Cheaper ESR meter
  • notallbad
    replied
    Re: Cheaper ESR meter
    Keep us posted.
  • mmir2012
    replied
    Ok i shall try it. Today I am working on case/box for proper casing to protect it. Really found it very useful specially as I said that I have repaired oscilloscope which was out of order a long time. I am very happy. Thanks for reply.
    Mubashir
  • notallbad
    replied
    Adjust resistor on TL084 pin 13 to bring freq close to 100khz.
  • mmir2012
    replied
    Good day for everyone,
    LED is now properly working. A capacitor was missing at that stage. A good news is that after checking and testing some capacitors I checked my oscilloscope which was out of order, horizontal line was missing only dot was showing there. I opened oscilloscope cover and checked power supply portion, one capacitor I found that was giving more difference than other. I simply changed that capacitor and ON power supply. I amazed to see that fault have been gone. I am very happy to make very useful gadget for my workbench.
    After repairing oscilloscope I checked frequency at the end of both probes of ESR. Showing 153 KHz is there. If 100 KHz is necessary then I have to fix it, otherwise its working well. Thanks.
    Mubashir
    replied
    Yes, check your connection, the LED should only light up hwen you have unbalance DC on the bridge which will only happen when the capacitor is shorted, or when measure the resistor since short or using resistor will let the DC offset to go through the short or resistor, but it cannot go through capacitor, that is how the short LED indicator works.
  • notallbad
    replied
    I would leave R7 as 680 ohm but check that you are using the correct resistor at R15.
    More likely is that Q3 transistor is incorrectly connected in your circuit. (Base is connected between R15 and C6, Collector is connected to the LED and Emitter is connected to GND).
    Are you able to post a picture of your build?
    I would be interested in seeing it!
  • mmir2012
    replied
    I further worked on it and changed resistors,add one transistor as per original diagram. Now meter is working properly. But as I am using 100 uA instead of 500 uA Meter I have changed the resistor value as per circuit requirement. One problem I am facing now that when I am checking capacitor, LED lit every time when I checks capacitors. May be I have to increase the LED current limiting resistor 680 ohm to above. what u say ? Thanks again for helping me.
    Mubashir
  • notallbad
    replied
    Mubashir
    Find troubleshooting tips in the above link.
    I shall be building various circuits in the next week or two, prototyped on a breadboard.
    Keep going with yours and let us know how things turn out!
    replied
    You can use the 100uA, it will be more sensitive since it will only take 100uA to drive the meter full scale, so you will have to use larger resistor in series with the meter.
    Here is the full text of the one transistor design which he indicated that the second transistor is needed.
  • mmir2012
    replied
    Thanks again.
    You can see attached file for one transistor circuit diagram which I use. Now I am going to add transistor and other components value as per original diagram. Soon I shall back. One thing I want to ask again that I don't have 500 uA meter. But I have 100 uA meter. Is it possible to use this meter instead of 500 uA meter.
    Mubashir
  • notallbad
    replied
    Provide a link to the diagram that eliminates one NPN transistor.
    I believe it is actually GS3's very own design modification but he also mentions that other components need tweaking.
    I would recommend building as per the original circuit, prove it works and record your findings. Then make any modifications and prove it still works be referring to your recorded findings to compare results.
    replied
    If you eliminate TR1, then T2 will not get enough drive to drive the Bridge so the out from the bridge will be too low. You should build it as shown.an you show us the other circuit that only has one bridge driver transistor, they will have to set up one transistor to have enough gain to drive the bridge of set the receiving Opamp gain to be higher.
  • mmir2012
    replied
    Thanks for quick reply. Yes that's the link. Two changes I have made or you can say deficiency. I saw another diagram that eliminated one NPN transistor TR1. May be this changes is making fault the move the meter needle. Second changes is that I am using 100 uA meter instead of 500 uA meter. Now what to do to use this 100 uA meter. As a trim pot I am using 2.2K preset and 680 ohm resistor too. Please help me how to use 100 uA meter instead of 500 uA meter. I have already bought it. I think I have cleared all the picture.
    Wait for reply.
    Thanks.
    Mubashir
  • notallbad
    replied
    Hi Mubashir
    Just to confirm, is this the one your working on?
    http://www.qsl.net/iz7ath/web/02_bre..._esr/index.htm
    According to post No.4:
    'At the output of the opamp we separate the AC and the DC components. First we see a low pass filter, composed by a resistor and capacitor, which allows the DC component to drive the base of the transistor which controls an LED. This LED will light if the capacitor under test is shorted or has high leakage current.'
    My understanding would be that if you were to connect the 2 test probes together then this would act as a shorted cap and light up the LED.
    Does your LED light up when the 2 probes are connected? This should work regardless of meter output.
    This would at least show that something on your prototype is working.
    Another point would be to check which resistors (R20, R21) you are using, the schematic shows 1k trim and 680ohm for a 500uA meter, what rated meter are you using? Have you made adjustment to R21 with any results obviously with probes shorted or with resistor across probes?
    Rob
  • mmir2012
    replied
    Originally posted by budm
    Which ESR circuit are you using? There are more than one in this thread.
    I am using TL084 IC based circuit. I have spent lot of time but 100 micro Ampere needle not moving.
    Mubashir
  • notallbad
    replied
    Thanks Bud, I shall look into sourcing the parts and attempt to build.
    replied
    I build this one as an experiment:
    https://www.badcaps.net/forum/showth...t=18298&page=3
    http://s807.photobucket.com/albums/y...%20experiment/
  • notallbad
    replied
    Hi Guys
    So I shall start with letting you know I have little electronics knowledge but have the determination to get something done.
    Also it may be relevant to point out that I am based in the UK.
    I wish to build these ESR Meters as per
    and
    http://members.shaw.ca/swstuff/esrmeter.html
    and
    http://danyk.wz.cz/esr.html
    I am in the process of acquiring all the components necessary and shall be initially building on a breadboard.
    Anyone out there still that has already built these or just in the know and can provide more details and help in any way? Initially it will be to identify parts needed, namely diodes, resistors and caps.
    Once the parts have been obtained I shall begin the build and report progress with plans and photos, not only will this help me document everything but also may help others.
    replied
  • mmir2012
    replied
    I further checked, LED is now ON when I touch probes. I bought 100 micro ampere meter. My problem is that when I touched probes, meter needle not show full scale. Please help me.
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
    by sam_sam_sam
    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
    12-31-2023, 06:04 AM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    by sam_sam_sam
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
  • Stephan Mathers
    EDMI ATLAS MK10 Electronic Meter Discussion
    by Stephan Mathers
    Greetings, new guy here but always interested in the crazy universe of modding
    We just finished construction of around 25 vacation houses, all inside the same private area.
    Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
    The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
    Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
    05-20-2025, 09:09 AM
