Help with DMM Fluke 12B Cap Reading
  • cyberndj
    • Jan 2012
    • 5
    I'm trying to troubleshoot a Phihong Switching power supply model PSM217-404-H-R for my Hanns G HD281 Monitor that's not turning on. I think that is one/some of the caps that are bad. I have a Fluke 12b Multimeter that I got a while back. I tested the capacitance on C601 and it registered 21.5 uF on the Fluke. The specs for this cap are 400v 22uF -- right on spec. I go and test C502 (25v 470uF) cap and get the reading of 3000-7900 uF's. Testing the other caps in the area return the same type of results. I am putting the Red Lead on the positive side and Black lead on the negative side (side with the off color stripe down the cap) using the capacitance setting. There are no bubbled/prego/leaking/brown stuff around the caps that would say their obviously bad.
    1. I would just like confirmation that i'm using this DMM right.
    2. What does this mean with the uF readings so high?
    C502 is the top right one with out the red marking on top. https://www.badcaps.net/forum/attach...7&d=1285542628
    -Jake
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Help with DMM Fluke 12B Cap Reading
    Yes.
    The caps are in parallel. When testing caps in circuit, you will not get accurate readings. You have to desolder them and test out of circuit.
    While the Fluke 12b can measure capacitance, it cannot (no multimeter can) measure ESR (equivalent series resistance).
    See this megathread on your monitor at
    https://www.badcaps.net/forum/showthread.php?t=11329
    I have come to a general conclusion that this particular monitor runs very hot and there are problems with the caps on both the power and main board. You can read through the above for all the details.
    --- begin sig file ---
    --- end sig file ---
    • cyberndj
      • Jan 2012
      • 5
      Thanks for the Confirmation!
      I've been following that thread and going through the troubleshooting steps.
      +5v stand by - +4.95V check (Post 110)
      Voltages similar to post 119 and 121. - Check
      Unplug power, attach controller card and power switch to test as in Post 111
      then POP!!!!!! right when I plugged the power cord in.
      The path from JR1 to where the "negative end of the big cap in the middle connects" curled up and peeled off in parts. --See pic
      Is this repairable (solder a 23 guage wire from the JR1 to anotherpoint -- or am I screwed for this board?
      -Jake
      • retiredcaps
        • Apr 2010
        • 9271
        Check your fuse, bridge rectifier and power mosfet.
        A good fuse should measure less than 1.0 ohms.
        Check bridge rectifier and power mosfet to see if they are shorted.
        See if there is continuity from the JR1 component to the cap. If not, then jumper it.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          Definitely something shorted if you can blow the whole track like that!
          -David VanHorn
          • cyberndj
            • Jan 2012
            • 5
            Ya, i'm trying to figure that one out myself!
            If the fuse is the rectangular box in the picture, then yes its blown, no continuity across it. It reads "T4A 250V CQ" (4 amp fuse at 250V I assume). F1 is printed on the PCB and there is a burn mark right under it as well.
            Just want to make sure, but Points 1-4 is the bridge rectifier, 5-8 the MOSFEt and 9-10 the fuse?
            Thanks again!
            -Jake
            • Agent24
              I see dead caps
              • Oct 2007
              • 4953
              • New Zealand
              Yes, fuses are usually marked with Fx part designations, and the 'T4A 250V' confirms it.
              Points 5 through 8 is the bridge rectifier
              Points 1 through 4 look like a transformer.
              The MOSFET will probably be on the heatsink directly to the right of the mains filter capacitor (big 420v brown one) - I can see at least 4 devices attached to that heatsink, you'll need to trace the circuit and\or look up each part number and find out which one is correct.
              -David VanHorn
              • retiredcaps
                • Apr 2010
                • 9271
                Yellow spray paint is your bridge rectifier. The pcb might say BD or BR.
                Blue spray paint might be your power fet. Green might be dual diodes.
                For all the above, you can test every possible pin combination in circuit. Any reading under 30 ohms suggests a short and requires you to verify out of circuit.
                For example, number the bridge rectifier pins 1, 2, 3, and 4. Measure the resistance between pins 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4.
                PS. Remember that the heatsinks are "live" when power is applied. If you have to do board acrobatics to get a measurement, use cardboard for insulation. You could have shorted something and maybe that is why your power supply went pop?
                • PeteS in CA
                  • Aug 2005
                  • 3580
                  • USA, Unsure of Planet
                  Be sure to be aware of the capacitance range your meter can measure. If what you're measuring is below or above that range, your results won't be helpful.
                  PeteS in CA
                  • cyberndj
                    • Jan 2012
                    • 5
                    Just as a follow up. I ordered a replacement power supply and poped that one in. Now my screen powers on but the screen stays white and no menu comes up. So after reading up, it looks like that it is the T-Conn board might be bad.
                    ...Just FYI if anyone reads.
                    • smason
                      • 1652
                      There's often a fuse on the Tcon board (small surface mount) I'd check it.
                      • SuperAman
                        PS5 HDMI port diode reading?
                        by SuperAman
                        I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                        02-03-2024, 10:16 PM
                      • Khoja
                        Fluke 123 no image on the screen
                        by Khoja
                        Hello experts,
                        I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
                        When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
                        At this point, I'll have to try and fix it myself. Has anyone here...
                        04-10-2025, 09:24 AM
                      • Junkrepair
                        Calculating ESR from tan delta -- tan delta's dependence on capacitance
                        by Junkrepair
                        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                        I found this nice little description of the conversion:
                        Calculating capacitor ESR from Tan(delta)
                        https://forum.digikey.com/t/calculat...-from-tan/2633
                        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                        06-12-2023, 02:45 PM
                      • Fuzzy Fix
                        0.00 ESR reading on a capacitor
                        by Fuzzy Fix
                        Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                        I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                        Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                        07-26-2024, 12:05 AM
                      • kalilinux25
                        no 3v and 5v section voltage reading
                        by kalilinux25
                        Hi my board is HUSK MB 11309-248.4TU05.021
                        The board is plugg and consuming 13 milliamp
                        measuring the 3v coil no reading and the 5v coil no reading
                        Ive measure the pins in PU4103 ( RT8223M)
                        1- NO READING
                        2- NO READING
                        3- 4.4V
                        4-NO READING
                        5- NO RADING
                        6- NO RADING
                        7-3.3V
                        8- 5V
                        9-19V
                        10- NO RADING
                        11-3.3V
                        12- 3V
                        13-
                        14
                        15
                        16-4.4V
                        17-3.3V
                        18- NO READ
                        19-5V
                        20- NO READING
                        21-2V
                        22-2V
                        23-NO READING
                        24- 5V
                        01-27-2020, 03:01 AM
