Autorange DVM and HV Probe?
  • Ltank
    • Jun 2013
    • 776
    I have a Fluke 87 v3 autoranging meter. I bought Tenma HV Probe and it states not to use a autoranging meter. Why? The meter has worked fine to read 5vdc up to 500 vdc and 110vac to 480vac. What am I missing? does the voltage divider in probe confuse the meter?
    Ltank
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Autorange DVM and HV Probe?
    The HV probe very possibly it have a 1000:1 ratio.
    And so by selecting manually the range there is less chances to miscalculate the reading.
    The Agilent U1272A and similar have a special auto-scale calculating mode, in which you are just setting the ratio of your probe and the meter display the actual voltage even by be in auto range.
    The advice of Tenma is just one warning that it would just alert you up front.
    By setting the range manually to 6V DC you are capable to measure up to 6000V.
      12-31-2023, 06:04 AM
    • jorpec
      by jorpec
      Hi
      Thnaks
      01-23-2023, 10:37 AM
      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
      12-14-2023, 07:45 PM
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • JimBanville
      MOSFET mystery
      by JimBanville
      N channel mosfets testing as P type?
      Working on a smps.
      Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
      Removed a pair of mosfets marked 1L02AB FDP
      26N40 from the circuit.
      The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
      I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
      09-14-2023, 04:22 PM
