Vote on your favorite recapping method. Multiple votes are allowed since some prefer different methods for different situations.
Favorite recapping methods
64Manual spring powered solder sucker0%13Desoldering braid0%16Bulb type solder sucker0%2Desoldering iron/gun (radioshack 45W, hakko 808, etc)0%8Needle/dentist pick0%18Other (PLEASE explain!)0%7sigpic
(Insert witty quote here)Tags: None -
Re: Favorite recapping methods
I personally use the following:
braid- my favorite method. it is pretty low cost, usually effective, and only requires one actual tool to be in use. usually my first method of attack.
spring sucker- used for large joints, mainly to reduce the volume of solder in prep for the braid.
desoldering iron- works te best but the tips don't last. only used when I need a lot of heat (ground planes, etc) and braid has failed me. my other complaint is that it involves using multiple "hot" devices, making workspace management a bit more challenging. however, it also only requires one hand to be used during the final desoldering, giving one a free hand when needed.
needle- a last resort, used when all else fails. if i had a good source for a SS dentist's pick, i would use this method more often.sigpic
(Insert witty quote here) -
don't forget to wet it with flux before you try to suck it. I use my 808, and so far am only on my second tip. though I wish frys sold the ceramic filter for the 808, they still sell the tips for a better price then ebay
I use a needle as a last resort, but the hakko works wonderfully as long as I have the heat turned up all the way
oh yes and remember to plunge the hole every few sucks, also make sure to change the ceramic filter every once in a while
I put the tip next to my ear (not too close!) and hear the sucking sound so I know it has good suctionLast edited by Uranium-235; 11-23-2011, 01:55 AM.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
For PSUs, I use braid, for the same reasons you mentioned, but it never seems to work for motherboards. It gets most of the solder off, but never all of it. For motherboards, I don't use anything to get the solder out. I just melt it with the solderig iron from one side and push the cap through the other side. It only ever seems to damage the pads on ASUS motherboards (even when I try to be a lot more careful with them).
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
If I anticipate a motherboard hole is going to be difficult to clear, I'll break the cap on the component side and cut the leads flush with the board on the component side.
Then I'll use small fine tip pliers along with my soldering iron to pull the soldered lead out through the non-component side. This way, no solder is dragged up through the hole towards the component side - instead, the solder is actually dragged along with the lead as it exits on the non-component side. I often find that there is little solder in the hole towards the component side, and the hole will be liberated merely by this action, without any further sucking or wicking.
Negatives to this method;
The cap may leak various crap that will have to be cleaned up.
If the original flow soldering was very "flow-eee", the hole may have solder thru-and-thru and not just towards the bottom of the hole.
The lead may be cut too short to grab with pliers, or be too short to grab and heat simultaneously, or may break off leaving a small piece that is very difficult to remove.Last edited by slap_happy; 11-23-2011, 03:55 AM.Comment
I put the tip next to my ear (not too close!) and hear the sucking sound so I know it has good suctionsigpic
(Insert witty quote here)Comment
Now I haven't done as many re-caps as you guys, but I just heat up the solder joints with the soldering iron and pull out the cap. Yes, I am aware that this practice sometimes damages traces though.So when I get around to it I will buy a solder sucker thingy
-BenMuh-soggy-kneeComment
Such fancy tools?
With PSUs I used to just use the existing solder, cut the leads of the new cap, and nudge it in while melting the solder from the bottom. I now use desoldering braid.
For motherboards, the braid is sometimes successful, sometimes not. I bought braid for "lead-free" applications. It's interesting, the braid is silver coloured instead of copper. Probably just copper coated with something. Even with this braid, it doesn't always clear the hole.
My iron is a cheap one.Comment
if you don't clear the holes and just heat and push when installing caps, then that is a problem.
