I'm seeing these kits to convert a toaster oven on Ebay. I'm considering trying it but want to know if anyone else here has tried it yet and how it works. I really need a reflow oven but I'd rather not waste my money if it's not going to work good.
Anyone try making a reflow oven from a toaster oven yet? Good? Bad?
by bpjlHello,
When starting the SEF 551.10 reflow oven, the following problem occurs:
It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer... -
by tmhobadcapI heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
Is that possible? I do not want to try this unless I have a spare microwave oven.
(I do not mean to suggest somebody to try this. It may be... -
by bpjlHi,
We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...03-16-2025, 09:26 AM -
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
