[FAQ] Atten 858d problem S-E (or 5-E) or stuck in 498'C.
    • 31259
    Re: [FAQ] Atten 858d problem S-E (or 5-E) or stuck in 498'C.
    you have 4 wires,
    2 are the element that is exposed.
    the other 2 are the sensor.
    • redwire
      • Dec 2010
      • 3912
      Thermocouple (+) is the skinny red wire, it is unique because a magnet will stick to it- it's iron. You will also get continuity to the thermocouple tip at the end.
      • clearchris
        • Dec 2013
        • 687
        These machines are really hit or miss. I'm looking at getting a T12 soldering iron station, it seems that kgser is the original hakko copier and seem to have the best ones. Eruntop looks like they make their hot air stations, but I'm not vouching for either. I got my hot air station off ebay some time ago, it has been ok, with some notable issues (fuse on neutral)...
        • sepica
          • Sep 2021
          have too one atten 852+ which has worked ok for several years
          now has decided to not going sleep anymore
          it heated properly and cooling down when put on rest
          but display jumps from temp to temp and not going a sleep
          maybe someone faced same?
          br
            • 31259
            check the cable for breaks if it's old - i'v seen that lots of times on soldering irons.
              • Jul 2011
              • 6070
              Originally posted by senndogg
              Its only a week i have been working with my new Atten 858D+ heating station and i have experienced a problem. The station showed S-E in the digital display, the blower fan was ok but it was NOT heating. Searching the web showed that the heating element was gone, this was an error code, but it was not true. Measuring it showed 70 Ohms. Also the mosfet which drives it was not shorted. The station was also stuck in 498'C sometimes, again no heat.
              Browsing again and saw some unresolved topics, there is one at a well-known polish forum. Mine is in warranty too but i was not thinking about shipping it ti China.
              After close inspection at the small circuit in the gun, i could distinguish a cold joint at the soldering of the thermocouple sensor. Bingo!
              Now the heating is working great again!
              Thanks for reading.
              First pic is the Atten 858D+. At the moment it is OK, SLP means "sleeping".
              Second pic is the culprit.
              If I were doing this repair I would resolder all of the joints on this board
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                #47
                today got an 858d that was not heating and after a while give error H-E or H-3 (cant remember if it was down facing). after resolder old solder, check resistor, thermocouple, try another termocouple i ordered the tric bat12 800b. after that i measured all wires (8 wire) to just be sure it was not a wire problem and guess what ? black wire not reading continuity.... now i have ordered 8x0,5mm cable 10meters for 17€ need also those arduino cable terminal to put them back properly
                edit: have to check cable thikness .. maybe 0,5mm are too small
                  • 31259
                  arduino?
                  you mean Dupont terminals?
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    #49
                    Originally posted by stj
                    arduino?
                    i mean the female wire terminal plug
                    • Crystaleyes
                      • Sep 2021
                      • 493
                      • Brazil
                      #50
                      I realise this thread is somewhat old, however I have had problems with an Atten 858D+ which stopped entering sleep mode, and found a solution which might help someone, someday?
                      The problem started after the unit was lent to a friend and the only way to get the heater to chill out was by holding the heater gun above where it was sitting naturally.
                      After failing to locate the reed switch, the situation was resolved by putting a thick band of tape onto the heater handle so the the gun sat about 20mm, or 3/4's of an inch, higher up in the saddle.
                      It's not pretty, but it was done about two years ago and it is still working fine.
                        • 31259
                        maybe the plastic moved on the metal bracket?
                        or the magnet got loose inside it.
                        • Prott
                          Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
                          by Prott
                          Hello fellow Badcappers,
                          I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
                          I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
                          Thank you!
                          03-01-2024, 08:23 AM
                        • Stunt
                          Hp Laptop Stuck on Hp protected by hp sure start screen
                          by Stunt
                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                          screen that's it and stuck there. I left it until the following day and i still...
                          09-02-2025, 01:51 PM
                        • stormanimal83
                          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                          by stormanimal83
                          Hey....
                          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                          01-18-2024, 02:15 PM
                        • ekozeko333
                          by ekozeko333
                          🧠 What I’ve Done So Far
                          Flashed...
                          06-21-2025, 02:48 AM
                        • EasyGoing1
                          The best way to drive a heating element?
                          by EasyGoing1
                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                          This is the general setup that I have now.
                          This is what the...
                          01-25-2023, 11:29 AM
