How about a Capacitance Meter?
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    #41
    Re: How about a Capacitance Meter?
    Yep we got at the main course of the menu after all this pushing around and hair puling like the nervous females do in their dog fights.
    Dear Tom if some one with ten times your education and experiences selects me for an product evaluation, he must know best of what he is doing and why.
    Game Over.
    • mariushm
      • May 2011
      • 3799
      #42
      Are you still around?
      You shouldn't make a determination or assume a person is stupid or an amateur, or the other way around, just because they're active here on a forum that caters to amateur repairmen.
      Just a hint... the person that selected you to give you a product for evaluation could be just a marketing drone that sent the same product to tens of people around the people. Those persons can often have little or no electronics knowledge. So don't make assumptions that those people are smarter, they may be actually idiots for sending a product to a person like you, but for them any review good or bad is good for the company, it's publicity.
      Or I don't know... has it crossed your mind that maybe nobody bothered to ask that company to send them a product for evaluation?
      Some people prefer to downright BUY the product, not beg to have products sent to review, with the basic idea that they won't be biased by this "gift" of a free product.
      Doesn't say anything about that persons' qualifications but it might say something about your intelligence (or lack of) if you're so credulous to believe they pick you just for your talents.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        #43
        Yes I did read that too, I have no comments to make when parts of my BIO and even pictures are publicly availiable.
          "Dear Tom if some one with ten times your education and experiences selects me for an product evaluation, he must know best of what he is doing and why." The most self serving statement of all the badcaps members. I must be VIP then since Agilent which only 30 minutes from where I work want to come by and demo their top of line test equipment just about every month, the sale man never really ask what kind of products we are developing and what the REAL needs are, just want to sell the most expensive stuff they have.
            12-31-2023, 06:04 AM
          • jorpec
            by jorpec
            Hi
            Thnaks
            01-23-2023, 10:37 AM
            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
            12-14-2023, 07:45 PM
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • Stephan Mathers
            EDMI ATLAS MK10 Electronic Meter Discussion
            by Stephan Mathers
            Greetings, new guy here but always interested in the crazy universe of modding
            We just finished construction of around 25 vacation houses, all inside the same private area.
            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
            05-20-2025, 09:09 AM
