AIWA mx-70 distortion
  • oboyled
    • Dec 2021
    • england
    Re-curbing the amp , all caps seem visually ok, amp hits distortion at vol level 3, any input. Using aiwa 6 ohm speakers . Any ideas
    • 31246
    how old is it?
    maybe the main smoothing capacitors have dried out.
      • 31246
      o.k. - 30years minimum - probably main caps.
      here's a manual:
      https://elektrotanya.com/aiwa_mx-70_.../download.html
      • oboyled
        • Dec 2021
        • england
        Hi, replaced PSU caps, (2*6800uf) no change. Against schematic both rails were down about +\-6v. All regulated lines were correct. At a loss. Any thoughts.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5059
          • New Zealand
          Excessive current draw pulling the voltage down? And whatever faulty part is also causing the distortion?
          -David VanHorn
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8339
            Kinda weird that it would distort upwards from 3. I assume both channels? Sometimes you gotta answer with desperate measures like Q21 and Q22 muteing circuit, or hauling out the old oscilloscope and see where this distortion is starting out from. It could be caps and IC, cold solder joints, transistors, a DC OFFSET.
            Good luck!
            • netgearnetgear
              AIWA 32" TV not turning ON
              by netgearnetgear
              Good day everyone,
              I have a AIWA 32" TV model #
              AW32B4SM that is turning ON with a blank screen. The backlight is working but there is no image on the screen. I did the standard troubleshooting checks: logic board inspection under microscope, reseating ribbons cables, power rail checks, diodes, mosfet checks, power on and measure voltages on coils, caps, vcc, regulator checks all check good. Then I measured the panel voltage (12v present) and noticed that the VONE (approximately 30v) was missing, the AVDD (15v) was only 5v, vcc 3.3v present, vcc 1.8v present. I know when...
              10-03-2025, 06:06 PM
            • pecman
              Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
              by pecman
              I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
              08-05-2025, 10:10 AM
            • Munem2x
              AIWA JH42DS300S SMART need USB firmware
              by Munem2x
              TV model AIWA JH42DS300S SMART
              Chassis TP.SK506S.PB802
              I need USB firmware for AIWA because video is frozen and remote controller not working.
              I tried firmware recovery file via USB but nothing changed....
              11-05-2023, 04:58 AM
            • ktmmotocross
              Asus X58c some distortion on output of ALC660 ic
              by ktmmotocross
              Hello.
              Have this old Asus X58c that have some distortion on output of ALC660 sound ic. distortion is in SPK and Headphone.
              i dont have spare ic, but it looks like a bad ic. have anybody some experience with this error?
              05-19-2023, 08:58 AM
            • LEEDASH
              Aiwa TX-110 Tuner Buttons
              by LEEDASH
              Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
              Thank you
              05-07-2024, 02:41 PM
