Analog ESR meter design
    replied
    Re: Analog ESR meter design
    Double WOW!, it can test any form factor CAPS, I like the way he made the testing pads for testing the surface mounted cap.
  • ben7
    replied
    Originally posted by vhr
    ESR meter for capacitor LOW ESR in circuit.
    http://radiokot.ru/konkurs/10/
    Wow, good link! Never seen that one before. Interesting how the circuits aren't even in a box xD
  • vhr
    replied
  • ben7
    replied
    Ok, I built a ~50khz, ~50% duty cycle LM555 timer circuit. That drives a transformer via a coupling capacitor. The transformer takes in 5vac and puts out about 225mV open-circuit. I used this page and the diagram on it to get my ideas from.
    I can post some pics tomorrow, but so far I have only made the capacitor testing portion. I tested a 63v 330uF NCC LXZ -> 216mV. I tested a bulged capXon KF (1000uF 25v) ---> 43mV!!!
    The 555 has no problem powering the transformer, as its 200:15 ratio. As described on this page, the transformer takes the high-voltage, high-impedance, and makes it low-voltage, low-impedance.
    replied
    I will not be using the Osc section for the short finder, I will be using the Current source and some mod in the probe side for the shorts finder.
  • Th3_uN1Qu3
    replied
    Originally posted by budm
    By the way, what do you get when you short all 4 test leads together, will you read the low resistance of the test lead it self
    I get zero. That was what all the trouble was about... getting it to read zero with the test leads shorted was quite an undertaking, and i learned a lot about stray coupling between wires in the meantime. There are only two test leads (woulda been awkward to use four), but with two pairs of wires going to them.
    For checking PCB shorts you would need to change the frequency to 50Hz and increase the coupling capacitor values so the 50Hz signal passes unaltered. Much less trouble that way. PCB traces are inductive too so if using a high frequency you could have the surprise that a short does not read as such unless the probes are really close to it. Another application for an AC milliohm meter working at 50Hz is as a "ground loop buster" in troubleshooting PCB layouts.
    replied
    Thanks for the explanations, I will try to build one using the LM317 for current source and using 1% resistors.
    By the way, what do you get when you short all 4 test leads together, will you read the low resistance of the test lead it self, I am wondered if I can modify the circuits for checking for shorts in PCB since it can do really lo-Ohm measurement, I use my LC 75 for that function sometime.
  • Th3_uN1Qu3
    replied
    Interesting, can the Constant current source be replaced by LM317? What is the current source output requirement?
    Yes of course it can be replaced by LM317. It's a textbook circuit i found over here: http://www.4qdtec.com/csm.html I chose that particular one because of the good thermal stability.
    For 1mOhm/mV, the current required is somewhere in the 20mA range. Ideally it would be exactly 20mA but in practice this is going to be a bit higher due to the loss in the probes. Use a 100mOhm precision resistor for calibration.
    The OP amp output offset can be reduce if you can you can use precision voltage source for the 1/2Vcc or add adjustment pot to reduce the offset.
    The opamp output DC offset is essentially zero in this circuit as all inputs are AC coupled, and most opamps are trimmed for output offset, trouble happens usually when input offset is amplified. I could have gotten fancy and used another opamp to ensure a stable virtual ground, but in practice a pair of 1k 1% resistors and a polymer cap from virtual ground to power supply ground worked fine.
    The offset i was talking about earlier, as frako pointed out, is created by inductive coupling between the current source wires and the opamp input wires, so the opamp is just doing its job, just that it's picking up what it shouldn't. In practice, this was the biggest challenge. Using wifi coax for the probes, with the shield connected to ground on the board end only, and grouping all four wires together as they leave the board eliminated this issue. Most important is the grouping of both opamp input wires as far as you can, as this makes all noise pickup common-mode and thus rejected by the diff input.
    I used 1% resistors everywhere.
    I see the output from the OSC, and two wires for the diff amp inputs, so how do attach the DUT to this setup. I may want to experiment with one and I want to be able to zero out the test leads itself also. Thanks for posting the diagram.
