soldering stuff
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    soldering stuff
    with my new 40w weller iron and my 60/40 "fine electronics solder" (rosin core), why is it that it makes so much smelly smoke and mostly vaporizes instead of going onto the psu boar where its supposed to go?
    this never was a problem with my old ecg 25w (now broken) iron and over-priced lead-free solder.
    is it the wrong solder?
    also, the iron tip already has a huge chip in it, and is already in lousy condition after 3 uses. is that because i dont clean it, or what do i do to prevent that?
    sorry about the stupid questions
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: soldering stuff
    The iron is too hot for the solder (and generally for most motherboard jobs).
    I have a 40w Weller soldering station with temperature control. It actually just regulates the voltage to the iron, as it's a standard 40w Weller iron. For most motherboards I leave the control at roughly half to 3/4 power.
    Ludicrous gibs!
    • seanc
      • Nov 2008
      • 1319
      Re: soldering stuff
      How new is new? It's chipped, what the hell?
      My cheap, crappy digital soldering station isn't chipped, it just seems to oxidize quickly between tip cleans.
      My 60/40 solder does the same when the iron is too hot.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: soldering stuff
        so what can i do to cool down te iron? solder on a heatsink? can i get different solder?
        this iron is a few uses old (maybe like 1 week)
        • Wrog
          • Oct 2009
          • 472
          Re: soldering stuff
          Which model did you get -- is there no temperature control? I usually set my iron to 350C to desolder (using wick) and 300C to solder using 60/40.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Re: soldering stuff
            no, its the cheapo $21.90 900degree 40w one...
            looks like that
            • Wrog
              • Oct 2009
              • 472
              Re: soldering stuff
              900 degrees?! No wonder... There may be replacement tips that operate at a lower temperature.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Re: soldering stuff
                can i get higher-temp soder? i mean on the package it said its for electric work?!
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Re: soldering stuff
                  it is for thick wire work. not small stuff. if you ever get an imac board to do, one of those may be your best friend... but not for what you are doing. hardware store stuff is not for electronics 95% of the time...
                  i think it is 900 degrees F, not 900 C
                  there should be some smoke from the rosin core... how are you soldering? iron to item, solder to item? try not to go straight to the iron... it oxidizes and negates the rosin flux.
                  sigpic
                  (Insert witty quote here)
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    Re: soldering stuff
                    Two things to try; wrap some #14 or #12 gauge solid copper wire a few turns around the tip and solder from the end of the wire. Or connect a regular light bulb in series with the soldering iron of about 75 to 100 watts (experiment).
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: soldering stuff
                      That kind of iron will work fine for mobos with enough practice.
                      A longer thinner tip would be nice and you will probably have to clean it between every joint, but it will work.
                      Light bulb trick sounds like a grand idea.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Re: soldering stuff
                        im not sure...i guess i just stick the soldering iron to the board/cap leg, and stick in the solder...if i touch the iron directly the solder will vaporize...
                          • 30978
                          Re: soldering stuff
                          i think your using the wrong solder,
                          forget lead/no lead for a second.
                          solder comes with many different fluxes.
                          it sounds like you have active flux (heat activated acid).
                          that type of solder *will* eat bits real fast if you dont clean the tip constantly.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4949
                            • New Zealand
                            Re: soldering stuff
                            If you don't keep the tip clean then yes, it will become dirty and useless.
                            And yeah, never use acid core solder for electronics
                            -David VanHorn
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • Geeker007
                              Friend messed up my laptop motherboard while working on my bench
                              by Geeker007
                              Hi All,
                              So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                              So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                              I have not tried putting...
                              06-16-2025, 01:40 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • tony359
                              Kaiweets USB soldering iron
                              by tony359
                              I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
                              As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
                              In other words, do you think it's expected and...
                              02-06-2024, 12:51 PM
                            • clearchris
                              Old Weller 100/140 Watt Soldering Gun
                              by clearchris
                              Someone gave me two of these 100/140w weller soldering guns. Yes, I know it runs current right through the tip, but might be nice to really get some heat into some big wires that need to be soldered.
                              So, worth a place on the bench, or chuck it?
                              10-04-2023, 01:27 PM