I actually made some youtube videos on the desoldering iron and braid methods, as well as one on soldering in new caps. I have none on the spring pump since i couldn't get ti to work on camera and the needle pick since I don't have the dentist's pick.sigpic
but then how do you clear the hole? the "heat and wiggle" method is used for a lot of methods... for me, the only time i leave the caps in when clearing holes is with the desolderign iron...
Such fancy tools?
by cheap iron, is it grounded and at least 30W
if it is any condolence, my main iron is a a 30W xytronic 258... $20 at a local electronics shop... and my desoldering iron is a 45W radios shack one i paid $11 for, (it goes though tips like a ****, and at $2 a pop, it adds up more or less).
I do have most of a 60W weller W60P as, but I more or less inherited it... that is another story for another thread. not operational since it is missing the tip and end nut. I will likely buy a new tip and find an acorn nut of the same thread that I could file and drill to work.Last edited by ratdude747; 11-23-2011, 12:21 PM.sigpic
you are basically using the iron tip's wicking properties int he same way that braid works...sigpic
if you do, look around in the announcements section for my video thread.sigpic
actually let me say this too. if using the vacumn tool dosen't work, I always re-wet the joint a second time with flux and 60/40, and try to keep the hakko on it longer a second time, that usually works. THEN I try a needleCap Datasheet Depot: http://www.paullinebarger.net/DS/
1) I find myself squeezing in 12.5mm caps into spots reserved for 10mm caps. I like to empty the holes of the solder because I want to put the cap in first to see what I have to push around for it to fit.
2) As you well know, some of the tiny caps are impossible to get in unless you leave the long leads on so you can use ordinary needlenose pliers to get them into the holes. In order for this to work, the pads have to be clear.
I wanted to get one of the desoldering irons, but not for what you think. I have an idea I got from somewhere to mod it for something else. I just couldn't find it for a reasonable price.Comment
Nah, I just switched to braid for two reasons:
Yes, this is what I was doing. $2 a pop is very reasonable every few months (Though I was doing this for my iron, not a desoldering iron). Problem is my prized iron from the trash is now defunct. I'm down to one other iron.
it is more like 1 tip every 2 weeks or less if i used my desoldering iron for everything.sigpic
It is easier for me to use the "heat and wiggle" method than to try to completely remove the solder around each lead. After the cap is removed, I remove the solder with a "solder sucker." My best soldering iron is only 25W.Comment
No, it isn't. That's all I ever do on motherboards, and it works just fine. It only ever seems to damage ASUS and ASRock motherboads. I do it on PSUs a lot too.I love putting bad caps and flat batteries in fire and watching them explode!!
When you can't clear it, make sure there is excess solder applied to the bottom in a concave fashion, so that the cap can be held in place by the concave "pocket" from the top of the board, and the cap will go through while it is heated from the other side.
Sometimes I get frustraded and push too hard, and that's when the pad can rip. But I've been getting better and better at it, and this rarely happens. And if I do see the pad starting to come off I at least make sure it's still attached a little bit so there will still be some contact.Comment
by proxneoDear reader
I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
At the moment, I have selected replacements based on the following list of values:
3 x 470uF 10VDC
3 x 4.7uF 35VDC
4 x 47uF 50VDC
8 x 22uF 6.3 VDC
1 x 220uF 6.3VDC
5 x 100uF 6.3VDC
Which...-
Channel: General Capacitor Questions & Issues
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by handsworthJust wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
by PNI E.Hi guys, I write here for help me. I have a Samsung eu75nu8000. The Tv start to turn off and on, and I understand it was a panel problem, because if I take out a ribbon the Tv stay on. I tried the tape method but I have no picture but the Tv now stay on. My question is I have to give up because it s the panel? I notice that the chip vpm2sm it s really really hot, I canβt stay with my finger on it. Do u think all the problem of my panel is due to this chip, or u think it s a death panel and I canβt do nothing?sorry for my English
Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
Thanks.
1hj4z24 = Service tag
A schematic would also be amazing if anyone has one!...-
- Loading...
