Fluke 123 no image on the screen
  • Khoja
    • Jul 2016
    • 36
    • Узбекистан
    Hello experts,
    I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
    When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
    At this point, I'll have to try and fix it myself. Has anyone here encountered a similar issue with the Fluke 123 or similar models? Based on your experience, what could be the likely causes, and where would you suggest I start troubleshooting?
    Any insights would be greatly appreciated.
    Best regards.
    • 31255
    you probably should have done some research.
    they have a problem with the flex cable coming away from the glass.
    there is an eevblog video on youtube showing one being fixed.
    not saying thats your problem, but it's a growing one.
    • Khoja
      • Jul 2016
      • 36
      • Узбекистан
      Thank you bro, I forgot to mention that I have replaced the screen but the problem is still there.
        • 31255
        see if you can find the service manual so you can start looking at the voltages and signals at the cpu then.
        • dicky96
          HP Elitebook Screen blank - backlights but no image
          by dicky96
          Hi guys
          I'm trying to fix this laptop screen
          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
          OK so I have the original screen which works but has lines across the bottom quarter of the screen
          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
          04-28-2021, 07:30 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • speedtime07
          i life zed air cx5 no image on screen
          by speedtime07
          hi everyone ,
          There is an image on the external computer screen ,
          flexi cable test ok - screen test ok -
          What alternative should I look for?
          thank you for your support​
          04-10-2025, 06:24 AM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • bohaboha
          LG 47LB630v to dark screen image
          by bohaboha
          Everything works as it should except that it is too dark screen image and the backlight is blue is it normal with bleu backlight ?
          What Can I Do To Get Brighter Image​...
          04-27-2024, 06:42 PM