    The output of the oscillator is between output and power supply ground. The inputs to the opamp join them as follows: IN1 to OUT, IN2 to GND.
    This is intended for 4-wire measurement, so the inputs to the opamp should go as close to the tips of the probes as possible so the probes are compensated for. If you accidentally swap the inputs around you'll know it because you'll get a large offset and bad readings because of the power supply configuration - since this is a single supply circuit, the negative rail of the opamp is the ground of the power circuit.
    replied
    Interesting, can the Constant current source be replaced by LM317? What is the current source output requirement? The OP amp output offset can be reduce if you can you can use precision voltage source for the 1/2Vcc or add adjustment pot to reduce the offset.
    I see the output from the OSC, and two wires for the diff amp inputs, so how do attach the DUT to this setup. I may want to experiment with one and I want to be able to zero out the test leads itself also, I will more likely to use 1% resistors to improve CMR in the diff amp. Thanks for posting the diagram. I am thinking about building this and attach it to $5 DMM. I have SENCORE 75 this is sent out for Cal in yearly basis so I can use this to compare to what I will be making so I do not have to carry this big SENCORE around for small works.
  • Th3_uN1Qu3
    replied
    Attached the schematic in ExpressPCB format and as a picture for those who don't want to install the software. ExpressPCB is quite a crude package but i've gotten used to it and i can't be bothered to learn anything else right now. The PCB needs some updates, it'll probably get posted when i find a suitable case for the meter, i'll have to shop around next week.
    C7 should be low ESR and can be of higher value. The probes absolutely must use shielded cable, with the shield connected to ground. If you want to make your own PCB before i post mine, the power side of the circuit (555 and current source) isn't too critical, but the opamp section benefits from a ground plane (connected to the ground of the opamp which is vcc/2, 4.5v in this case).
    I decided to make the opamp section in SMD because i didn't find the MC33078 in a DIP package and i thought a SO-8 opamp with all thru-hole parts around it would look pretty lonely. I used 1206 and 0805 parts. I would have liked to have all passives in 1206 but that's how i found them.
    If you want to use another opamp the requirements are 15MHz minimum bandwidth and low noise. The input offset doesn't matter since it's capacitor coupled.
  • ben7
    replied
    Guys... This wiring stuff is nothing short of magic. I remembered i had some wifi coax from a scrapped laptop's antenna. I used that for my probes, connecting the shield only at the board end. The ground wire of the current source remained as it was as there wasn't enough coax left over.
    By using this coax and grouping the four wires together as they leave the board, i got the display to show the magical zero with the probes shorted. No more offset. 0.0mV.
    Right now the two wires going to the opamp are wired to the very tips of the alligator clips - those clips are absolutely awful. I'll have to get better ones. Oh, and i've yet to fix the current source, output still shows double what it should. I think i'll get on that right now.
    Once i'm done with this i will release the circuit and PCB layout. For now i'll be sticking with 1mV/mOhm, should be plenty enough for most applications. Next challenge: 10mV/mOhm. Stay tuned.
    Awesome! glad to hear this is going well!
    -Ben
  • Th3_uN1Qu3
    replied
  • cmj21973
    replied
    Originally posted by ben7
    Hmm, I need to get a new breadboard but once I do, I can try to make one of these. I have some SMPS transformers, but I cant get the core apart without it breaking got any tips?
    -Ben
    ferrite cores?
    Transformers are dipped in lacquer.
    Soak them in fingernail polish remover, acetone, or lacquer thinner overnight.
    If the core is not broken into to many pieces, or any missing, it can be super glued back together and still work.
  • Th3_uN1Qu3
    replied
    More progress. Good observation on the inductive coupling - i have separated the pairs of wires and the offset has reduced a lot. Gotta find some properly shielded wire. The other issue was the input impedance of my differential amp which was too low.
    Currently the offset is under 3mV best case, but with it being so sensitive to the position of the wires the meter isn't really usable. I'll report back when i get shielded cable.
