How accurate needs an ESR meter be?
  • Bob Parker
    Technician
    • Feb 2007
    • 182
    Re: How accurate needs an ESR meter be?
    Originally posted by devid21
    I want to explain to some nuclear physicists why we need a transformer in this circuit.
    It compensates for the error introduced by masuring probes therefore it is possible to use longer probes.
    Transformer provides more current measurement,so it is possible to measure small values of ESR
    This can not be achieved without transformer circuits.
    Fascinating. So we're just imagining those circuits which measure down to 10 milliohms without using a transformer. Thanks for telling us.
    It is a good shrubbery. I like the laurels particularly...
    • devid21
      Banned
      • Sep 2010
      • 82
      And i thought that the topic you are not interested
      It discusses the analog ESR meter using a transformer.
      Always glad to help good people
      I can also offer a good beer
      • devid21
        Banned
        • Sep 2010
        • 82
        With regard 10 milliohms,this value has long been reached
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Update! It occured to me that the one major loss of this circuit is the voltage drop of the 1N4148s. So i realized that adding a gain stage would be pointless because whatever it would make up would be lost again.
          And then it hit me. Use schottkys! I used one SBL1040CT with both diodes in parallel and one SBL2040CT which had one diode blown so i only used half. And... watch that meter swing full scale. There you go, now you have an use for those half-blown 20A diodes.
          A working TV? How boring!
          • devid21
            Banned
            • Sep 2010
            • 82
            It“s all long ago it occurred
            In this scheme 1N4148 nobody uses.
            Columbus when it discovered America.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              #26
              Good one. But anyway, the resolution of the meter basically remained the same, just that it now has higher efficiency hence lighter on that 9 volt. So it occurs to me that my problem is the transformer - luckily i'd just bought a spool of 0.2mm, so i'll proceed making my own transformer.
              • devid21
                Banned
                • Sep 2010
                • 82
                #27
                Today is Saturday.
                Let“s listen RAINBOW- Wolf to the moon.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  #28
                  Well, almost Sunday hehe. Anyway, i've finally understood 100% what are the factors that influence the reading.
                  #1. The sense resistor
                  #2. The primary:secondary turns ratio (the higher, the better)
                  #3. Resistance of the secondary winding which is actually the most important factor. Therefore it is impossible to obtain good accuracy with a small core like EE16 or EE19 which is what i've been using.
                  My cheapo dB meter needs about 15mV to move a clearly visible amount. So, i came up with a circuit that increases the reading by 15mV per 0.001 ohms. Yup, one milliohm resolution. The lower limit will be 0.2 ohms. Since my current one has 0.1 ohm resolution i'll just build a separate meter and not worry about any range switch. I'll be building it next week.
                  • devid21
                    Banned
                    • Sep 2010
                    • 82
                    #29
                    An excellent example for veterans.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      The upper end of low ESR is about 0.1 ohms so if your lower limit is 0.2 ohms it's will not be suitable for testing low ESR caps.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #31
                        I meant lower limit = minimum reading, highest ESR it can read. I said it's gonna go down to one milliohm and it will.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          If it's highest then that would be upper and maximum, not lower and minimum.
                          - Dr Seuss
                          • devid21
                            Banned
                            • Sep 2010
                            • 82
                            #33
                            Transformer serves as consent to provide low output impedance voltage source measurement.
                            When measuring the ESR of about 0,it is not included in the regime of short circuit.
                            Therefore,the output stage is not overloaded and the shape and amplitude of the output signal does not change.
                            The amplitude of the measuring pulse-125mv.
                            When short-circuiting the probes amplitude slightly decreases to 115mv,and the shape of the pulses slightly rounded.
                            This means that measurement ESR of about 0 shape and amplitude of the pulse is almost exact same as the unloaded.
                            This ensures the accuracy and reliability of measurements.
                            Resistance R5,R6-3-5ohm;R8-18k.
                            Diodes-1N5851.
                            Resistance in the generator should be put precision 1%.
                            • jorpec
                              Changing the scale of an analog meter
                              by jorpec
                              Hi
                              I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                              I wonder how i can accomplish this so the meter would be precise at any temperature ?
                              Thnaks
                              01-23-2023, 10:37 AM
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
                            • narf
                              Epson EB-U42 projector / Caps with 0.7 ohms ?!
                              by narf
                              hi all,
                              first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                              i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                              what i've found so far:
                              - the PSU does its job and supplies 12V to the mainboard via the connector.
                              - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                              - not far away, there's the first cap with a resistance of 0.7 ohms....
                              07-02-2024, 03:53 PM
                              Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                              by sam_sam_sam
                              I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                              I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                              12-31-2023, 06:04 AM
                              How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                              by sam_sam_sam
                              About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                              Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                              12-14-2023, 07:45 PM
