: This that famous harmonic distortion?
    Most of the cheapest meters have a diode peak detector so they are only accurate for pure sine wave that has no DC component.
    • Behemot
      • 4845
      • CZ
      Enjoy, APC BE550-FR. I guess active-PFC PSUs won't like this stuff…
      • Behemot
        • 4845
        • CZ
        Originally posted by Kiriakos GR
        New glossary terms for you.
        what's coming out from all those al cheapo UPSes.
        Modified sine wave with passive PFC.
        my cheap multimeter can only make like 160 V from it
        Average measuring meter = Non - True RMS
        OK, there was nothing new for me.
        New information for you: „modified sine wave“ can mean all types of strange and sometimes pretty terrible wave types, which have absolutely nothing in commong with sine wave, other than maybe carying +- the same energy. Waves definitelly not healthy for hunreds od devices out there people often use them (or try to use them) with. And I am not talking about PSUs here but things like pumps.
        My plan is to map some of it and do some experiments with it.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          People the man become expert in just 24 hours.
          Do no post further messages.
          • Behemot
            • 4845
            • CZ
            Let me ask, who are you telling me not to post anything else in my own thread? Aren't you somewhat too self-important lately?
            Don!t get it wrong but as quite often, especially from you, when I ask something, I get no answer but everybody telling me how wrong I am doing it and what moron trying to kill myself I am. Thank you very much, very helpfull. I did not get the answer till now BTW.
            Now when I checked different phase, distortion-free, I got pure sine wave so my idea was confirmed, thanks for making me find it myself, which is the best possible solution by the way.
            So I am sorry, but such input as yours I don't really need
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
              #26
              Just take a camera and show your face.. I do not do... me..you...me...you.. dialogs with ghosts and kids.
              • Behemot
                • 4845
                • CZ
                #27
                What?
                  "I told ya several times already, I am no idiot." Who is calling you idiot, from what we see, the measurement is not done right so what you see is not truly represent the real AC wave form you are trying to look at without using the diff probe as others have pointed out or float the scope (which is dangerous and the input of the scope has to be able to handle the voltages). If you are going to get mad when we pointed out the method you are using is not right, then good luck.
                  Draw up the 3 wires you have on your outlet, the Phase, the Neutral (return), the safety Ground. if the Neutral is not tied to safety ground at the circuit breaker panel, then your reading between the Phase and Ground will not be valid since you will be reading the voltage through the stray capacitance of the wiring/ main transformer that supplying the power to the outlet. That P-P reading as shown that I see also tells us the reading is not done properly.
                  If you put AC meter between Hot and Ground, if the Neutral is tied to Ground, then you should read 230VAC. Reading of 160VAC between Phase and Ground indicates that the Neutral is not tied to safety ground or the wiring problem.
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    #29
                    Hi Behemot, Do you have the scope isolated?
                    if so that is wrong. What you are measuring should isolated.
                    You should measure the output of the transformer but it will filter some of the noise from the grid.
                    My pc
                    CPU : AMD PHENOM II x4 @ 3.5Ghz
                    MB : ASUS M4A89TD PRO USB3
                    RAM : Kingston ValueRAM 16gb DDR3
                    PSU : Cooler Master 850W Silent Pro
                    GPU : ATI Radeon HD 6850
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      Neutral is tied to ground, before breakers, that's the norm around Europe, did not see important to mention that.
                      I told ya what the O-scope was measuring was not important by that time - I am not doing measurements now! Simply looking how the wave looks; probably multiplier was not set right but that does not matter. That 160V was what DMM was showing when running on battery - that made me somewhat think the output is some crap so the meter is not even able to measure it. Also wattmeter got nothing from it. So I looked at it with O-scope, you can see the result in post #22.
                      Differential probe seems to me like some wonderfull mantra which will save everything. Generations managed without it and I also won't buy differential probe expensive like hell for simple looking at waves and taking orientation measurements.
                      Another phase without any load looked OK so that confirmed for me the technique is fine and I really saw harmonic distortion by the power supplies (display has no PFC at all, ATX PSU only passive one), maybe lights (don't really know where the lights are connected in here).
                      joshnz: yes, would you ppl at least mind reading what I wrote? It is in the very first post, O-scope is isolated by 2kVA isolation transformer. Jeez, that's the first thing to do when measuring things like this.
                        It's a bad idea to isolate the oscilloscope. Always isolate the load instead.
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          There was no load.
                            Well, always isolate what you're testing anyway. Never the oscilloscope.
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              Been using it for load but can do for empty socket as well I guess. The question is if it won't smooth some of the waveforms?
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                #35
                                My understanding is the ociliscope is getting it's power from the isolating transformer and probe is connected to to the mains?
                                My pc
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  Yep.
                                  • joshnz
                                    • Feb 2011
                                    • 969
                                    • New Zealand
                                    #37
                                    I also understand that you have the ground clip of the scope connected to the neutral of the power point?
                                    My pc
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      Nope, to the ground as well. I say as well because the O-scope ground is connected to earth ground directly. I see what you mean but I am not really sure if it would be safe to ground the neutral of running UPS - I cannot be really sure the neutral is not flowing so there may be some (not low) currents flowing through, no?
                                        The reason it is not safe to isolate a scope is because it's a single insulated device, which means one failure is permitted, a live-to-chassis fault. With a properly earthed instrument, this will simply trip the RCD/GFCI or blow the fuse. Isolating it removes this protection. In addition, if you happen to connect the earth of the scope to a live circuit, the scope chassis is now floating live. If you touch it, you could be electrocuted.
                                        So, always isolate the load/DUT only!
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          Nope - it is directly donnected to earth ground so it will go to short and trigger breakers. Besides, there almost nothing metalic besides connectors on it…
                                          • dreamlayers
                                            Weird clipping on Logitech Z-10 speakers
                                            by dreamlayers
                                            I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                                            05-22-2025, 11:41 AM
                                          • ktmmotocross
                                            Asus X58c some distortion on output of ALC660 ic
                                            by ktmmotocross
                                            Hello.
                                            Have this old Asus X58c that have some distortion on output of ALC660 sound ic. distortion is in SPK and Headphone.
                                            i dont have spare ic, but it looks like a bad ic. have anybody some experience with this error?
                                            05-19-2023, 08:58 AM
                                          • pabloroggeri
                                            Dell inspiron 3421 that distortion on the screen
                                            by pabloroggeri
                                            Dell inspiron 3421
                                            Mother DNE40-CR MB.
                                            Good guys.
                                            I have this problem with this Dell notebook, it has that distortion on the screen as you can see in the photo. has it ever happened to you?
                                            I present the tests and measurements that I already did:
                                            I tried with another screen and it does the same thing, I also put this screen on another one and it looks perfect.
                                            I checked the LVDS flex that goes to the display and it is perfect
                                            Through HDMI output the image looks perfect
                                            All power lines were measured...
                                            09-29-2023, 06:46 AM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • NorthernCrow
                                            Late model "40 RCA LED LCD, upper 1/3 screen distortion, no T-Con board
                                            by NorthernCrow
                                            Greetings,
                                            I have a quick question for some of the more experienced techs out there.
                                            (my background: I do component level work and am somewhat experienced with TV repairs)
                                            "40 RCA RLDED4030A-B-RK LED LCD TV, about 2 years old, the set experiences distortion in the upper 1/3 of the screen, distortion is not static (at least not all of it),
                                            It appears as what seems to be fast rolling reflections of what is displayed on the lower screen sections and also some light colored horizontal lines.
                                            A thing to note, if a large portion or all of the...
                                            01-02-2019, 12:26 AM