  • Th3_uN1Qu3
    replied
    Yes i am using 4 wires for measurement. No, the wires aren't shielded, and the alligator clips i'm using really suck. I'll improve on that as much as i can and come with accurate results before i make the circuit public.
    @ ben7: My circuit does not use a transformer.
  • frako
    replied
    I made some progress. Designed and built my circuit on a PCB, and it works... sort of. There is still offset produced by voltage drop on the wires even though i have a differential amplifier and separate wires for the current source and measurement input. I don't yet fully understand why. Not having a scope anymore really sucks. However, as opposed to the messy perfboard, on the PCB circuit the offset remains constant now and can be eliminated using the relative function of the multimeter. Oh and yes, it does work fine at 100kHz now, so it's a qualified ESR meter. I used a 110mOhm resistor for calibration, which i made from 10x 1.1Ohm 1% resistors, as this was the smallest value i found in 1% at the store.
    You are using 4 wires for measurement? Are the two pairs properly shielded so no inductive coupling between current source and measurement pairs? You really need scope to debug that circuit...
  • ben7
    replied
    -Ben
  • Th3_uN1Qu3
    replied
    The current source ended up dodgy, so in the current shape i need to divide the displayed value by 2, i'm too lazy to swap parts around right now. But given all this, the circuit works OK. It currently has 1mV/mOhm resolution (erm, well, 2mV), has a range of 1mOhm to 2 Ohm (that is if i fix the current source, now it's 1mOhm to 1 Ohm), and is accurate enough to spot caps that have even just started to go bad. I will add another range that goes from 10mOhm to 20 ohm, and if i find a way to get rid of the offset (or better wires) i'll also do 0.1mOhm to 0.2 Ohm.
    I tested all my pulls (mostly junk brands, but a large portion of them are fine) and found over a dozen caps that were bad without bloating. I also found a bad Nichicon (likely simply of old age) i pulled out of a 19" Eizo CRT that had a blurry picture. Again, without bloating. If i had this meter when i decided to dismantle that, that monitor would still be working now.
  • Th3_uN1Qu3
    replied
    Thanks. The original author recommended using a DMM with a relative function to eliminate the offset, but i'm pretty sure that's not the way to go - the offset is unpredictable to say the least. I'm thinking of using a differential amplifier to be able to use 4-wire measurement and completely take the probes out of the equation, which should result in zero offset.
    Also there are nonlinearities at the lowest end of the measurement. A precision rectifier should take care of this. I think this works well enough to try and make a PCB now. In a later revision the 555 timer will be replaced with a more stable circuit that i just thought of, but i want to get the input and rectifier done first.
  • ben7
    replied
    I'm back at it. Found the drill in the meantime.
    I fixed a couple groundloops in my messy perfboard design and now i get much lower offset when using 50Hz. Under 3mV with 1mV/mOhm resolution which is good enough for me. 50Hz isn't adequate for an ESR meter, but it sure works wonders at things like measuring resistance of wires and finding PCB ground loops.
    However, when going past a couple kHz in frequency, the offset would still go crazy. At 67kHz i would get 265mV with the leads shorted. Since i added a separate wire going to the opamp (aka 3-wire measurement, it woulda been 4-wire but it's not a differential input so one of the wires is going to be ground anyway), i tried connecting the positive lead directly to the circuit ground and not to the probe going to ground. Surprise surprise - 70mV. It looks like i found one of the culprits... The wires i am using for the probes have very significant inductance at high frequencies. Gotta find wire with finer strands. The wires are from ATX PSUs btw, so now i've learned something new - some ripple filtering is done by the wires as well.
    Wow, great observation!
    -Ben
  • eccerr0r
    lowest current galvanometer/analog meter (passively powered!)
    by eccerr0r
    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
    04-16-2025, 12:41 AM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • Darren Hibbert
    Replacing a Current Sense Resistor
    by Darren Hibbert
    Hi.
    Quick question.
    I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
    04-08-2024, 08:36 PM
  • mikey5791
    Need help to replace burned resistor in 350w atx psu
    by mikey5791
    Hi to all forum members,
    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
    12-26-2024, 04:55 AM
