Tektronix 422 losing intensity
  • samcan
    • Aug 2012
    • 20
    • U.S.A.
    My Type 422 Tektronix scope intensity knob needs to be near or at max clockwise to be able to have a trace.
    Any suggestions on re-establishing full range intensity?
    Do I need a new CRT?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Tektronix 422 losing intensity
    I can't help you, but there are lots of Tek fans over at the eevblog.com forum. One person there, tekfan, as the name implies knows a lot about Tek scopes.
    --- begin sig file ---
    --- end sig file ---
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      try cleaning the pot ,i had a freind had the same issue with an older scope,wouldnt show trace until it was fully clockwise,i cleaned it with contact cleaner and it worked fine after ,wasnt the same make as yours tho.
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • Peter9DO
        • Dec 2011
        • 277
        Hit it a couple times on the side!** It used to work with the old CRT TVs! lol!
        **Do NOT under any circumstances take my advise! If you decide to beat the hell out of your scope I (Peter9Do) take no responsibility for the outcome, which I for see not to be beneficial to the scope or yourself. I will also not take any responsibility for any personal injury you may do to your (but not limited to) hand, arm, head, foot, leg, knee in the process of dropping a dime on that sucka @$$ O-scope! Keep the proceedings as peaceful as possible and if you must go the rout of bitter rage please video it and post it on YouTube (Please share link on BadCaps forum) like the rest of us would! Thank you!
        • Peter9DO
          • Dec 2011
          • 277
          Here is the service manual for the scope:
          Just click the link on the bottom of the page that says "get manual".
          Good luck!
          -Peter
          • tensorarc
            • Jul 2016
            • usa
            Your posted a link to the Tektronix 422 service manual that is for serial No. 1-19,999, do you have a link for serial No.'s 20,000 and above? The two manuals are not the same. Serial's 20K and above do not use Nuvistors.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8680
              Usually the dimming is mostly irreversible and a new CRT is needed. About how many hours has it been used? (if the answer is "I don't know" assume tens of thousands of hours. Half life of regular CRTs are only around 15K hours!)
              With the service manual you should try the CRT calibration to see if it helps a little, make sure all the pots are good, and at least see if the voltages are good. There are some internal adjustments that may help, but once those are at their limits... new CRT time.
              There are some rejuvenators out there that may help the CRT for a few hundred hours but ultimately again a new CRT is needed.
              One question is whether focus is still good? then perhaps it could be a different problem.
              • chth96
                Is it possible bridging tiny broken trace
                by chth96
                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                cutting tiny trace.
                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                12-03-2022, 11:32 PM
              • Crystaleyes
                RiddleMeThis - What smokes but doesn't burn?
                by Crystaleyes
                hope life is treating you well.
                I have a question, as I am genuinely puzzled.
                There is this old Tektronix 2215 scope which has been laying around for some time, that I knew had some issue, but couldn't remember what...
                Anyways, last night, I thought I'd give it a look, as space is needed, so put it on the bench and plugged it in.
                The CRT had a terrible trace which only filled half the screen and didn't seem to respond much to any of the controls, so I decided to give it 15 minutes to warm up whilst I cleared up the bench...
                07-02-2023, 01:58 PM
              • Friend4Cap
                Tuf gaming b550-pro damage circuit trace help!
                by Friend4Cap
                If anyone can help it will be very appreciate!!
                Motherboard - (TUF GAMING B550-PRO) client connected Floppy Drive 4-Pin Power Connector to RGB_Header_1 +12V G . R . B and Burn one N6V8 and Damage all circuit trace, please check pictures, Motherboard not turning on & everything check ok, no short to ground, I need to repair all circuit trace and replace burn N6V8 but don't know where this 5 circuit trace connect to N6V8. If anyone with TUF GAMING B550-PRO can check. “Thank you in advance”...
                05-07-2023, 05:38 PM
              • jshhh
                Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                by jshhh
                Hi guys,
                I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                03-26-2025, 07:05 PM
              • SluggerB
                Why is my silver conductive trace paint not conductive?
                by SluggerB
                I'm working on repairing a keyboard, there is trace damage on the membrane. So I got my little pen of silver conductive trace repair paint and repaired the trace. Let it completely dry, test it, and its not working. So I take my multimeter out, put it on continuity, touch 2 different area of the paint, and nothing. I put it on resistance, I get OL most of the time, occasionally it might flash to something ridiculous like 17 mega ohms or something.
                Why is this stuff not working? This is what I am using https://www.amazon.com/gp/product/B00B88B9KI
                05-03-2022, 02:00 PM
