Anyone try building a ESR meter with Arduino
  • 100MH
    I'm thinking of building a ESR meter with Arduino. The parts are available on ebay and all over the internet cheap. What is your opinion on the design?
    http://arduino.cc/forum/index.php/topic,80357.0.html
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Anyone try building a ESR meter with Arduino
    I have see some one in UK to have built those and actually he is selling them for around 75-80$ USD.
    The circuitry is calibrated, and in a small plastic enclosure.
    My opinion is that if you need a tool it is best most of the times to buy it, so to use your personal energy in to other matters.
    Arduino is an complex subject and does not worth getting to it for just making an LCR meter.
    • Alohamora
      • Aug 2012
      • 37
      I have no opinion on the soundness of the design, but do let us know how it works out if you try it.
      • Peter9DO
        • Dec 2011
        • 277
        Wow, never really thought of using my Arduino for a test circuit... You might be on to something my friend. If you decide to start working on it keep us posted I would love to hear how the progress goes along. I have a little experience with the Arduino so if you have any questions (not saying I will be able to answer them) but shoot em by! I will subscribe to this thread!
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Sounds like a nice project, would be cool to investigate!
          Muh-soggy-knee
          • yo77777
            • Oct 2012
            • ITALY
            That project is final state, but where is full set of eagle files and arduino code?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Then what's the fun? I think it is quite fun to build things and then use them for something ... LOL
              Sorry for bringing up an old thread, it's just, I've been thinking about this more xD I have a 2 line character display, and an arduino, just need to have a working computer.... ugh
              Muh-soggy-knee
              • slackwarerobert
                • Apr 2013
                • 13
                • Third World Dictatorship
                I never even thought of that. Now I will have to drag my old nicad charger out of the closet to get the display off of it. Curse you, as if I don't have enough projects taking up all my free time. Wonder if the cpu will play nice with the arduino, been 30 years since I coded assembly on it.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  I don't have a working computer connected to the internet at the moment, so there, you cursed me
                  Muh-soggy-knee
                  • chth96
                    Is it possible to test small ceramic disc capacitor with analogue meter?
                    by chth96
                    I read EBOOK of Testing Electronic Component and found that
                    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                    Is it really possible to test small ceramic disc capacitor with analogue...
                    03-09-2024, 10:03 PM
                    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                    by sam_sam_sam
                    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                    12-31-2023, 06:04 AM
                  • jorpec
                    Changing the scale of an analog meter
                    by jorpec
                    Hi
                    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                    I wonder how i can accomplish this so the meter would be precise at any temperature ?
                    Thnaks
                    01-23-2023, 10:37 AM
                    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                    by sam_sam_sam
                    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                    12-14-2023, 07:45 PM
                  • Stephan Mathers
                    EDMI ATLAS MK10 Electronic Meter Discussion
                    by Stephan Mathers
                    Greetings, new guy here but always interested in the crazy universe of modding
                    We just finished construction of around 25 vacation houses, all inside the same private area.
                    Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                    The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                    Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                    05-20-2025, 09:09 AM
