Scope probe ground clip sparking on chassis
  • Bob Parker
    Technician
    • Feb 2007
    • 182
    Re: Scope probe ground clip sparking on chassis
    I'm not going to follow this thread any more, while I still have some hair.
    Just be very careful where mains voltages are concerned because the old saying is very true: "A little knowledge is a dangerous thing."
    It is a good shrubbery. I like the laurels particularly...
    • Toasty
      • Jul 2007
      • 4171
      Was this ever resolved?
      veritas odium parit
      • Agent24
        I see dead caps
        • Oct 2007
        • 4958
        • New Zealand
        Gave up on it for the time being. I think the tuner is pretty screwed anyway. Even if it's something simple like corrupt firmware I don't know where I'd get a new copy.
        Might give it some more time.. sometime... if I can be bothered.
        -David VanHorn
        • riotpack
          • Jul 2008
          • 27
          http://www.questronix.com.au/info/info_tingles.htm
          Read that.
          Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
          • Dranoweb
            • Apr 2013
            I apologize for digging up a really old post
            I would also like to say thanks for the manual - I just inherited a q1280 myself.
            just wondering what frequency probe you went with.
            I had high hopes of using this at 470mhz, but looking at the 100khz on the front, i think it's just going to do for my switch mode testing etc.
            again sorry for the old post revival - but info on old stuff, is usually in old posts - and indexed on google.
            • japlytic
              • Oct 2005
              • 2086
              Originally posted by Toasty
              From Kemet.com:
              X capacitors are across the line. { Think X = cross }
              If they short-circuit, the risk is fire.
              Many X-class capacitors are flameproof, a condition of agency approval.
              Y capacitors are from line to chassis. { Think Y = upper points are power lines, lower is ground. }
              If they short-circuit, the risk is a shock to the user. => as is your case
              Y-class units are designed not to fail, but when the do fail, they fail safely (go open circuit); again, a condition of agency approval.
              Remember capacitors are reactive components as well (their reactance is dependent on frequency), which means Y-class capacitors can transfer minute amounts of current between the line and isolated chassis, but this is not enough to become dangerous.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4958
                • New Zealand
                #27
                I got a cheap 50 MHz probe on eBay from some Chinese seller. Probably doesn't even work up to 50 MHz but I doubt it matters since that scope is only good for 5 MHz anyway.
                The most limiting issue with this Q1280 is that the controls are unmarked and uncalibrated. You have no way of knowing voltage and frequency accurately unless you compare to a known signal.
                Despite that though, it's still useful, and much better than no scope at all. But if you can afford it you should probably get something better.
                -David VanHorn
                • redwire
                  • 3910
                  I've repaired a few scopes that got damaged when a noob connected the probe to a mains-referenced circuit. Like a TV or SMPS, the -ve DC rail is live and big spark when you connect the scope probe ground there.
                  It melts a (chassis/earth) ground trace in the scope and it becomes a floater. The X-cap then bites you. Hard to find the pcb break, but most scopes have their bnc gnd to the power cord, if you check with an ohmmeter. They're not designed for a 15A fault there.
                  • redwire
                    • 3910
                    Oops I meant the Y-cap bites you, its leakage current can make small sparks or give you a jolt because the scope lost its ground trace.
                    • repair-it
                      Need advice testing a samsung power supply board with scope
                      by repair-it
                      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                      07-12-2025, 11:00 AM
                    • EasyGoing1
                      General question about oscilliscopes
                      by EasyGoing1
                      What is it about scopes, that make them unique from multimeters? I ask that for two reasons based on my own experience with the last scope I had.
                      1) I learned that getting a scope to read current is apparently not a trivial thing and you need some fairly expensive probes to be able to do it.
                      2) When I tried to use the ground clip on the scope probe to read the signal over a single resistor by putting the ground lead on one side then the probe on the other side of the resistor, it immediately gave me some kind of a warning about over voltage I think ... I didn't leave...
                      02-13-2021, 06:21 PM
                    • budwich
                      ESD Diode on HDMI output of Yamaha a1050 RCVR
                      by budwich
                      I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
                      I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
                      09-11-2023, 12:21 PM
                    • Delicieuxz
                      I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                      by Delicieuxz
                      I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                      Here's an audio clip of the sound coming from my speakers:
                      https://vocaroo.com/16HaryHwTx78
                      I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                      11-15-2023, 09:50 PM
                    • Shuasmith14
                      Dell P2214Hb not turning on, power supply issue?
                      by Shuasmith14
                      Hello, I have a Dell LED monitor P2214Hb that doesn't do anything when the power button is pressed, power button is not lighting up at all. I'm pretty new to this, but I started with testing the power supply first. I know I'm dealing with high voltage and am being careful, I'm using a differential probe for my O-scope measurments. The PS board is E162032 Vol. 3, 4H.26302.A04.
                      Currently I'm getting steady 5v at pins 3,4,5 at the left side connector output and steady 22v at the right side connector output pins 3,4. Right side pins 1,2,5,6 is switching between 0-60v and left side...
                      09-10-2022, 08:09 AM
