PICS! I need some help with one hole....
  • rudeguy
    • Nov 2008
    • 16
    There is one hole on one board that I work on that always give me trouble. These are through-hole solders with a tab instead of a post. All the other ones I do are fine but this one hole always ends up trashed.
    Here are some pics of the board and the problem hole. The purple arrow points to the other hole on the board that always turns out fine.
    I use the same method on both: lots of flux. Chisel tip heated to 350C. Solder wick all the solder that I can from both sides, then pull the tabs out. Every time the one hole is fine while the other is trashed. I have to resort to picking out the old solder with a pick if I can't blow it out with hot air.
    What am I doing wrong?
  • capkid
    • Oct 2010
    • 1339
    Re: PICS! I need some help with one hole....
    Is there a heat sink nearby on the other side of the board?
    LG Plasma Mal-Discharge Correction Service
    • redwire
      • Dec 2010
      • 3902
      You are heating three things - the top pad, the bottom pad, and the lug... With one hot tip.
      Once you use solder wick, there is little heat transfer from lug to pad due to the lack of solder. You apply heat to the top lug+pad, but the bottom pad stays cool and gets ripped up. I think this is what's going on.
      I use either two soldering irons (one on top, other on bottom) or one iron but leave fresh solder ( not wicking it all off) and pull the lug out when hot.
      • domas
        News Hater
        • May 2013
        • 323
        • Denmark
        Agree. I wouldn't use wick here. I mean, as funny as it sounds, more fresh solder with some flux is what helps you. Yes I know the amount of heat you transfer to the board is enormous (huge amount of solder + the heating time), but that is the way I would go. Make sure solder melts on both sides before you try to pull the component
        • rudeguy
          • Nov 2008
          • 16
          Thanks!
          That makes perfect sense. I even resorted to Chip Quik alloy to try to keep the solder wet but it wasn't enough.
          I do have an IR preheat station, I'll give that a try on the next one I do. Leave the old solder in, heat it up to 350, and remove the old tab. I don't have enough hands to use 2 irons at once....how do you guys do that stuff?
          • rudeguy
            • Nov 2008
            • 16
            Did another today, same thing.
            The old solder just won't melt through the hole. So I finally got mad and left it on the IR preheat station for 30 minutes set to 350C. I felt like I was baking cookies.
            But the solder finally melted through. Now to put the thing back together and make sure I didn't melt anything I wasn't supposed to.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              ^ replace any electrolytics, they went and off gassed more than likely....
              Follow the white rabbit.
              • rudeguy
                • Nov 2008
                • 16
                worked like a champ!
                I thought for sure some of the plastic would warp.
                • corrize
                  Best way to solder LVDS connector for beginner (and qfn) ?
                  by corrize
                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                  See the test :
                  https://youtu.be/bNAzC-EvqHs?t=1767
                  With hot air from bellow the board, that's...
                  03-09-2023, 02:57 AM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
                • petemanuk
                  BGA solder balls not connecting - help pls
                  by petemanuk
                  So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                  I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                  I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                  11-16-2022, 05:21 AM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • sircastor
                  Solder not reflowing - what am I doing wrong?
                  by sircastor
                  I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                  For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                  03-03-2024, 02:44 AM
