Ring Tester Question
  • Mikeley
    ESR Man
    • Oct 2010
    • 41
    I built the Ana Tek Corp Ring tester last evening from their kit. Reasonably confident it's working ok per test instructions etc, but need to build up confidence in it's abilities.
    Working on an Dell E172Fpb, I decided to pull 2 of 4 inverter transformers. Anyone ever ring tested these?
    The secondary on each give me 2 yellow leds. Happy with that!
    The various primaries (there are 3 of them per traffo) are showing no change (2 red flickering leds) or short (no leds illuminated) in the case of one primary of the second of the two traffos... me thinks there is a problem here.
    For kicks, left the other two in circuit and tested with the same results as traffo one. Wondering if there is someone familar with the traffo in this LCD monitor or Ring tester who is willing to comment?
    Mike
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Ring Tester Question
    Did you wind the inductor coil with the kit?
    If so connect it to the kit and all the green leds should light. If it passes that test the kit is fine.
    • Mikeley
      ESR Man
      • Oct 2010
      • 41
      Did that test Krankshaft, all the leds light up solid. So, I'm confident the kit is operating as intended. It has a fresh battery too.
      As the kit is not a 'go/no go' instrument, it very much depends on the inductor under test. Some inductors have higher Q than others. I guess I just need to use it for a while to gain experience interpreting test results.
      For my first victim, the primaries of inverter transformers the E172FPb above all seem to be of low or no Q. I was expecting higher Q. Is my Ring tester just spot on that this particular board has 4 short/open traffos? Looking to benefit from others experience using the Blue Ring Tester!
      I should say that I am waiting on transistors, as two NPN's were shorted out, and decided to take out the transformers as this particular board had the plague... dryjoints! Several other components on the inverter side of the board also had poor solder joints. So I am not too surprised that the traffos may be sacked!
      Thanks for the feedback!
      Mike
      • Krankshaft
        • Jan 2007
        • 2328
        The results are usually comparative with inverter transformers if they have a similar reading across the transformers then they're good.
        The secondary is the part that fails most of the time due to the many hair thin windings.
        To get more of a reaction from the meter try measuring the primaries in circuit and see what happens.
        • Mikeley
          ESR Man
          • Oct 2010
          • 41
          Ok thanks!
          • Ron K
            • Sep 2010
            • 17
            Dear help,
            I just got a new assembled blue ring tester and would like to change the clips to probes, but I would like to shorten the wires, would that affect the test results?
            thanks
            ron
            • Jack Crow
              It's a CLASOB!
              • May 2008
              • 823
              All,
              Ok guys you got me beat on this one.
              Just what is a ring tester? Sounds like something I could have used a few jobs ago.
              Back in the day...
              Some of the mechanics came to me with a military generator 'stator' assembly.
              The 'dc' checks were all in spec, but one of the three phases was near the lower limit.
              Confirmed their DC readings then made up a new test.
              I resonated the coils in the stator.
              Two came up on the same frequency, and the third was in a different frequency.
              That told me one winding was toast and the unit needed to be re wound.
              Gather your ring tester sends a pulse into a coil and looks for response.
              Reaction might have to do with the frequency of the pulse (rise time) loading and the expected frequency of the transformer under test. If memory is any good most switchers are in the 50 to 100khz range. Makes sense your not seeing much of a ring out of it.
              Teach me something new and share a thought. Also if there is a link to the kit, I would like a chance to read it.
              Be well all.
              Jack Crow in Virginia.
              "You are, what you do, when it counts"
              The Masso
              "Gravity, the quickest way down"
              Mayor John Almafi
              "You ever drop an egg, and on the floor you see it break?
              You go and get a mop so you can clean up your mistake.
              But did you ever stop to ponder why we know it's true?
              If you drop a broken egg you will not get an egg that's new?"
              MC Hawking
              • cmj21973
                • 267
                Here's the BLUE Ring PDF.
                • Mikeley
                  ESR Man
                  • Oct 2010
                  • 41
                  Ron K
                  I've swapped the clips for an old set of multimeter probes. I kept the wires about the same length, but shorter would be fine also. Seemed to make no difference in my case.
                  I have been using it away for a few months now with 100% success.
                  ML
                  • Jack Crow
                    It's a CLASOB!
                    • May 2008
                    • 823
                    M,
                    Thanks for that write up.
                    Now have a clue.
                    Someplace in the storage unit I have an old Boonton Q meter. Learned to use one when making parts for AM Stereo exciters back in the 80's. When I saw one on Ebay, it was too good a thing not to grab.
                    So this is the 'quick' edition of the old Q meter.
                    Thanks much
                    Jack Crow
                    The Masso
                    Mayor John Almafi
                    MC Hawking
                    • tony359
                      Ring tester
                      by tony359
                      I'd like to add a ring tester to my toolbox to test flybacks but also low frequency transformers if possible.
                      I found a few products online, some based on the "diodegonewild" design, others are different designs. Some are available to build DIY, others are not.
                      Any suggestions on a DIY one I could put together? Ideally something which would also be able to test low frequency transformers, that might be handy.
                      So far I found these two:
                      http://bobparker.net.au/Basic%20Digital%20Ringer/ (the posher version...
                      09-13-2023, 07:34 AM
                    • nubinator
                      how can i test individual leds without tester
                      by nubinator
                      Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                      I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                      10-25-2022, 11:05 PM
                    • Pipolups
                      Corsair K70 LUX RGB dying LEDs
                      by Pipolups
                      Hi there !
                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                      10-08-2024, 11:58 AM
                      Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
                      I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
                      One other check that...
                      08-03-2021, 06:41 PM
                    • CapLeaker
                      VOIP, ATA REN and old analog phones ring voltage booster
                      by CapLeaker
                      I am working on a backup phone to VHF paging solution. Basically I am dealing with the old Zetron pagers. Here is how it works: One calls a number, the Zetron picks up, operator punches in the DTMF access code, the Zetron keys the transmitter and you can talk. press # the Zetron unkeys the transmitter and hangs up / times out.
                      Now this setup works good on the old land lines, but not at all using a VOIP ATA. You can call all you want and swear like a bastard at the Zetron, but it will not (even if I threaten it's life) pick up.
                      Yep, I know about the high ring voltage...
                      12-10-2022, 09:27 PM
