Analog ESR meter design
  • mariushm
    replied
    Re: Analog ESR meter design
    ^ i think this is the meter :
    http://pro-radio.ru/measure/10248/
    The links in the text point to an older and similar through hole version with source code and everything available.
  • vhr
    replied
    ESR/L/C/F/P/t meter
    http://www.youtube.com/watch?v=a-mXYYr3KjY
  • vhr
    replied
    marcdima
  • marcdima
    replied
    Originally posted by vhr
    all things are clear now thank you very much
  • vhr
    replied
    marcdima
    TV1,TV2-42TM026-RC
    https://cdn.badcaps-static.com/pdfs/...bddb34ce25.pdf
  • marcdima
    replied
    thank you Simurg
    for the new link I see that you are the author of this great work
    I like the way you made the testing pads for testing the surface mounted cap. , I try to do something similair .
    thank you tom66 for the explanations
    you're right it's very clever
    for resistors I only found standard SMD 1R0
    I think tolerance will influence on the accuracy of measurement , I do not have a choice .
    replied
    Originally posted by marcdima
    Unfortunately, this link does not work now
    http://radiokot.ru/konkurs/10/
    but luckily I saved the diagram (see picture)
    I would really like a small explanation of this diagram
    I'm not a pro of electronics but I have basic notion
    I always learning in this field
    I understood
    In this diagram the power source is a 1.2V battery rechargeable
    the transistor VT1 used as a constant current source to approximately 50mA current given
    capacitor C2 and the transformer TV1 I think it is the oscillator
    The 1 ohm Bridge Resistor for the measuring
    I have a question here! to increase the precision we reduce the value of resistors to 0.5 ohm or less ,so it is possible to use the smd resistance of 0 ohm ? (ideal conductor is not going to be 0 Ohms when I measure these resistances 0 ohm with true rms multimeter I see 0.7 ohm )
    another question the transformer TV2 I think used here to amplify the signal
    What kind used here
    what is he number of turns of the primary and secondary ...?
    I appreciate your support my friends
    thank you very much
    I think I understand how this works (it's very clever)
    The transistor is configured, with the transformer as a blocking oscillator, one of the simplest oscillators you can make, using just one transsitor. It also has a constant peak current characteristic because of this.
    The 1 ohm resistors are to add a voltage which the diode VD3 drops to allow low-ESR measurement. The zero function removes the rest of the offset. The resistors must be 1 ohm to allow you to measure low ESR.
  • Simurg
    replied
    link: http://radiokot.ru/circuit/analog/measure/22/
    forum: http://radiokot.ru/forum/viewtopic.p...60919#p1460919
    transformer TV1 and transformer TV2 http://lightportal.at.ua/2011/SDUanalog/Shem07.jpg
  • marcdima
    replied
    To increase the resolution reduce the resistors to 0,5-0,3Ohms.
    You can also increase the number of turns of the secondary winding of the transformer TV2.
    I understood
    What kind used here
    thank you very much
  • mainfurer
    replied
    I get zero. That was what all the trouble was about... getting it to read zero with the test leads shorted was quite an undertaking, and i learned a lot about stray coupling between wires in the meantime. There are only two test leads (woulda been awkward to use four), but with two pairs of wires going to them.
    For checking PCB shorts you would need to change the frequency to 50Hz and increase the coupling capacitor values so the 50Hz signal passes unaltered. Much less trouble that way. PCB traces are inductive too so if using a high frequency you could have the surprise that a short does not read as such unless the probes are really close to it. Another application for an AC milliohm meter working at 50Hz is as a "ground loop buster" in troubleshooting PCB layouts.
    HELLO!!! greets from Mexico, may i ask you for your final version of the esr add on for the dmm??? can you post please your pcb? so me and other can have a view of your impressive job thanks and hope to read from you soon
  • Ryu.Hayabusa
    replied
    Attached the schematic in ExpressPCB format and as a picture for those who don't want to install the software. ExpressPCB is quite a crude package but i've gotten used to it and i can't be bothered to learn anything else right now. The PCB needs some updates, it'll probably get posted when i find a suitable case for the meter, i'll have to shop around next week.
    Is this the final design? I've been looking for a ESR meter I can build and attach to a DMM so I don't have to muck around with micros or display controllers.
    replied
    Originally posted by Shocker
    I think I figured out why constant-current meters are nonexistent.
    With the constant-voltage design, the higher the ESR, the lower the dissipation in the cap. Remember, smaller caps have higher ESR, and worse heat dissipation.
    The constant-current design means higher ESR caps get HOTTER. And when they're also smaller...
    Not really. Most constant-current designs have a maximum compliance voltage - the point at which the current is unacceptably inaccurate. For one prototype meter I considered building, it was 1.5 ohms. Open circuit voltage was about 1Vp-p.
  • vhr
    replied
    replied
    Current through the cap will in mA or less range not enough to cause any heat.
    IE: 10 Ohms ESR with constant current of 10mA will cause 100mV (about 1 milli-watt of power) feeding the reading circuit, which mean you can even use smaller curret source.
  • marcdima
    replied
    thank you guys I am trying to collect components
  • Shocker
    replied
  • MDOC
    replied
    thank you MDOC I did the translation I wanted to say rather it is not well translated
    OK. I removed the image because it had sensitive information on it.
  • vhr
    replied
    marcdima
    Of C2 and TV2 depends maximum stretching of the scale.I have a scale of 0-5 Ohms.Resolution can be increased to 0,001Ohms!Then the full scale will be 0-0,5Ohms.
    For LOW-impedance(LOW ESR)capacitors that is enough.
  • marcdima
    replied
    thank you vhr this is what I wanted to know
    and thank you again for useful documents
    I need just know the capacitor C2 = 6200* !!! , and I give a try . What is the value of this one ?
  • vhr
    replied
    marcdima
    Works fine.Transformers HDT of old TVs and monitors.
    Resolution-0,005Ohm.
    VT1-BC547
    VD3,VD4-1N5819
    Calibrate these resistors and capacitors.
    https://cdn.badcaps-static.com/pdfs/...3abfb7040a.pdf
    http://www.capacitorlab.com/capacitor-types-polymer/
  • eccerr0r
    lowest current galvanometer/analog meter (passively powered!)
    by eccerr0r
    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
    04-16-2025, 12:41 AM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
  • Darren Hibbert
    Replacing a Current Sense Resistor
    by Darren Hibbert
    Hi.
    Quick question.
    I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
    04-08-2024, 08:36 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    Need help to replace burned resistor in 350w atx psu
    by mikey5791
    Hi to all forum members,
    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
    12-26-2024, 04:55 AM
